Old Jul 16, 2014, 09:29 AM
United States, AZ, Cave Creek
Joined Aug 2011
Originally Posted by groovejet View Post
Don't worry; just use polyurethane glue as shown in the thread I linked to in my previous post. You'll need to modify the wire gear wood pieces a bit to make them fit the Slick, so do a dry test-fit before coating in glue. Also, face the wire forward, which is opposite to that shown in the photos on that thread.
Cool thanks I will take a look
CC268 is offline Find More Posts by CC268
Old Jul 16, 2014, 12:12 PM
Joined Aug 2011
Check out this thread for more info: http://www.rcgroups.com/forums/showthread.php?t=1678035
Hey so if I do the landing gear mod using glue I am guessing there is no getting it out to use CF landing gear down the road? Not that I really care just curious
Also is gorilla glue considered polyurethane glue?
Old Jul 16, 2014, 12:46 PM
akabek's Avatar
Canada, ON, Toronto
Joined Jan 2013
I also use wire landing gear on my Skywing/Wattaplane planes. Gorilla glue is what I use when I install the gear. When it is installed there is no turn back. Wire gear is not as nice looking as the CF but they will out last the plane. Unless you have a perfect landing every time and a paved runway I would use the CF gear for another project. If the gear goes out of shape just bend them back. You will spend less time fixing and more time flying.
akabek is offline Find More Posts by akabek
Old Jul 16, 2014, 01:07 PM
Joined Aug 2011
Will do I will use gorilla glue then. Thanks.
Old Jul 16, 2014, 09:36 PM
Joined Jan 2012
Originally Posted by jetinteriorguy View Post
The only thing that's a problem with the wire lg is that the piece of ply that goes on last as a retainer can break in a hard landing. I just applied some fiberglass cloth to both sides using som spray glue, then soak it in thin ca to harden it. Then I trimmed off the excess fiberglass with my dremel tool. If you need more help just PM me your email and I'll send you pics.
Hi jet,
Can you post the pictures? I would like to see them...
xcski is online now Find More Posts by xcski
Old Jul 16, 2014, 10:04 PM
Joined Aug 2011
I just want to confirm....the 48" Slick does come with servo horns, am I correct?
Old Jul 16, 2014, 11:22 PM
EP 3D Flyer
feda's Avatar
Hamilton, Canada
Joined Nov 2005
Yes, it comes with servo arm extensions.
Cheers,
feda
feda is offline Find More Posts by feda
Old Jul 17, 2014, 09:10 AM
Joined Aug 2011
Cheers,
feda
Old Jul 20, 2014, 11:22 AM
Joined Aug 2011
So what kind of glue to you use to glue the horizontal stabilizer to the fuselage. I am a bit confused as to what glue is safe on what...
Old Jul 20, 2014, 03:19 PM
Renton, Wa.
Joined Feb 2006
With the hor. stabilizer you can use either welders or similiar or ca. Its when dealing with the hinge area on the wings and such that you should be careful. Epp to epp is fine with ca. I personally use ca on the hori. stabilizer.
stevelmaa is online now Find More Posts by stevelmaa
Old Jul 20, 2014, 03:42 PM
Joined Aug 2011
Alright cause the video I watched they use CA for everything...so I am assuming if I am careful medium or thin CA will work on pretty much everything . I do have EPP glue if it has to be specific to EPP
Old Jul 20, 2014, 04:26 PM
Renton, Wa.
Joined Feb 2006
I like using med. thick ca. Be careful if using thin ca on epp. Real easy to make a mess and pull off the paint/ink on the airframe. Med. is more controllable.
Old Jul 20, 2014, 04:47 PM
Burke, VA
Joined Sep 2009
If your going to use CA on the hinges make sure it's foam safe CA so it doesn't eat the EPO wing core.
jetinteriorguy is online now Find More Posts by jetinteriorguy
Old Jul 20, 2014, 05:02 PM
Joined Aug 2011
Alright well I will use medium CA and pick up some medium EPP safe CA
New Product 48-in Scale EPP Edge-540 Co-developed by Wattaplane and Skywing feda 3D Foamies 3399 Jul 19, 2014 04:50 PM
Discussion WTB BF deal profile EPP kit w/elec & full fuse kit like wattaplane Wingbreaker Hot Online Deals 0 Nov 22, 2012 07:24 AM
Discussion 5.8Giga R/C system under development? Dimitris76 FPV Talk 0 Jun 29, 2010 04:38 PM
Discussion New RC heli simulator under development sash Simulators 11 Apr 19, 2010 03:54 AM
Spit under Development Shogun Foamies (Kits) 0 Apr 08, 2005 07:19 AM
