Old Yesterday, 12:27 AM
RCDad is offline
Find More Posts by RCDad
Bay Area
Joined Feb 2004
I found the fiberglass tubes that house the aluminum wing rod stuck out too much. I cut the protruding ends on both wings and now the wings match up. You should also check to see if the wing rod is too long.
Also look for foam seams that are sticking out preventing a tighter seam. The foam on the top of the wing may need to be trimmed as well.
Good luck,
Kevin
RCDad is offline Find More Posts by RCDad
Old Yesterday, 02:51 AM
jiggz is online now
Find More Posts by jiggz
"its not a hobby its obsession
jiggz's Avatar
United Kingdom, Meopham
Joined Jul 2014
Mine has the same slight gap ..I have never had any flight issues with it
jiggz is online now Find More Posts by jiggz
Old Yesterday, 03:34 AM
icarus the 2nd is online now
Find More Posts by icarus the 2nd
Fly as high as the sun
Joined Oct 2014
Same here, I have a similar gap, no issues though in flight. But I had to bend the alu spar to a much smaller angle.
icarus the 2nd is online now Find More Posts by icarus the 2nd
Old Yesterday, 08:20 AM
NoMoGlo is offline
Find More Posts by NoMoGlo
United States, OK, Oklahoma City
Joined Nov 2014
Good luck,
Kevin
There is a video on YouTube by Sean Byington ("Stupidmonkey") titled "How to assemble a FMS 1400 mm P51B Mustang" where the wing gap issue is addressed in the first two minutes of the video and it is indeed the tubes that accept the spar rods. They are too long and extend past the inner edge of the wing and need to be filed flush to the wing. Hope this helps.
Good luck
Steve
NoMoGlo is offline Find More Posts by NoMoGlo
Old Yesterday, 08:59 AM
radfordc is offline
Find More Posts by radfordc
radfordc's Avatar
United States, KS, Lansing
Joined Jan 2002
That's exactly what the problem was. I trimmed the fiberglass tubes and all is well now.
radfordc is offline Find More Posts by radfordc
Old Yesterday, 09:03 AM
radfordc is offline
radfordc's Avatar
Joined Jan 2002
Without me reading through 400 pages of this thread....are there "fixes" need to be done prior to flying the plane?
I'm wondering about the landing gear struts....do they need to have flats filed to prevent the legs from twisting?
I did have to make an adapter to go from the Deans plug on the ESC to the XT-60 on the battery. I also had to carve a little foam off the bottom of the canopy to clear the batt wires.
Old Yesterday, 11:38 AM
jiggz is online now
jiggz's Avatar
Joined Jul 2014
I would remove the screws on the legs that r used to control travel in the spring put some lock tight on them else u will lose them in flight
Old Yesterday, 02:09 PM
radfordc is offline
radfordc's Avatar
Joined Jan 2002
Thanks, jiggz. I would have missed that for sure.
Old Yesterday, 03:50 PM
jiggz is online now
jiggz's Avatar
Joined Jul 2014
No probs ..ask me how I know they come out in flight ..
I noticed they were missing on mine on the second flight after the sortie where she wouldn't cling to the runway on landing she just kept bouncing
Also when u power up to take off a slight touch of right Rudd is needed from the off as she likes to ark left without input ..
Old Yesterday, 11:40 PM
GiusedtoBe is offline
Find More Posts by GiusedtoBe
GiusedtoBe's Avatar
Tennessee
Joined Apr 2009
Lol, I found that one out the hard way as well when one of the gear was canted sideways upon landing. Destroyed LG door.
I prefer the inspect and tighten over Loctite because I've had bad experiences with that stuff but your method is definitely more foolproof.
GiusedtoBe is offline Find More Posts by GiusedtoBe
New Product New T-28 Trojan 1400mm EPO by FMS jbc Electric Warbirds 8886 Yesterday 09:54 PM
Wanted FMS 1400mm 190,109,F6F or Corsair PNP NEW for Trade FieldofDreamsFlyer Aircraft - Electric - Airplanes (FS/W) 1 Jul 29, 2012 07:07 PM
Poll Choose the new paintscheme for the FMS 1400mm FW190-A8 Beltpilot Electric Warbirds 87 Jul 25, 2012 08:29 AM
Sold FMS 1400mm Zero - LPU in SoCal Inland Empire Justwingit Aircraft - Electric - Airplanes (FS/W) 0 Jul 08, 2012 05:27 PM
Question 1400mm FMS Hellcat or 1400mm FMS Zero? lendwaym Electric Warbirds 7 May 13, 2012 09:27 PM
