Old Mar 13, 2015, 07:28 PM
Redjack is offline
Find More Posts by Redjack
United States, AL, Andalusia
Joined Feb 2014
Question
When is a plane in perfect balance?
When is a plane is perfect balance? Is it when the horizontal stab is level?
Redjack is offline Find More Posts by Redjack
Old Mar 13, 2015, 09:51 PM
BMatthews is online now
Find More Posts by BMatthews
B for Bruce
BMatthews's Avatar
The 'Wack, BC, Canada
Joined Oct 2002
When the wing sits level. The tail should be slightly negative at that point.
Actually when it's that close it's close enough either way. There's a range of acceptable positioning where at the forward extent the model will behave like an overly stable trainer. As you shift it to the rear over about a 8 to 12% chord range it becomes less and less pitch stable in that it takes longer and more altitude to recover hands off from a dive. When it's at neutral stability it won't recover at all with no input. This rearward extreme is where a lot of fun fly models and serious sport fliers set their balance point locations.
When you get down to the ragged edge you work with in flight testing for feel and results. We only balance on our fingers or other points to get to where it's safe enough to fly the first flights.
BMatthews is online now Find More Posts by BMatthews
Old Mar 14, 2015, 08:39 AM
Marion is offline
Find More Posts by Marion
Marion
USA, NC, Hillsborough
Joined Oct 2003
When the plane flys reasonably level, and you roll inverted -- and it then needs no (or very little elevator) for level flight. That's my personal criteria.
Marion is offline Find More Posts by Marion
Old Mar 14, 2015, 08:55 AM
eflightray is offline
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
But, it can also depend on the plane and the flier.
From a CG point of view, when a plane flies how I want it to, that to me is near enough.
If you gave the exact same model to two different fliers, and told them the CG was out and they needed to correct it. You could easily end up with two different CG locations.
It comes down to personal 'feel'.
The CG dimension specified on a plan or in the instructions, should be a safe starting point, and is where it should be for the first flight.
It's then up to the flier to decide if they want to move it.
Where the elevator is in relation to the horizontal stab, is not really to do with 'balance', but is generally a good place to start.
Though for a first flight many might recommend a couple of clicks of up elevator before launch.
eflightray is offline Find More Posts by eflightray
Old Mar 14, 2015, 09:19 AM
LesUyeda is offline
Find More Posts by LesUyeda
LesUyeda's Avatar
San Diego, California
Joined Dec 2004
"When is a plane is perfect balance? Is it when the horizontal stab is level?"
An airplane is no more than an arrow. It will fly in the direction of the tail feathers. If those tail feathers are other that in the direction of desired flight, you will have to force the aircraft to fly in the attitude you want it to, by some method, or other.
Les
LesUyeda is offline Find More Posts by LesUyeda
Old Mar 14, 2015, 10:57 AM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
This is the sort of balance point for a serious aerobatic model being flown by an advanced pilot.
A trainer or advanced trainer would be set so it needs some amount more down to hold it inverted so that it's more positively stable when upright.
Of course a newer pilot is likely not doing that much inverted flying anyway so this technique isn't likely one they would think of to use. But it does illustrate how the model behaves as we move the CG back towards the neutral stability point.
Old Mar 14, 2015, 10:59 AM
portablevcb is offline
Find More Posts by portablevcb
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
If talking about static measurement, then I just make sure the fuse centerline is slightly nose down. Yes, it may be wrong compared to the aerodynamic center, but, it has worked for me.
When flying I verify the CG with a dive test.
portablevcb is offline Find More Posts by portablevcb
Old Mar 14, 2015, 12:42 PM
slipstick is offline
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
Agreed. The CG is correct when the plane flies as you like it to fly.
NOTE: the CG marked on the plans/in the manual is no more than a hint. Usually just a reasonably safe starting point.
Steve
slipstick is offline Find More Posts by slipstick
Old Mar 14, 2015, 01:22 PM
whiskykid is online now
Find More Posts by whiskykid
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
assuming that all things are strait and square!
then put the plane in a 45 degree climb, the roll inverted, and the plane should continue on the same line!
that is the simple way too tell, there is books written on how too properly balance an airplane, which usually needs too be done, on a very calm day!
the plane also needs too be balanced laterally, (side too side)!
I turn the plane upside down, rest it on the rudder, then hold on too the nose cone, with the engine free wheeling! and make sure the plane doesn't fall too the same side every time I let go of the wings!
once you get it statically balanced, then you perform the flying part of it! ( refer too first option) 45 degree inverted roll!
unless your flying in competition, that will get you into a happy place with your balance!
whiskykid is online now Find More Posts by whiskykid
Old Mar 14, 2015, 04:07 PM
B for Bruce
BMatthews's Avatar
Joined Oct 2002
Here again this is a technique for setting the balance and associated elevator trim right on or darn close to the neutral stability point. For a pattern or serious fun flying aerobatic model it's perfect.
But it isn't right and it won't work for trimming a trainer or advanced trainer where we WANT some positive stability for the new or lower time pilot.
Old Mar 14, 2015, 08:11 PM
Neophyte hacker
Albuquerque, NM USA
Joined Sep 2003
For non-aerobatic stuff:
Trim the plane for straight and level 'hands off' flight. Without touching the throttle use the elevator to put the plane in a 45deg dive (doesn't have to be exact, just enough to get the plane to speed up). Then let go the elevator stick. If the plane rises out of the dive it is forward balance. If it continues on the down line it is neutral. If it tucks and dives steeper the CG is to the rear of neutral.
FWIW, if the CG is too far back you'll know it without this test
The idea is you can do slight adjustments to get a more neutral controls....if you want. I've rarely felt the need to get close to neutral. I have had a few planes that I have moved the CG aft of the plans, usually due to things like swept wings or highly staggered biplanes.
charlie
Old Mar 14, 2015, 09:46 PM
Fly Wheel is online now
Find More Posts by Fly Wheel
Ochroma Pyramidale Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
Question: wouldn't the angle between the main wing and the horizontal stabilizer (Decalage?) make a difference in this formula?
Fly Wheel is online now Find More Posts by Fly Wheel
Old Mar 15, 2015, 02:35 AM
bogbeagle is offline
Find More Posts by bogbeagle
Joined Mar 2007
I'm always mystified when it's claimed that an aeroplane can fly "exactly the same", whether it's erect or inverted, whilst maintaining the same trim settings.
It doesn't quite make sense, in my head.
Will someone explain to me, how that works?
bogbeagle is offline Find More Posts by bogbeagle
Old Mar 15, 2015, 03:47 AM
Staffs, UK
Joined Nov 2003
Why not ? If it has zero camber airfoils with the thrust line, wing and tail all on the same datum line. How's it gonna know which way up you think it is ?
OTOH most aircraft can't do that because they don't meet most of those conditions.
Steve
Old Mar 15, 2015, 06:39 AM
AA5BY is online now
Find More Posts by AA5BY
AA5BY's Avatar
East Texas
Joined Aug 2007
I don't get it either... gravity is a flight trim factor. With a perfectly symmetrical plane, upright flight needs a slight bit of up trim to counter gravity. When inverted, it would need a slight bit of down trim to factor for gravity.
In my head, I'm seeing these two trims adding to each other for a variation that does not provide the same trim for upright and inverted.
The only way that I can manage to get my head around equality of upright/inverted flight, is for trim adjustment between the two. This could be automatic however... such as a sensor like is used in an IPhone that trims out the variation.
AA5BY is online now Find More Posts by AA5BY
Discussion How to charge and balance a LiFe in the plane Diggendirt Batteries and Chargers 19 Jan 10, 2015 12:10 PM
Question when in thermal mode the planes goes down VirTus Sailplane Talk 20 Mar 20, 2014 09:30 AM
Help! Low Voltage warning in iCharger 306B when plugging in balance port, please help jasper7821 Batteries and Chargers 15 May 04, 2012 11:57 AM
Help! Shoud my TP 4600 be perfectly balanced when discharged? imxz28 Batteries and Chargers 10 Feb 25, 2008 01:26 PM
How to fit 9 FAUP cells in Banana and balance perfect Fishstyx High Performance 15 May 30, 2004 01:59 PM
