Old Jul 14, 2014, 08:33 AM
United States, NC, Wake Forest
Joined May 2014
LEDs controlled and hooked up to Rx
Is this the best option if I want my LEDs powered off of my Rx and also be able to turn them off with a switch on the Tx? I have an AR8000 and a DX8..This is going on my F450
http://www.horizonhobby.com/products...kit-EFLA600#t3
I have this one on order, but I don't think that you can control the on and off from the Tx? Can you?
http://www.readymaderc.com/store/ind...oducts_id=2864
jhabers is online now Find More Posts by jhabers
Old Jul 15, 2014, 06:33 AM
Ft Lauderdale
Number_6's Avatar
Joined Sep 2012
Hi,
The one you have ordered does work off
a spare receiver channel and needs no other
power source...but they are aircraft style and
not really expandable if you want to add on.
For more of a custom, large plane lighting...when
I want to really light up the sky...say with 5 meters
of 12 volt LED strip lights I use :
http://www.hobbyking.com/hobbyking/s...arehouse_.html
For these the receiver controls on/off and the red wires
just splice into the + wire from strip to your 12 volt, 3s battery source.
The ground wire for that LED strip, not shown, just goes from LED strip
to same 3s battery...to complete the circuit for that strip.
I have used up to 3 of these controlling different light strips in a plane.
It is custom work...not like the one you have on order.
If you like to do custom LEDs like me...you can use multiple switches
and multiple 3s (12 volt) batteries to power them...just need to have
them all connected to same ground.
I have DX8, DX9, and the new DX6 and all setup with these switches
on Aux or Gear channel, set up as a switch..see Spektrum manual.
Actually I also use rudder channel too...as a switch...on my flying wings
that are setup as elevons.
Hope some of this helps.
Oh, I should add do not connect the one you have ordered to 12 volt!
It runs on lower receiver voltage!
Number_6 is online now Find More Posts by Number_6
Discussion hooking up a orange rx with flight stabilization to a wing Cavi Electric Plane Talk 7 Feb 18, 2014 02:54 PM
Discussion Electronics Hook-up for Specialized Stability Control GForce6point0 Electric Plane Talk 7 Feb 09, 2014 08:27 PM
Alert hooking up old computer power and loading LEDs to hummingbird? hingus2000 Micro Helis 44 Aug 06, 2004 01:22 PM
Anyone know how to Hook up LED's to the reciever? Summer Foamies (Kits) 10 Dec 18, 2003 12:52 PM
Hooking up a LED system POST PICS gassyanimal Parkflyers 10 Dec 11, 2001 10:28 PM
