Cutting Parts
So tedious setting up the tabs for all those parts. I think I spent well over 4 hours today just lining them up and arranging them onto the parts. Even after spending all that time, I found out the hard way, that I forgot to break the tabs off the cut lines. The laser cutter burned though the tabs anyway. I had to use masking tape to hold the parts in place so they didn't all fall out when I lifted them from the machine. Not a big deal with these first few parts, but I will have to fix that before I cut the rest of the ribs. Good enough for the first prototype.
Here's a short video of the new laser cutter burning through a sheet of 1/8" balsa:
I picked up a bunch of long narrow plastic bags from our local hobby shop. I think they will work in conjunction with a rubber band for the plans. I can use packaging plastic around the wood bundles too. Doesn't look like the shipping boxes will be an issue. I'll also take a look at what USPS has to offer as boxes for shipping. Free is a good price.
I should be able to get the prototype bird built, tested, design tweaked, and a 2nd kit cut by April. I just picked up some of what Janice (local hobby shop) had left. Was slim pickings, heavy, but will work for the prototype. I'm hoping to order a bunch of contest balsa from National Balsa for future kits, but I have to wait for a bit for funds to collect. My income seems to be lagging behind my outgo here lately. Materials needed for a short kit: 3 - 1/8"x4"x36" balsa sheet 5 - 1/16"x4"x36" balsa sheet 4 - 3/32"x4"x36" balsa sheet 1 - 1/4"x1/4"x36" square balsa stock 1 - 1/16"x6"x12" air ply sheet 1 - 1/8"x3"x36" lite ply or stiff C grain balsa (two 18" lengths) Electronics: 1 - 28mm Outrunner with a standard X mount (eg: 2826 with an APC 9x4.5e, 2830 with an APC 9x5e, or 2836 with an APC 9x6e prop) 1 - An appropriate 3s LiPo (1300, 1800, or 2200mah) 1 - An appropriate bushless ESC (18-25 amps) 1 - receiver 4 - mini servos (HXT900 or similar) Will need other materials like: Wheels, 3/32" music wire to bend landing gear from, Landing Gear Straps, pushrods, and linkages, etc... I'll generate a list as I build the prototype over this coming week. I cut the balsa sheets in half to make 18" planks so they fit in the laser cutter. Each plank takes on average about 3 minutes to cut. Some planks take as long as 6 minutes while others take only 30-45 seconds. Fred, when you get home and get a chance, take a look at what stock you have. I'll see what I have in my shop too. Would be a good thing to use contest grade balsa sheet so feel free to order some from National Balsa. Give me a call.
It is a considerable amount of work and quite tedious to build and texture the 3d model to render in exact scale to 2d plans. Through a bit of trial and error, I finally got the results I was looking for.
I'm not going to give an absolute step-by-step on how to render plans from 3ds max. If you don't use 3ds max then you can skip the rest of this post. Rendering Plans (greatly simplified):
