Old Aug 29, 2012, 07:51 AM
United States, TN
Joined Mar 2011
Ready To Transition From A Trainer To Sport/3D Plane Is This A Good One?
I learned to fly on a 57" Apprentice 15e high wing trainer, I'm ready to transition to a sport/3D plane. I like the looks of the 55" Aerosky Extra 330SC: http://www.nitroplanes.com/05a330-red-rtf-nv.html is this too much of a leap or should I consider something else?
Thanks for any input!
itsme2 is offline Find More Posts by itsme2
Old Aug 29, 2012, 10:08 AM
South Africa, WC, Cape Town
Joined Oct 2011
I think it really depends on how well you can handle the Apprentice. It basically flies itself whereas the Extra will be a handful, especially for the landings. What radio do you have? Can you set expo?
Riddlers is offline Find More Posts by Riddlers
Old Aug 29, 2012, 10:43 AM
docbrew's Avatar
United States, TN, Gallatin
Joined Aug 2012
That 330 would be a handful for sure. I would go with a high wing sport plane or a low wing trainer before that 330.
Your looking at going from a Toyota Camry to an Indy car.
docbrew is offline Find More Posts by docbrew
Old Aug 29, 2012, 03:33 PM
United States, TN
Joined Mar 2011
I have a Spectrum DX6i now, I can set expo.
Old Aug 29, 2012, 03:34 PM
United States, TN
Joined Mar 2011
My thought is to use low rates and move the push rods to lowest movement.
Old Aug 29, 2012, 03:56 PM
My poor poor planes.
winndaddy's Avatar
United States, LA, Lake Charles
Joined May 2012
Without seeing you fly its hard to access wich plane would be best. Some people have alot faster learning curve than others ( as evidence at my club ). I suggest, get it, dial it back, and stay high until you get comfortable.
Winn
winndaddy is offline Find More Posts by winndaddy
Old Aug 29, 2012, 04:15 PM
winndaddy's Avatar
Joined May 2012
By the way, I'm partial to Twisted Hobbys so I can't comment on the plane.
Winn
Old Aug 29, 2012, 04:17 PM
Don't worry be happy :)
Stark's Avatar
Sweden, Gävleborg County
Joined Sep 2001
I would suggest that you look for a plane in durable EPP instead if you really want to learn 3D flying.
For example so has Twisted Hobbys planes in many different sizes, colors and shapes.
Stark is offline Find More Posts by Stark
Old Aug 29, 2012, 04:25 PM
Big Gassers
Joined Oct 2011
Twisted Hobbys for sure...I'm teaching a friend right now with the 32" Edge from TH.
Ryan1325 is offline Find More Posts by Ryan1325
Old Aug 30, 2012, 06:38 AM
D/FW
Joined Aug 2004
I would stay away from it unless you're in a club or have a more experienced pilot that could maiden it for you and get it trimmed and flying gently. If this thing is a good bit out of trim on the maiden, and you're only experience is high wing trainer, then this one may get away from you really quick. If you're looking for a plane that size that wouldn't be as radical, you may want to look at something like an Eratix. That one is more like a trainer if you set it up correctly and use low rates.
JoeDirtRC is offline Find More Posts by JoeDirtRC
Old Aug 30, 2012, 01:32 PM
United States, PA, Philadelphia
Joined Dec 2011
I have no trainer or Sim when I started; went directly to warbirds (P-51 and AT-6) that almost killed my interests in RC in the first month of flying. And then I got a Cermark Fantasy Racer that saved me from quitting. I actually found big foamie are more stable in the wind and obviously easier to see when you are at10 mistake height. Anyhow, it would save me lots of pains if I knew more about EPP plane back then. My first three EPP 3Ds are from TechOne. I bought them because of the are bigger in size and less skill-required in building. I really like TH's Crack Pitts but my flying field is consistently windy that pushes my 32" EPP all over the place. So now I only fly EPP planes with wingspan greater than 44". My 2 cents is you should consider your flight environment and your skills both in building and flying. Nothing wrong with the Aerosky, but get prepared to feel flying a brick.
Vince_TT is offline Find More Posts by Vince_TT
Old Aug 30, 2012, 04:05 PM
winndaddy's Avatar
Joined May 2012
Meh, just have someone there thats experienced to maiden it so it can be trimmed and gone threw properly. After that, I'm sure you could handle it. However, it would suck to put all the work involved in getting the plane together just to crash within the first 2 minutes.
Help! are twisted hobbies planes good 3d trainers? RCAddict16 3D Foamies 9 May 29, 2012 08:17 PM
Discussion Is this a good boat for me to get? mahbouni Racing Boats - Electric 4 Apr 03, 2012 03:28 AM
Discussion Transitioning from Radian to faster slope plane Riodiler1 Slope 39 Apr 01, 2012 02:06 PM
I need a 3d trainer....transition from "sport flier" to "3D" Jim_W 3D Flying 12 Nov 11, 2004 03:31 AM
Easy Sport 40, is it a good transition from trainers Gordo35 Fuel Plane Talk 2 Nov 07, 2004 11:51 AM
