Old Today, 03:12 PM
the Netherlands
Joined Nov 2007
Originally Posted by cubcrafter60 View Post
Hi Hugo,
I remember those flights last year! Wasn't there a CG problem or something the first time? You should be fine this time. On your floats, I haven't heard of anyone modifying the stock floats to 'V' bottoms (I bought a set of longer seaplanesupply.com V bottom floats but haven't installed them yet) I'd just make sure that the bottom of the vee's are straight and I'd also do a float test to make sure you haven't removed too much flotation (it will probably be fine). I'd make sure your water rudder centers properly EVERY TIME or things can get real interesting when you touch down! (don't ask how I know ).
I've also heard that it can be hard to break the suction on glass smooth water, some guys taxi around a bit to make some ripples in the water then takeoff through that area.
Best of luck, hope you have a great vacation, and look forward to seeing a new video soon!
Robin
Thanks Robin, I also remember the pleasant mail exchange. Here's some pics of the progress:
I glued the servo on, and I am still thinking about a splash guard of some sort. It is a high quality Hitec servo and a proper rudder, so it centers very well. Also need to balance the lot out, add some lead to the left hand float probably.
The float rudder servo is mixed to the air rudder, but I can switch it off so it returns to neutral. I think it is wise to land like that, and only use the float rudder to steer once floating.
Cheers,
Hugo
HugoW is online now Find More Posts by HugoW
Discussion Fun Cub sinowace Hitec/Multiplex USA 14 Oct 09, 2011 04:43 PM
Discussion Multiplex Fun Jet at the lake bah7566 FPV Talk 31 Jan 03, 2010 09:19 AM
For Sale Multiplex Fun Jet -- PRICE DROP Toby W Aircraft - Electric - Airplanes (FS/W) 2 Dec 28, 2009 09:51 AM
Video Multiplex Fun Jet FPV set up test bah7566 Electric Plane Talk 0 Dec 25, 2009 10:05 PM
Wanted multiplex fun-jet or trade! heli123 Aircraft - Electric - Jets (FS/W) 0 Nov 14, 2009 11:02 AM
