Old Mar 24, 2015, 03:13 PM
United States, NJ, Sparta Township
Joined Mar 2007
Prop Savers
What is the deal with prop savers. It looks like O rings dry out and break when on a plane for a couple months. Is there a fix for this or is this normal in dry conditions.Is there something better than the black O ring prop savers? Thanks Ron
darticus is online now Find More Posts by darticus
Old Mar 24, 2015, 04:12 PM
Build straight - Fly twisty
Whiskers's Avatar
Australia, QLD, Little Mountain
Joined Feb 2010
Silicone rubber is the material to use. Do a search for silicone rubber rings.
They are used for many things, from jewelry making to castrating animals.
But with anything you choose do not wait "a couple months" to replace them.
As a mission critical part they need frequent inspection and replacemant.
Whiskers is online now Find More Posts by Whiskers
Old Mar 24, 2015, 05:04 PM
Joined Mar 2007
Thanks very much. Ron
Old Mar 24, 2015, 08:45 PM
SlingWinger
San Bernardino, California, United States
Buy silicone tubing and slice off whatever width ya want.
dayhead is offline Find More Posts by dayhead
Old Mar 24, 2015, 09:19 PM
Kimbers Keeper.
Joined Nov 2014
I take the orings off and store them in a baggie in a dark place.
BHOFM is online now Find More Posts by BHOFM
Old Mar 24, 2015, 10:32 PM
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
Here's a source for metric silicone o-rings:
http://www.oringsandmore.com/metric-silicone-orings/
They are specified by inside diameter and cross section thickness. Silicone does hold up very well.
whitecrest is offline Find More Posts by whitecrest
Old Mar 25, 2015, 04:11 AM
Remote island inhabitant
epilot's Avatar
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
I use ordinary cheap rubber bands and change them frequently.
epilot is online now Find More Posts by epilot
Old Mar 25, 2015, 06:50 AM
Joined Mar 2007
Thanks all! Did any of you try sling shot gum rubber, a cross section of the rubber tube? Ron
Old Mar 25, 2015, 07:25 AM
Canadian Bacon
flypaper 2's Avatar
Kingston, Canada
Joined Jun 2004
Best stuff I found is Theraband silicon rubber tubing you can get at any of the health/ medical supplies stores, used for exercising. Comes in different colours for different strengths. I found the blue the best for our purposes. Can be cut to different lengths for different motor sizes. Knife and scissors work to cut it. Indoor planes and such, I cut about 1/16 thick. Bigger planes are about 1/8 to 3/16 thick. I use a pair of bent nose needle nose pliers to install. You can see it here on the Deltaray.
Gord.
flypaper 2 is online now Find More Posts by flypaper 2
Old Mar 25, 2015, 07:43 AM
Joined Mar 2007
Gord.
Will try to search this out. Cool! Ron
Old Mar 25, 2015, 08:53 AM
AKA Don
bz1mcr's Avatar
United States, MI, Houghton Lake
Joined Dec 2002
Yes sling shot rubber is normally silicon tubing and about the right size. It is often easy to find at Walmart and sporting goods stores.
I have seen silicon tubing at Home Depot, Lowes, and local hardware shops.
The best way to cut "slices" off silicon tubing is to use a Toe nail clipper for a large dog. They are available at pet supply shops.
bz1mcr is online now Find More Posts by bz1mcr
Old Mar 25, 2015, 06:51 PM
HookedonJonics's Avatar
United States, CA, Covina
Joined Jan 2014
I normally will get a 700c bicycle inner tube and just cut it in half. I can get almost a life time supply of prop saver bands for 2.50
HookedonJonics is offline Find More Posts by HookedonJonics
For Sale 4 X PROP SAVERS for 1.5 or 2.0 mm Shafts & Props w/4mm Hole scharlach Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Dec 09, 2014 07:56 PM
Discussion Prop Saver or Not Prop Saver ? jabetha FPV Talk 4 May 21, 2009 09:26 AM
Prop Saver 0 Ring Sizes, Prop Saver idea link dougmontgomery Foamies (Kits) 6 Mar 24, 2005 08:27 PM
NEW prop saver!!! $1 for countless prop saver xoon Parkflyers 13 Jan 18, 2005 11:19 PM
FS: Many prop adapters,Hobby-Lobby alum prop savers, GWS prop saver,QRP 36mm spinner kyril Aircraft - Electric - Airplanes (FS/W) 7 Jun 03, 2004 02:28 PM
