Old Jul 20, 2015, 05:36 AM
G-LO is online now
Find More Posts by G-LO
G-LO's Avatar
Va.Beach VA.
Joined Aug 2007
Originally Posted by Lee View Post
I have been playing with feathers on conventional wings trying to see what effect they have on flight.
This is the most recent step to get a bird kit back on our site.
Hey Lee. Where are the primary "feathers" located on your site? I have thought about that idea some time back; thinking that your pelicans and Albatross was basically a flyparty Epp Eagle without the feather tips.
With a little tweaking, that design is favoring the look of a Golden Eagle. Very nice *
G-LO is online now Find More Posts by G-LO
Old Jul 20, 2015, 06:43 AM
Lee is online now
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I have been consulting with the same artist that helped with the Peregrine to see what we can come up with. Before we started with a bird and tried to make it a plane. Now we are taking a plane and trying to make it look like a bird so it will fly better. We are going to modify the wing and tail shape and tail and give room for the feathers to be cut into the back of the wing.
Lee is online now Find More Posts by Lee
Old Jul 20, 2015, 03:15 PM
nickchud is online now
Find More Posts by nickchud
What could possibly go wrong?
nickchud's Avatar
Market Harborough
Joined Apr 2006
Dayhead and Speedactyl: About membrane wings....
Can I introduce wing warping into the conversation? Here is a 'Carbon Falcon' from Acesim.com It ought to work.
nickchud is online now Find More Posts by nickchud
Old Jul 20, 2015, 04:15 PM
speedactyl is offline
Find More Posts by speedactyl
Defies Logic & Common Sense
speedactyl's Avatar
Philippines, NCR, Makati City
Joined Jun 2012
Thats cool . My wing require a CG as far back as 30% given it has a AOA of 3-5degrees . Like some powerd microlite planes .
Try upthrust the motor that much to enduce that AOA on your wing.
Wing warping is interesting like those early airplanes.
I could incorporate theconcept for future builds
speedactyl is offline Find More Posts by speedactyl
Old Jul 21, 2015, 09:43 PM
jcstalls is offline
Find More Posts by jcstalls
Dragons, WindMills, all Same
jcstalls's Avatar
United States, IN, Indianapolis
Joined May 2002
Carbon Falcons are great, just particular within their nature.
My first one flew great but I did a few mods, like alum tube ribs, BL IPS w/ CF rod, a few other whittle thangs and lots of time in set up per specs in da manual n trimmin.
Heck, I use to thermal it to boot.
jcstalls is offline Find More Posts by jcstalls
Old Jul 21, 2015, 09:55 PM
speedactyl's Avatar
Joined Jun 2012
hmm I do away with the ribs for simplisity reason and just use airflow to inflate them . problem is if my AOA drops the wing collapse causing a stall. hence the reason I always fly with the nose pointing up. which for some RC pilots this looks unnatural when compare to solid wing aircraft or wings with ribs
Old Jul 21, 2015, 10:35 PM
jcstalls is offline
jcstalls's Avatar
Joined May 2002
Ahw, but can one fold their plane in a postal tube in a moment, only to later a field to fly again within moments?
Old Jul 21, 2015, 11:05 PM
speedactyl's Avatar
Joined Jun 2012
That should be the most ideal rc plane for those who commute and travel by bike
Old Jul 22, 2015, 10:00 AM
MicroHeli-Nut is offline
Find More Posts by MicroHeli-Nut
The Rave.
Singapore Paya Lebar, Singapore
Joined Aug 2003
I just checked, they are out of production! ... Carbon falcons, that is...
MicroHeli-Nut is offline Find More Posts by MicroHeli-Nut
Old Jul 22, 2015, 11:30 AM
speedactyl's Avatar
Joined Jun 2012
Believe me . Its alot complex to produce this type of carbon airframe than to form Foam airframe. This is why foam planes are common. Even wood airframes hardly compete.
my frame is fabricated in aluminum. And just as complex to build.
Old Jul 22, 2015, 02:49 PM
rhokita is offline
Find More Posts by rhokita
gardena, ca
Joined Feb 2003
When I was a kid back in the mid 60's,I made a escapement controlled simple Jedelsky airfoil wing glider. It flew ok. The Jedelsky airfoil with its flat sheet construction should be able to make a compact foldable wing, kinda like the Carbon Falcon. The first 3rd of the wing would be a sorta strong rigid shaped spar airfoil and the back 2/3rds would be a foldable semi-rigid membrane. This semi-rigid membrane would be a sandwich composite of currently available materials, like the tear proof polyester paper, thin pack foam, kevlar roving and mylar, kinda like how they make racing sails. (btw, I built a 'Geoboat" membrane type canoe using dacron and kevlar roving for the membrane). Anyway, I was kinda thinking along this path with the goal of making a 1/2 scale (14') Pterodactyl and I wanted to simulated the animal's membrane wing which i find fascinating. Its another 'brainteaser' project for now...
rhokita is offline Find More Posts by rhokita
Old Jul 22, 2015, 07:03 PM
speedactyl's Avatar
Joined Jun 2012
Cool. My last membrane aircraft is loosly base of the pterodactyl and the brits westland hill variant . But with the added tail fin for extra control
Old Jul 23, 2015, 02:01 AM
nickchud's Avatar
Market Harborough
Joined Apr 2006
I was also wondering about wing warping as a way to replace the tail fin, somehow providing yaw stability,
Old Jul 23, 2015, 04:58 AM
speedactyl's Avatar
Joined Jun 2012
will incorporate that on my next build.. else a I could do a separate surface in a elevon setup attach to the main wing
Discussion Why aren`t most foam planes made with EPP or equivalent. Scarey Foamy EDFs 1 Jul 24, 2007 10:20 PM
Planes Built With EPP And Depron. What Would Be Your Favorite. jbj620 3D Flying 10 Dec 05, 2004 07:06 AM
Rave Before n After My new war bird P-51 Mustang(EPP) powder Slope 22 Aug 22, 2003 01:27 PM
hey guys if yous are looking for arf war bird planes seafire Foamies (Kits) 5 Mar 10, 2002 05:41 PM
