United States, OH, Bradford
Joined Jun 2005
Now, regarding spar design:
First of all, the key parameter is the bending moment at each location along the span. If you know the bending moment at a given point, and the depth of the wing spar at that point, you can calculate the tensile and compressive stresses in the lower and upper spar caps at that point. Then the sum of the moment forces made by the spar caps has to equal the bending moment imposed on the spar.
For each spar cap's moment force, take the distance from the middle of that spar cap to the "neutral axis" times the tensile (lower cap) or compressive (upper cap) force in the spar cap. Divide the force by the cross-sectional area of the cap and you have the stress in the spar cap, which you can compare to the compressive or tensile strength of the spar cap material (minus an appropriate factor of safety).
When you bend a beam (such as a wing spar) some portions get stretched (the tensile side, for positive "G" the lower side) and some get squished (the compressive side, the upper cap for positive G). That means that there is some point in the thickness in between the two where the tensile and compressive stresses are exactly zero. That location is the neutral axis. The distance between the neutral axis and any given location in the spar cross-section tells us how much leverage the material in that location has, and how much deflection it sees (and therefore the amount of strain in the material) when the spar is under a bending moment.
If the upper and lower caps are identical (same shape, cross-sectional areas and material), then the neutral axis is halfway between them.
If you stiffen only one spar cap (beef it up, or add a doubler or some carbon to it), then the increased stiffness in that cap pulls the neutral axis closer to it. For a given applied bending moment in the spar at that location, this reduces the leverage of that spar cap, and increases the leverage of the other spar cap. The reinforced spar cap sees a benefit because of the extra strength, but not as much as you might expect, because of the loss of some leverage. The corresponding increase in leverage on the other side helps make life easier for the opposite spar cap. This is what happens when you add carbon to only one spar cap. It's generally more effective to add carbon to both spar caps, keeping the leverage betweeen them roughly where it was.
That said, on planes that see max loads mainly from the positive-G direction (such as winch or Hi-start launched sailplanes), you generally need more beef in the upper spar caps. This is because the compressive strength of most materials is less than the tensile strength, even without considering buckling failures. The difference is fairly pronounced in wood (as much as about 2:1 in many cases), but (contrary to popular belief), significant but not that great in materials like carbon or steel.
The big exception is Kevlar. The tensile strength of Kevlar is fantastic, actually higher than typical varieties of carbon, but its compressive strength is truly pathetic, less than half that of garden-variety hardware store E-glass. Rumor has it that the aramid molecule itself has a kink in it, and the low compressive strength is the result of buckling at the molecular level. In any case, the compressive strength is truly awful, to the point that unless the part involved does not see any significant compressive load (such as blades for most full-scale propellers, which see mostly tension from centrifugal forces), you're usually better off choosing some other material.
Oddly enough (and supporting the molecular buckling theory), the tensile strength of Kevlar after it's been failed in compression is nearly as great as it was before the failure. What typically happens in a compressive failure is the fibers lose their load-carrying ability, dumping the load onto the matrix material (epoxy/polyester/whatever), which then crumbles away, leaving a loose "rope" of nearly undamaged Kevlar fibers. Successive loading and unloading of the loose fibers rubs them against each other to the point that they eventually saw through themselves, but at least initially the broken pieces at least stay connected to each other.
So far we've been talking about compressive failure, pure crushing failure like what happens when you squash a ball of clay between your palms. Buckling is a different type of compressive failure entirely. Buckling typically happens at far less than the pure compressive strength of the material, unless the structure includes enough support along the length of the piece to prevent it. When you crush a soft-drink can, it fails in buckling, suddenly, catastrophically, and at far less than the pure compressive strength of the material.
If your spar failed in buckling, it means that your design did not take advantage of the entire compressive strength available from the material.
Buckling is a function of the stiffness of the material, not the material's strength. That's right, if you made a part out of the strongest heat-treated tool steel, and that same part out of the softest, cheapest, low-carbon coat-hanger-wire steel, both would fail in buckling at the same load, because they have almost exactly the same stiffness, despite their huge difference in tensile and compressive strength.
Buckling prevention is one of the two functions of the shear web in a typical spar. This is also why we typically orient the grain of the shear web material vertically, to maximize the support for the compressively-loaded spar cap. If the part is supported along its length enough to prevent it from flexing off to one side, it will prevent it from buckling.
The other function of a shear web is to connect the upper and lower spar caps together. One of those is in tension, the other is in compression, so something has to connect them together so one has something to pull on, and the other has something to push on. Without a means of communication between the two of them, their entire structural relationship would quite literally fall apart. In addition, the wing is making lift, an upward force. The loads in the spar caps are spanwise. They're handling the tension and compression caused by bending moments resulting from those upward lift forces times the moment arm created by the span, not the lift itself. The vertical lift force has to be collected along the span and transferred to the fuselage. This is done by the vertical components of the shear loads acting in the shear web.
One other load in the shear web comes into play at dihedral joints. The spar caps coming into the joint from both sides are at an angle to each other. Because of this, the compression/tension forces in them do not exactly cancel, they each have a vertical component that shows up as a vertical compression or tension force in the shear web itself.
I heard the tragic story once of a new airliner design back around the WW II era, where the engineer designing the shear web for the wing spar forgot to take this load at the dihedral joint into account. Somehow this didn't get spotted in certification tests, and later resulted in the loss of an aircraft, along with a number of fatalities. According to the story, when the engineer learned of his error and its result, he couldn't live with himself. Utterly despondent with his feelings of guilt, he increased the number of fatalities related to the accident by one.
Generally the loads in the shear web are not as difficult to deal with as the loads in the spar caps. If the shear web is beefy and stiff enough to properly support the compressively-loaded spar cap, it's generally also strong enough to handle the shear loads imposed on it. However, it is possible (especially with the extensive use of carbon in spar caps these days) to have spar caps that are overstrong, and a shear web that isn't. Ideally, each of these components should be just the right size to do its job, plus the necessary safety factors. Anything less than that invites catastrophy, but anything more than that adds unnecessary weight, which also invites catastrophy.
