Old Dec 14, 2014, 06:12 PM
Michael
United States, ME, Wells
Joined May 2008
Wattage
Check the watts for both packs: 6S ( nominally 22.2 volts) * 4 amps = ~89 watts and 2S (nominally 7.4 volts) * 10 amps = 74 watts.
The 6S, at 10 amps discharge rate, would be over 200 watts; check your manual for discharge limits with / without regenerative discharge, and don't forget the limits on the charger supply battery...
Michael
Originally Posted by WR_Rider View Post
Excuse me for the stupid question I couldn't find or understand what I read in the manual. For the termination "c" in your example! Of c/10 or c/3 is the "c" the chage current or capacity?
Also I was using the stock storage setting to do a 6s3300 pack and it only discharged at 4amps vs the 10amp setting. Then I tried a 2s1350 a d it did try to discharge at 10amps both packs started out fully charged.
Any ideas as to why the 6s3300 wouldnt discharge at 10 amp?
Snowflake6515 is offline Find More Posts by Snowflake6515
Old Dec 14, 2014, 06:50 PM
Electric baptism 1975
DavidN's Avatar
Vernon, BC, Canada
Joined Dec 2000
Here is my understanding.
The discharged power, V x amps, has to go somewhere. If you are connected to a battery for power source, you can set the discharge to regenerate the battery(assuming it has room to be topped up). I think 10 amps input into the 12v battery is the max. If you use a power supply then it must be dissipated as heat & is less.
DavidN is offline Find More Posts by DavidN
Old Dec 14, 2014, 09:18 PM
Seattle
Joined Sep 2007
For most chargers the "C" in C/10, C/3,etc, refers to charge rate. For example a charge rate of 10 amps and C/10 results in a termination of 1 amp. Where as the termination for C/3 is 3.3 amps.
The Powerlabs use the method above unless the pack capacity is specified in the preset. If the pack capacity is specified (its in the fuel tab), then the charger uses the capacity value in the calculation instead of the charge rate. Also the presets allow you manually set a termination value in amps, if you want.
Gregor99 is offline Find More Posts by Gregor99
Old Dec 15, 2014, 06:45 PM
Joined Jun 2014
So I took the genaric storage charge and set it for 4amp discharge and a termination to c/5.
The 6s3300 discharged just under 4 amps but if it had, wouldn't I expect the discharge to terminate at 800ma? (4000ma /5) the discharge terminated at 250ma's.
I assume on storage it's looking at probably more settings. If I had done a generic discharge should it have terminated at the ~800ma?
WR_Rider is offline Find More Posts by WR_Rider
Old Dec 15, 2014, 07:00 PM
Seattle
Joined Sep 2007
There's some addition logic, beyond the charge current. Typically the termination will occur between 20 and 60 seconds after the calculated termination is reached.
New Product Introducing the ALL NEW Cellpro PowerLab 6 (EC5 version) Charger Howard Matos FMA Direct 416 Aug 14, 2014 06:59 AM
Discussion New Powerlab 8X2 302 Z28 Batteries and Chargers 9 Jul 27, 2013 09:08 AM
Discussion Revolectrix Cellpro PowerLab 8 (Charges In 5 Min?) Nickerz Batteries and Chargers 1 Feb 11, 2013 03:30 AM
Discussion The NEXT Cellpro PowerLab from FMA/Revolectrix RCnGuy FMA Direct 13 Aug 20, 2012 10:27 PM
Sold Revolectrix/FMA direct Cellpro PowerLab 8 unused new thwang99 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Aug 26, 2010 04:24 PM
