Old Oct 23, 2014, 05:38 PM
erikfj's Avatar
Germany, BW, Bietigheim-Bissingen
Joined Sep 2012
Question
DLG High Performance
Hi everyone!
My name is Erik, I'm an aerospace engineering freshman at the University of applied sciences in Stuttgart. I have been learning how to work with all kind of composites in this past few weeks and i have a passion for DLG flying.
I was wondering if anyone has build plans for a high performance 1.5m DLG. My idea was to experiment with the use of some new materials we get from sponsors for the build gliders. More specifically the use of honeycomb sandwiches with ROHACELL and Texalium.
Thank you in advance for your help!
Greets from Germany
erikfj is offline Find More Posts by erikfj
Old Oct 23, 2014, 06:06 PM
No slope for richardo
Endless Sloper's Avatar
Seattle, WA
Joined Jun 2005
We'll share, only if you post your progress and findings here
Endless Sloper is offline Find More Posts by Endless Sloper
Old Oct 23, 2014, 06:14 PM
Seattle, WA
Joined Jun 2005
Start w/ the wings here:
http://www.rcgroups.com/forums/showthread.php?t=2152557
http://www.rcgroups.com/forums/showt...2#post20322883
http://www.rcgroups.com/forums/showthread.php?t=1348570
Someone can point you to the Zone V2 Tails as well (Maybe Gerald (G_T)?)
For the fuse, there are several ways to go, just depends on preference and needs, I'll let others that have created fuses step in here.
Old Oct 24, 2014, 03:03 AM
Österreich, Oberösterreich, Linz
Joined Nov 2002
Originally Posted by erikfj View Post
Hi everyone!
Have a look for RCN09 at the german "RC-Network" forum....
wstark is offline Find More Posts by wstark
Old Oct 24, 2014, 07:42 AM
Kyle Clayton
Wave Glider's Avatar
United States, VA, Dinwiddie
Joined Feb 2008
Welocme! Not that I am a builder but I did once ponder the use of texallium. It is a fantastic looking fabric but I was told on here there may be some issues with it and radio interference problems as the aluminum in it makes it conductive. I don't really know as I never tried it, but it would be fantastic if someone could use it. It would make an awesome looking plane.
Wave Glider is offline Find More Posts by Wave Glider
Latest blog entry: Helios and XXLite DLG
Old Oct 24, 2014, 12:11 PM
Meek A Mouse
Deutschland, BW, Stuttgart
Joined Aug 2004
Hi Erik,
I highly recommend to visit the AkaModell guys at first. Rumor has it that they 're gonna mill a wing plug for a Zone V2 wing the next few weeks.
Seems like you mixed up Texalium with TeXtreme, which is a brand name for spread tow fabric made by Oxeon of Sweden.
Cheers,
Stefan
gideon is offline Find More Posts by gideon
Old Oct 24, 2014, 02:27 PM
United States, CA, Mission Viejo
Joined Jan 2005
Hi Eric Welcome to RC Groups
As a matter of fact I have been in the process of milling a Nomex Honeycomb Core for a wing. I am starting with the tail and going to see how that works. I haven't spent any time with the hobby for some time but am trying to get back at it. Made a few test pieces and they look promising.
Air Head is online now Find More Posts by Air Head
Old Oct 24, 2014, 02:49 PM
Seattle, WA
Joined Jun 2005
Very cool AH, any preliminary data on weights for the tails?
Old Oct 25, 2014, 12:47 AM
eitanro's Avatar
Tel Aviv-Yafo Ben Gurion, Israel
Joined Sep 2004
Welcome to RCG Eric!
If you need a stiff and lite fuselage, you can find one here: http://www.rcgroups.com/forums/showthread.php?t=2028571
Eitan.
eitanro is offline Find More Posts by eitanro
Old Oct 25, 2014, 02:45 PM
Joined Jan 2005
"Very cool AH, any preliminary data on weights for the tails?"
Id like to take at least 20% out, perhaps more.
If someone has some old tail molds they don't use that I could play with to make some test samples and see if it works out id like to get hold of some to play with. This stuff is tough to work with and it takes quite a bit of time so I don't think it would be a marketable item - but for all out performance I think its a leap ahead of foam for a core considering the compressive strength is about double or more. That means the skins can be lighter if I'm thinking this through. I built a test piece some time ago, im at work and when I get home ill try to put up a photo.
Old Oct 25, 2014, 09:44 PM
elkski's Avatar
United States, UT, Sandy
Joined May 2013
ANY PICS OF THIS HONEYCOMB ROHACELL?
THe compressive strength is double in what axis?
I am lost?
Does rohacell come in a honeycomb or is this a machining?
elkski is online now Find More Posts by elkski
Old Oct 26, 2014, 06:07 PM
Joined Jan 2005
Here you go. Google up Nomex honeycomb and you can see what it is. No Rohacell is not Honeycomb. They are both core materials, Roacell is a foam, core materials all work the same way in composite construction
Found I want one too! Any high performance DLG. eteet Aircraft - Sailplanes (FS/W) 2 Jun 19, 2007 03:23 PM
Question Looking for used high performance DLG Rogo Hand Launch 5 Nov 23, 2006 11:35 PM
Wanted High performance DLG / HLG JayGarcia Aircraft - Sailplanes (FS/W) 3 Sep 07, 2006 09:25 PM
New High Performance CNC molded DLG RobertTHaas Hand Launch 3 Dec 23, 2004 01:42 PM
FS: High-performance DLGs - new kyril Aircraft - Sailplanes (FS/W) 3 Oct 16, 2003 12:56 PM
