Old Jul 15, 2014, 06:20 AM
Joined May 2014
fpv help with wiring
I've brought a hobbyking fpv 5.8 but would like to use this camera but the wiring is different need help how can i use thi camera with the hobbing king transmitter
azza1985 is offline Find More Posts by azza1985
Old Jul 15, 2014, 06:47 AM
What place .... is this ???
Australia, SA, Adelaide
Joined Oct 2011
It might seem a dumb question, but why not use a Fatshark camera which would plug straight in, compatible with the power supply from the vtx as well?
Heppy Ket is offline Find More Posts by Heppy Ket
Old Jul 15, 2014, 07:06 AM
Philippines, Calabarzon, San Pedro
Joined Jul 2012
Not familiar with the camera. What voltage does it run on?
Hajile is online now Find More Posts by Hajile
Old Jul 15, 2014, 07:18 AM
Joined May 2014
The camera a 12v plus it's waterproof as it's going on a bait boat
Old Jul 15, 2014, 07:37 AM
Joined Jul 2012
I see, you need something waterproof, so the red plug on the camera goes to the battery. You can ignore that one, or replace it with a Deans plug or XT60, whatever your battery uses.
You'll need to splice the yellow video plug. Pretty straightforward really.
vTX
Red=5v lead (ignore this)
Black=Ground (Connect to the ground wire on the video plug)
Yellow=Video (Connect to the video wire on the video plug)
White=Left microphone (ignore this)
Blue=Right microphone (ignore this)
Or if you want, solder the Black and Yellow wires on the vTX to a male RCA plug and stick that into the camera jack.
If anyone thinks i'm wrong, let us know, i'm just going with experience from my 5.8 boscam.
BTW, product page for the RTX, the pin layout is on the sticker.
http://www.hobbyking.com/hobbyking/s...le_600mw_.html
Old Jul 15, 2014, 11:38 AM
TerryM
orectolobus's Avatar
United States, AR, Heber Springs
Joined Sep 2001
cut the RCA plug off. Strip back the yellow and ground leads.
Connect the yellow to the yellow wire on the Fatshark provided lead.
Connect the black/grn wire from the RCA plug to the the black Fatshark cable.
Splice a second connector to the Fatshark power plug. Add a connector to plug in the
battery and put a connector on the camera power wires (cut the red plug off).
The attached image does not show the black/grn lead from the camera going to the Fatshark
6-pin plug. You need the grn for the video. You are NOT using the red,black green and white wires on the
6-pin plug. leave them off and coil them up. They are there to supply 5v to a camera. Use a 12v battery pack like
a 3s-11.1 450mah pack to power camera and fatshark vtx
orectolobus is offline Find More Posts by orectolobus
Help! Help with F550 wiring/component internal layout Fatlab Multirotor Talk 0 Dec 21, 2013 03:30 PM
Question 7" FPV LCD Display help - connector wiring? ElGuano FPV Equipment 0 Nov 07, 2013 10:55 AM
Discussion Help with basic FPV setup (wiring) richardp05 FPV Talk 1 Feb 01, 2010 02:46 PM
Discussion Need help with Aiptek wiring harness for FPV & flight recording MinneFlyer FPV Talk 5 Oct 08, 2008 11:53 PM
