Old Jul 08, 2015, 10:34 AM
jcny is offline
Find More Posts by jcny
Brooklyn, NY
Joined May 2005
Building a Mini Vapor from parts, which glue to use?
I had to have a Mini Vapor, so I acquired all the parts. I know CA glue was what the factory used, but I want to be able to disassemble it for repairs.
Has anyone used a different glue which worked well? I'm wondering if Contact Cement would hold OK, and still give me the option to take it apart? I know just about any glue would weigh more that CA, but people have been having melting issues using CA Debonder. Does even ZAP Z-7 Debonder melt the plastic?
Also, any assembly tips you could give me would be greatly appreciated. For instance, when I dry fitted the Horizontal Stabilizer, it was not level with the brick holder on the fuselage. Should I "massage" it, or don't worry about it?
Jeff From Brooklyn
jcny is offline Find More Posts by jcny
Old Jul 08, 2015, 09:51 PM
jcny is offline
Brooklyn, NY
Joined May 2005
Actually......
Horizon Hobbies recommended Welder Adhesive in the red tubes, so that is what I will try.
Jeff from Brooklyn
Discussion Which mini/micro to build next Highguy Mini Multirotors 1 Jun 25, 2015 11:41 AM
Discussion Mini Vapor Brick Micro Citabria built from parts balthazar420 Scale Kit/Scratch Built 0 Jun 11, 2015 02:39 AM
Sold Mini Vapor Parts birdbrain Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 May 11, 2015 05:06 PM
Discussion Help Building from Mini Vapor Parts md11spotter98 Beginner Training Area (Aircraft-Electric) 3 Jun 04, 2014 10:30 AM
Discussion Need advice Use Gaui parts or build from scratch Claytonc Multirotor Talk 6 Dec 21, 2013 12:41 PM
