Has anyone ever put one of these together?
This is my first proper "balsa build", and I'm finding it quite a
'challenge'.
Not exactly the first word that springs to mind - but the thread would get closed down straight away if I said what I really think LoL
The Catalina isn't strictly the first thing I've made out of balsa - I'm finishing a fuze for a my quaint old Electro Streak that I happened to snap in half when I lost it in the sun. But that's a story for another day.
Back to the Easy Built...
Ho-li cow - what have I gotten myself into here
It's an interesting 'kit' - to say the least.
There's some sheets of balsa in there with wing rib/fuselage bulkead patterns printed on them. Some loose balsa sticks, blocks, sheets etc. of varying sizes. Some printed ply, a couple of hardwood spars, and other bits and bobs like hinges, control horns etc.
The printing on the printed sheets varies from quite neat and tidy to rather large smudgy areas - not real easy to guess which side of the line I should cut to, so I went 50/50 and cut in the middle of the line when it got a bit too fat.
Anyhoo... I started with the centre wing section, as per the 'manual'. I soon found out that had I cut everything on the far side of the printing, I would have been closer to the mark. Meh - so I had to go in and remove more to get things to fit all the way in. Better than having great big gaps everywhere, I 'spose.
Main section went together pretty well down onto the two hardwood spars, but when it came to laying the top two spars, I suddenly found myself scratching my head regarding
which bit of balsa to use
There's quite a few lengths of square and oblong balsa - all different sizes. Of course, none of those lengths have any identifying marks on them like the printed sections do - so now I find myself trying to work backwards from what I can figure out goes where, and what's left over.
Oh joy.
I'm concerned that I'll end up using the wrong size somewhere and not have any left for where it was supposed to be used. And that's only on the wings yet
It looks like 1/4x1/4" might be right for the front top spar of the main wing section, but the main rear top spar and both top spars on the left and right wing sections seem to take 1/4x3/16" a lot better - 1/4x1/4 leaves way too much wood standing above the contour of the wing ribs.
But...
If I use all the 1/4x3/16 I'm left with a lot of 1/4x1/4, which doesn't look like it wants to fit anywhere - including LE caps etc.
Aaaackkk...!
I suppose I can work on the theory of diminishing probability - build the wings as far as I can, then build the fuze as far as I can, and finally try to use what's left over by process of elimination.
More joy.
Another thing that has got me totally flummoxed is the left and right wing extensions according to plan. The centre section came up pretty good as far as alignment and square goes. But the extenstions are tapered. When I line the 1/4x1/4 bottom spars up with the plan, there isn't a snowballs chance in hell that the wing ribs are gonna sit across those spars - not according to the notches I cut as per the printing.
So I pinned the inside edges of the spars to where they are roughly meant to be, put the matching inside rib across them, and then put the outside rib where it is meant to be. This way, the ribs aren't trying to go sideways across the spars (which they refuse to do anyways - unless I cut the nothches obliquely).
That all kinda matches up ok now. BUT... the spar position at the wing tips is close to 4mm under where it is supposed to be on the plan.
I'm not sure if I'm doing this right
Considering the Electro Streak fuze was purely cut from plan and lined up to within 1mm, I'm sweating my freckle off here trying to build this Catalina.
Some things seem just so out of whack, I worried I'll end up making a boomerang...
BJ
