Old Jun 30, 2014, 07:32 PM
Aero Sapiens
MojoMaestro's Avatar
Canada, QC, Montreal
Joined Oct 2009
T-Motor 1306 -3100 KV , ESC 6A or +
hey guys,
I'm building a slowflyer, an Old Fogey, i intend to use a motor i have that came with
a 6A ESC soldered to it. The thing is it was powering a 120 -140gr 3D plane,
The old fogey will be from between 165-200 gr depending on wich battery i ll use.
So i was wandering if the the weight increase could burn out the ESC.
That little 2s T-Motor for a weight of 11.g it gives you 44W. I got some Power HD* 12A ESC
that i could use to replace the 6A one. But i would prefer to avoid it,
the wires are fine & i ain't a good solder boy lol
( i (L) NATO Forces , no offense ment, just a word game to say i can't use a soldering iron )
i run it on a 30c battery & a 6030 (6x3) prop.
Here's some specs , if U want...
Tiger Motor T-Motor MT Series MT1306-10 3100kv
Tiger motor team developed many series very efficient brushless motors for electric flyers.Motors and
speed controllers are not limited to competition use, and perform exceptionally well in all types of electric RC models.
Specifications
KV................................................ .................................................. ...............3100
Configu ration............................................ .............................................9N12P
Stator Diameter.......................................... .............................................13mm
Stator Length............................................ .................................................6 mm
Shaft Diameter.......................................... ................................................2m m
Motor Dimensions (Dia.*Len)........................................ .........Φ17.715mm
Weight(g)......................................... .................................................. ........11.2g
ldle current(10)@10v(A)................................ ...........................................0.2A
No.of Cells(Lipo)....................................... ................................................1-2S
Max Continuous current(A)180S.................................... ............................6A
Max Continuous Power(W)180S...................................... .......................44W
Max. efficiency current........................................... ....................(1.5-4A)>71%
internal resistance........................................ ..........................................62m
MojoMaestro is offline Find More Posts by MojoMaestro
Last edited by MojoMaestro; Jun 30, 2014 at 10:08 PM. Reason: page fit & precisions
Old Jun 30, 2014, 09:58 PM
Aero Sapiens
Joined Oct 2009
Stumbling upon this on the forum....
General rule of thumb
50 watts per pound to fly the plane
100 watts per pound for acro work
150 watts per pound for 3D
i think i got my answer
Discussion Recommended ESC's for T-Motor MN3508-20 580 KV motors jdco Multirotor Power Systems 3 May 24, 2014 03:35 AM
Wanted Turnigy 6a escs or similar simonk or blheli escs Rcnewbiechris Aircraft - Electric - Multirotor (FS/W) 0 Mar 01, 2014 05:58 AM
For Sale (4) Tiger 1306 & (4) Tiger 6a ESC starvinmrvn Aircraft - Electric - Multirotor (FS/W) 2 Dec 25, 2013 06:45 PM
Sold motrofly 3100 kv motor, want to go fast ? bigchuck09 Aircraft - Electric - Airplanes (FS/W) 0 Sep 26, 2013 01:46 PM
Sold motrofly dmh2215 3100 kv motor bigchuck09 Aircraft - Electric - Power Systems (FS/W) 0 Sep 26, 2013 11:32 AM
