View Poll Results: What’s the most important thing to you?
Lowest possible cost 3 23.08%
Make it as small and light as possible 6 46.15%
Battery longevity is very important 3 23.08%
Highest power possible 3 23.08%
Highest RPM possible 2 15.38%
Only use through hole construction 2 15.38%
No winding of transformers 4 30.77%
Group buy of components including boards 0 0%
Group buy of boards only 1 7.69%
I’d rather buy a kit with everything in it 0 0%
I want to buy a pre-built & pre-programmed system 0 0%
I only want to use a 4.8v Ni-MH battery 2 15.38%
I only want to use a 2S battery 1 7.69%
I only want to use a 3S battery 1 7.69%
I want to use a 4.8v battery to 3S battery 5 38.46%
I want to use only off the shelf parts from Digi-Key or Mouser 3 23.08%
I want the Timer board to be separate from the HV board 6 46.15%
I want a combination Timer & HV board 1 7.69%
I want all the options possible using jumpers 3 23.08%
I want a USB connection 2 15.38%
I want a serial connection (DB9) and I’ll use my own USB adapter 3 23.08%
I want a ICSP connection 3 23.08%
I want a premade parts list (BOM) at Digi-Key 2 15.38%
I want a premade project parts list (BOM) at Mouser 1 7.69%
I want 1 design and 1 design only 1 7.69%
I want optional designs to choose from and Ill make the boards myself 8 61.54%
Multiple Choice Poll. Voters: 13. You may not vote on this poll
Old Dec 09, 2014, 05:28 PM
Joined Jul 2014
Originally Posted by andso View Post
i have in echo the HIFI (we are in the sound frequencies), where the solution is not where we were expecting it.
If you have a load (a bad load) and a low consumption first stage, the best way is to charge via a diode a sufficient capacitor supplying this frugal first stage: even if the main supply is disturbing, no care.
Ah hah! Finally something that I understand! I take it that you would put a scope on the circuit, to determine the offending frequency(ies). And, then, pick the diode and capacitor to bleed off that frequency. Or, would you just use components that would handle such a broad spectrum that you would be sure to catch the bad frequency(ies), anyway?
I like your out-of-the-box thinking regarding using a battery as a capacitor.
Andso, thank you for all that you are contributing to the project. You are, obviously, very skilled!
Tee One Dee is offline Find More Posts by Tee One Dee
Old Dec 09, 2014, 11:43 PM
Joined Dec 2012
Have to ask, is there a course running somewhere for broken English ?
I blowed if I can follow a thing he says.
bluejets is offline Find More Posts by bluejets
Old Dec 10, 2014, 12:51 AM
Joined Jul 2014
Oh, no... I meant that the electronic design conversation is so far over my head that I was glad to read something that I might know a little about... I'm sure that he has to work at understanding us, just as much. What an amazing time we live in... Turn on an electric box and collaborate with a new friend on the other side of the world.
Yes, I know I used three emoticons... Just for fun...
Old Dec 13, 2014, 04:21 PM
frenchy
France, Pays de la Loire, Chalonnes-sur-Loire
Joined May 2013
Tx/Rx disabling
And that is now i need collaboration for validate:
The idea is to disconnect the Tx/Rx lines when Vdd is ON on the ICSP --> DONE
and after the MCLR/Vpp line go On enter in pgm mode. But i have add
a manuel switch for the annoying non-functionning cases.
In the next weeks i'll check this.
note:
V1/4 part of 74HC4066 invert the Vdd On issued of the ICSP to have a low input to 74HC4066
and disconnect the Tx/Rx lines
My schema is not compliant with the actual software. I have had a look, but if you agree, that is for you: i am learning python and QT to give a front-end (in french: c' est pas gagné).
And, again if you agree, i have to design the boards
@jakestew
as i am still discovering the great work done, on my open-source system (except eagle...) :
in your script you mention
FilePath = "C:\stim\RPM_value.txt"
FilePath = "C:\stim\key_value.txt"
and in your "CDI 1840 simulation ReadMe.txt" you say:
Create directory C:\stim and copy the two text files into the directory
but you do not furnished them, and the path is good only in window environnement!
Because i am curious, on your page http://unimatrixtech.com/2_stroke_engine_tech.htm
all the links give a 404 error...
@bluejets
i do what i can (verifying often with a dictionnary)!
try to write what you said in french: this will be funny for me!
And correct me on my technical work...(schematics)
@ anhalt
I have take in your considerations, and the remarks on the links you have posted.
Correct me if forget something.
@Tee One Dee
It is possible for you to play eagle with the new actual non functional board.
andso is offline Find More Posts by andso
Old Dec 15, 2014, 03:01 AM
United States, ID
Joined Sep 2011
Pete (doubletop) did all the work on the simulator. The files should be in one of his posts in this thread.
Ray mirrored some stuff there. All the v2/OTF/servo stuff is just scattered in this thread. Info on the v1.0 setup can be found here...
electrofunnel.com/CDI-2012
jakestew is online now Find More Posts by jakestew
Old Dec 16, 2014, 03:34 AM
frenchy
Joined May 2013
just to mention that it starts good with LibreOffice in a linux environnement
Old Yesterday, 02:49 PM
Joined Dec 2014
Just FYI: Silicon Chip has an update to their CDI from 1997 in the December 2014 issue. Probably too bir to fit on a model airplane, but should work fine on a motorbike or car.
kipphebel3 is offline Find More Posts by kipphebel3
Discussion CD Ignition lead and fixed plug .... solentlife Engines 10 Feb 18, 2014 12:03 PM
For Sale NIB 52cc Gas engine w/CD-Ignition 3.2kw kukntra Aircraft - Fuel - Engines and Accessories (FS/W) 4 Jul 23, 2012 09:10 AM
Discussion Best open source autopilot vs commercial solution syncra Multirotor Talk 0 Apr 12, 2012 02:35 PM
Discussion Any Open Source / CC CAD Files for gliders? DrFragnasty Composites Fabrication 8 Apr 09, 2012 06:36 AM
Discussion I'm designing an open source quad frame. Inclusions anyone? Physics_Dude Multirotor Talk 3 Mar 11, 2012 01:22 PM
