Old Jul 05, 2014, 08:58 PM
Antaeus's Avatar
NEWPORT BEACH, CA, USA
Joined Oct 2001
Not for my set up at least. You will probably fly at ~70% throttle (~45Amp) most of the time. Batteries after a 3 min circuit was at ~100F. That is why I don't source current from 1 big pack pulling 150Amp.
Antaeus is online now Find More Posts by Antaeus
Old Jul 05, 2014, 09:03 PM
DamonH's Avatar
United States, NM, Clovis
Joined Oct 2011
So you run two 6s in parallel?
Edit: disregard, I went back and saw you posted it... Do you run the same setup/batts in the A-10?
DamonH is online now Find More Posts by DamonH
Old Jul 05, 2014, 09:35 PM
United States, CA, San Diego
Joined Jan 2011
Interesting idea- so how long are your flight times?
IntheTubeDeep is online now Find More Posts by IntheTubeDeep
Old Jul 05, 2014, 11:49 PM
Antaeus's Avatar
Joined Oct 2001
Damon, yes, the A10 has the same set up. Not parallel. One 6s 2600mAh feeding one ESC/Fan/motor.
ITTD, My timer is set to go off at 2:30 By the time I landed, it is a 3:15min flight. Typically, my charger puts 1600mAh back in the 2600 pack.
Old Jul 06, 2014, 03:59 PM
Joined Jan 2011
There is a groups of guys in Singapore I think they all fly their 29 in 4s, 2x3000s in parallel they get good flight times like 4-6+ minutes but they fly Wemo/HET set ups on 5B fans, I'm sure the 4s set ups are not ideal for 12B fans, just way to high amps for a 14.8v set up
On my mild ERC 12B/HET 3w25 fans in my Su35 it draw only 88-90A at WOT so I get decent flight times, like 4-5 minutes- thats pretty good on a twin 70
Old Today, 04:12 PM
Antaeus's Avatar
Joined Oct 2001
ITTD,
I thought I show you what wonderful things your FreeWing 12B special metal fan / 2200v motor can do for your F-22. I am sure my RCBlog Galaxy 12B are made by the same manufacturer.
55-degree-plus climb-out! I don't think my HET powered LX Mig29 can do the same. My maximum amp draw is 70Amp per motor.
Mig29 Twin 70mm powered by 2 FreeWing aka RCBlog Galaxy (4 min 9 sec)
Old Today, 04:34 PM
DamonH's Avatar
Joined Oct 2011
Nice flight! Are you using stock landing gear?
Old Today, 04:57 PM
Antaeus's Avatar
Joined Oct 2001
Thanks Damon! I have been using stock plastic landing gears and I don't usually have problems with them. I may occasionally get a gear stuck in down position, but that's about all the problem I had.
Old Today, 07:19 PM
Corsair Captain
United States, AZ, Mesa
Joined Oct 2010
One of my main V2 got stuck up. Need to grease the end points so they can break away when called to do so. I tried cycling them about 6 times before high alpha landing it into the wind. Minimal scrape on wing tip.
garryk is offline Find More Posts by garryk
Old Today, 07:25 PM
Mach One
captain MoMo's Avatar
Joined Apr 2011
Very nice indeed. You know I also have my Mig 29 finished and ready to rock and roll So, I am not discriminating against the J-10 LOL
What are the throws on your Mig 29? Also, I have installed the FW 12B CR EDFs on my SU 35 and they are awesome. Although a bit of an amp hog but I love them. What mah battery do you use and how long do you fly your Mig?
captain MoMo is online now Find More Posts by captain MoMo
Old Today, 07:57 PM
Antaeus's Avatar
Joined Oct 2001
I will give you my CG and throws perhaps later today or tomorrow...I am pooped from being in the sun all morning.
I am using 2 separate 6s 2600mAH 40C. Each pack supplies dedicated electrons via 12AWG wires to one set of ESC+MOTOR. The batteries ARE NOT paralleled together. I don't like to heat up the connectors, wires, battery and electronics running 100 to 140amp through a single 10AWG wire.
3.5 to 4 minutes flight duration depending on flying mood. I am sure if I fly at half throttle all the time, it would exceed 7 min. I am just surprised at 50% throttle setting, it draws only 40% of its max amp draw.
Old Today, 08:00 PM
Antaeus's Avatar
Joined Oct 2001
GarryK,
I've tried adding washers, rubber rings, zip-ties, fishing line knots, etc. to cushion to jam between at the endpoints. Anything helps. Although you still get a stuck gear once in a blue moon.
Discussion Flyfly mig 29 OVT ak MIG 35 amigob Electric Ducted Fan Jet Talk 11 Oct 28, 2010 12:22 PM
Sold HET-RC Mig 29 Twin Fans Grey 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Dec 07, 2009 10:15 PM
For Sale Mig-29 twin fan (including 2 X Het 6904mm fans 3DTRYER Aircraft - Electric - Jets (FS/W) 0 Jun 17, 2009 04:58 PM
Discussion new mig-29 twin fans to be out soon gazza2003au Foamy EDFs 11 Feb 24, 2009 05:08 PM
Discussion HET Mig-29 Vs FlyFly Mig 29 skydve76 Electric Ducted Fan Jet Talk 2 Oct 06, 2008 12:32 PM
