Old May 18, 2015, 09:50 PM
Bmurry226 is offline
Find More Posts by Bmurry226
Joined Apr 2015
Parkmaster 3d weight
Finally finished my Parkmaster 3d as my first electric foamie. It came in at about 18.906oz (536g). That seems a little on the heavy side. Is it going to be a problem? I'm using the headsup hobby recommended setup.
Bmurry226 is offline Find More Posts by Bmurry226
Old May 19, 2015, 07:00 AM
Wingin' Wayne is offline
Find More Posts by Wingin' Wayne
I like the violent stuff!
Costa Mesa, CA
You will be fine on the weight. Numbers you see on websites are optimistic. Of course it could be lighter with different components. I've had 5 and all near 19 ounces. Happy landings!
Wingin' Wayne is offline Find More Posts by Wingin' Wayne
Old May 19, 2015, 07:14 AM
Joined Apr 2015
Thanks! How do you hold your esc and receiver in?
Old May 20, 2015, 06:53 AM
Costa Mesa, CA
Velcro to the side.
Old May 21, 2015, 08:32 AM
BHOFM is offline
Find More Posts by BHOFM
Kimbers Keeper.
Joined Nov 2014
At that weight it will never fly, send it to me for proper disposal. I know with all that weight
the shipping will be terrible, but I am willing to pay it to protect the environment.
BHOFM is offline Find More Posts by BHOFM
Old May 21, 2015, 06:00 PM
Joined Apr 2015
Not worth the trouble. I'll just trash it and start over . I'll let you know if I ever get it off the ground. I'm still messing with the controller settings and decals. Had to take a break to fix my lawnmower
Old May 21, 2015, 06:09 PM
Xpress.. is offline
Find More Posts by Xpress..
Hitec RCD CSR
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
Typically the PM comes in somewhere around 20oz, so at that weight you're going to do stellar!
Xpress.. is offline Find More Posts by Xpress..
Old May 22, 2015, 06:46 AM
Costa Mesa, CA
At 230 watts per pound, mine ALWAYS get off the ground. My double snap-roll on takeoff is really ballistic! Wouldn't it be a real DRAG if we were all the same?
Old May 22, 2015, 01:17 PM
Joined Apr 2015
I ran mine with the 10x4.7 and 11.x.5.5 prop. The 10x4.7 came in at 201.4 watts and the 11x5.5 came in at 200.6 watts. Both were right around 17amps but the 11x5.5 was a little under the 10x4.7. All tests were at full throttle. Which would be best to use?
Old May 22, 2015, 02:16 PM
BHOFM is offline
Kimbers Keeper.
Joined Nov 2014
I would run the ten inch. More power than you will ever need and the ten will respond a bit
quicker. I have the 11X5.5 and never tried anything else.
Old May 23, 2015, 07:50 AM
Costa Mesa, CA
Slo-fly and E props look different and perform different. Use the one that suits your style. Why not give them both a try ? I use the meter and narrow my choices down and then test drive them at the field. Meter is a handy tool, for me performance is the last answer.
Old May 23, 2015, 09:33 AM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
I used a 10 x 4.7 slow flyer prop on my Parkmaster for 3d flying. The 11 x 5.5 apc will likely give you a little more speed and punch out from a hover but the 10 x 4.7 performed nicely with this plane.
The Parkmaster could actually perform a knife edge square loop. The guys at the field thought that maneuver was pretty cool.
KE Spin is offline Find More Posts by KE Spin
Old May 23, 2015, 12:11 PM
dankar04 is online now
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
I don't have one yet but its on my G/P sim. I'm well aware its not same s real life, but it works fine on sim. there are others and like this one the best.
dankar04 is online now Find More Posts by dankar04
Old May 25, 2015, 04:41 PM
Joined Apr 2015
I was kind of hoping the sim was simliar to the real version. Is this not true?
Old May 25, 2015, 05:12 PM
KE Spin is offline
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
I found that the actual plane flies better than the sim version. It flies decent in the sim but I felt it was a little more stable and capable in the real world.
Discussion Parkmaster 3d hinge gap HELP! Bmurry226 Foamies (Kits) 1 May 10, 2015 04:02 PM
Discussion Parkmaster 3d setup Bmurry226 3D Foamies 46 Apr 29, 2015 07:12 AM
Sold Multiplex Parkmaster 3D ltrfred Aircraft - Electric - Airplanes (FS/W) 5 Jan 12, 2015 11:32 PM
