Old Jul 28, 2015, 07:56 AM
Sollym is offline
Find More Posts by Sollym
Joined Nov 2008
Linking Futaba 14SG with Futaba receiver R2006gs
Hello,
I Just purchased a Futaba 14SG transmitter which is a FASSTtest . In reading the manual I understood that it can also work with the S-FHSS receivers.
I purchased a bunch of R2006GS and R2008SB receivers.
I tried to link the receiver to the transmitter but nothing happens. The receiver keeps blinking the red light. I thought that I could change the FASSTtest mode in the transmitter to an optional S-FHSS mode but cant find a way to do that.
Did I purchased the wrong receivers and have to stick with only the expensive FASSTest receivers? or is there a method to do this? Any help please.
Solly
Sollym is offline Find More Posts by Sollym
Old Jul 28, 2015, 08:29 AM
DougV is online now
Find More Posts by DougV
DougV's Avatar
United States, FL, Miramar
Joined Dec 2007
You purchased the correct receivers, you must change the protocol on the 14SG to S-FHSS first then go through the linking process.
On the main screen scroll to FASSTest 14CH or 12CH and press RTN, then scroll to the FASSTest protocol and press RTN and select S-FHSS.
Hope that helps,
Doug
DougV is online now Find More Posts by DougV
Old Jul 28, 2015, 09:48 AM
Sollym is offline
Joined Nov 2008
Radio
Hello Doug,
Thanks for your help.
Since I intend to operate some model with FASSTest receivers and some with S-FHSS receivers, can I use the method you described to set the correct mode for each of the receivers.
Solly
Old Jul 28, 2015, 10:05 AM
Sollym is offline
Joined Nov 2008
Hi,
To clarify my question: If I change the protocol for one receiver to S-FHSS and then change it again for another receiver to FASSTest. Will the transmitter automatically change itself when I choose to a deferent model?
Old Jul 28, 2015, 10:08 AM
DougV is online now
DougV's Avatar
Joined Dec 2007
Yes, the protocol will be saved by each model.
Doug
Old Jul 28, 2015, 10:30 AM
Sollym is offline
Joined Nov 2008
Thanks a lot
Solly
Old Jul 28, 2015, 10:44 AM
Sollym is offline
Joined Nov 2008
Changing protocol
Doug,
From main window I hit lnk and then scroll to system. hit RTN . Scrol to FASSTest-12CH. I select it by hiting RTN once but it does not open an option to change to any other frequency. Help?
Solly
Old Jul 28, 2015, 10:50 AM
DougV is online now
DougV's Avatar
Joined Dec 2007
Select 12Ch and press RTN, then scroll to the desire protocol.
Doug
Old Jul 28, 2015, 11:00 AM
Sollym is offline
Joined Nov 2008
OK, I think I got right. Thanks a lot.
Solly
Old Jul 28, 2015, 11:02 AM
DougV is online now
DougV's Avatar
Joined Dec 2007
You're welcome!
Doug
Sold Futaba 14SG with receiver jmiceli11 Aircraft - General - Radio Equipment (FS/W) 4 Jul 13, 2015 05:26 PM
Sold Futaba 14SG with three extra receivers camoy Aircraft - General - Radio Equipment (FS/W) 2 Jul 06, 2015 08:58 PM
For Sale Futaba 14SG with 3 receivers camoy Aircraft - General - Radio Equipment (FS/W) 0 Jun 08, 2015 04:51 PM
Sold Futaba 14SG with 8 receivers/Case and GY 430 Gyro martinoa Aircraft - General - Radio Equipment (FS/W) 4 May 26, 2015 05:01 AM
Sold NEW IN BOX Futaba T6J 2.4 Radio System with two new R2006GS Receivers !!! shooboy Aircraft - General - Radio Equipment (FS/W) 2 May 12, 2015 06:42 PM
