USA, ME, Ellsworth
Joined May 2008
14x9-3 Master Airscrew:
5s 5000: 900+ watts @ 45 amps, 7300 Rpm = 20V = 4V per cell 6s 5000: 1500 watts @ 65 amps, 8600 Rpm = 23.1V = 3.9V per cell 15x13-3 APC: 4s, 5000: 900 watts @ 63 amps 5000Rpm = 14.3V = 3.6V per cell 5s, 5000: 1240 watts @ 74 amps, 5500 Rpm = 16.8V = 3.4V per cell The numbers look realistic enough to me, I don't like what the 15 x 13 x 3 is doing to the cell voltages but it might be OK if only used for short bursts. Jack |
Thanks guys.
I'm wondering if this motor will be any good on a 7.5lb plane on a 5s? Which three blade prop size looks like it will give the best speed and thrust? A 15" would work the best for the airframe. What does a 15x10x3 look like? I really want to run a three blade prop on the Hangar 9 P-40B. But it's not looking very good. |
USA, ME, Ellsworth
Joined May 2008
If you took off at that peak power and immediately throttled back to get the motor down into the 2.5-3 Watts per gram range it would probably be OK. I would also want a battery with a higher "C" rating to keep the cell voltages up around 4V or so at full throttle. Here are some rules of thumb for power levels for various types of planes: Approximate power requirements: 50-70 watts per pound; Minimum level of power for decent performance, park flyer/slow flyer models 70-90 watts per pound; Trainers and slow flying scale models 90-110 watts per pound; Sport aerobatic and fast flying scale models 110-130 watts per pound; Advanced aerobatic and high-speed models 130-150 watts per pound; Lightly loaded 3D models and ducted fans 150-200+ watts per pound; Unlimited performance 3D and aerobatic models Jack |
Thanks guys.
I appreciate the help. That motor just isn't going to work. I might put the L5055A-400KV in my FMS P47 1400mm? I'm going to look at the G-60 motors instead. Maybe a G-60 500KV on a MAS 15x7x3 on a 5s? Looks like enough power and speed. Low flight times though. around 5 minutes? I would like to run a 3 blade on this but not looking good. |
Joined Mar 2010
I wouldn't give up on the prop until you see how it does in the air. I got all sorts of gloom and doom feedback when I proposed putting a 4-blade prop on my H9 Mustang 40. This was a Power 46 / 4S 5000 setup. It turns out that the plane flew very nicely. Of course, it was not as fast as the 2-blade, but it was also not that much slower. The multiblade props can always use more pitch, and they tend to unload more in the air. Also, the surfeit of thrust means the model will come closer to achieving the prop's pitch speed. You really have to consider all the variables here.
So it's done. Again...
Ordered the G60 500KV motor instead for the P-40B. I'll use the L5055A-400KV in another plane. It looks like it will run great on a 5s. I also ordered the 14x7x3 MAS prop to go with it. I'll start with that. With a 5s 5000 It shows a 10 minute mixed flying time. Hope that I get close to that. Thanks for your help guys. Much appreciated. |
Joined Jul 2007
danpos I have no experience with the L5055 400 but I think it would fly that plane just fine. Have you thought about going to a higher cell count and a smaller prop? I think tlh's post was close to what would suit your needs you. From what I have seen when going from a 2 blade to a 3 blade just go down 1" in prop size per extra blade and test the amps.
| Thread Tools | |
| Sold Turnigy L5055a 400kv 1400W (.60 sized motor) | 06graphite | Aircraft - Electric - Power Systems (FS/W) | 4 | Aug 29, 2012 09:38 AM |
| For Sale WTS Turnigy L5055A-400 Brushless Outrunner 400kv $37 shipped | scatsob | Aircraft - Electric - Power Systems (FS/W) | 3 | Jan 09, 2012 01:01 AM |
| For Sale TURNIGY 50-65A 400kv Outrunner | Mikemynameis | Aircraft - Electric - Power Systems (FS/W) | 1 | Dec 29, 2008 12:41 PM |
| Sold TURNIGY 50-55A 400kv Outrunner w/TURNIGY 80AMP ESC | dizzane | Aircraft - Electric - Power Systems (FS/W) | 8 | Jul 13, 2008 09:19 PM |
| Discussion Turnigy 50-65a 400kv | blackstrat | Power Systems | 10 | Jun 11, 2008 09:20 PM |
