Old Mar 11, 2015, 05:00 PM
beachflyer is online now
Find More Posts by beachflyer
AMA 112747
beachflyer's Avatar
Neptune Beach FL USA
Joined Nov 2000
Flip32 racing edition
Anyone have a pic of what the outputs are on this board?
beachflyer is online now Find More Posts by beachflyer
Old Mar 11, 2015, 05:30 PM
Granted is offline
Find More Posts by Granted
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
The outputs on that board are the motor connections and one of the 2-wire plugs is for a buzzer. The other is battery monitoring (one closest to usb), the small 3-pin header is Spek.sat connection, and depending on the software you load the RX plug can be configured as all PWM inputs or one PPM in and an I2C or serial connection.
Granted is offline Find More Posts by Granted
Old Mar 11, 2015, 05:40 PM
AMA 112747
beachflyer's Avatar
Joined Nov 2000
Thanks. I can read the board. I am talking about top outputs and the right handside 9 wire output! I just need a pic of the board with all outputs named. Buzzer says Buzzer and battery says battery, thats it. No help from READY TO FLY QUADS
Old Mar 11, 2015, 05:51 PM
Granted is offline
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
That 10-wire plug is the RX-in, and depending on the software you load on the board changes what those connections do. Even some of the motor connections can be configured as IO ports so labelling them doesn't help.
Don't expect any help from RTFQ.
Old Mar 11, 2015, 05:59 PM
AMA 112747
beachflyer's Avatar
Joined Nov 2000
Ok. I gotcha. I can make it work now
Old Mar 11, 2015, 06:03 PM
Granted is offline
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
NP, I had the same issue figuring out a Flip32+.
Old Mar 12, 2015, 08:43 AM
hoggdoc is offline
Find More Posts by hoggdoc
United States, CA, Huntington Beach
Joined Jan 2013
The difference is that the Flip32+ is well a documented board. Even on RTFQ there are several images of wiring diagrams.
I am totally surprised that Paul has nothing supporting the new mini Flip32 on his site.
hoggdoc is offline Find More Posts by hoggdoc
Old Mar 12, 2015, 11:03 AM
Jedivoll1 is offline
Find More Posts by Jedivoll1
MSRL Team Pilot
Joined Jan 2012
How would you mount this...I didn't see any mounting hole and it won't fit post pre-drilled holes for FC in most frames.
Anyone have a suggestion???
Jedivoll1 is offline Find More Posts by Jedivoll1
Old Mar 12, 2015, 03:46 PM
derelicte is online now
Find More Posts by derelicte
Joined Aug 2006
I was wondering about that myself...
derelicte is online now Find More Posts by derelicte
Old Mar 12, 2015, 09:18 PM
AMA 112747
beachflyer's Avatar
Joined Nov 2000
I have email him multiple times about this and no responce is what I have got back!!
Old Mar 12, 2015, 09:20 PM
AMA 112747
beachflyer's Avatar
Joined Nov 2000
Is it too much to ask to have it done like the rest of the Flip boards, Hard to tell what wire goes where on the Satellite reciever output. Not sure where to input the 5 volts needed for the board
Old Mar 13, 2015, 03:39 AM
Granted is offline
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
The sat connection should be ground at the center pin (confirm this), plug in the usb and see which of the outside holes is 3.3v, the remaining will be signal.
The board gets 5v same place as most, thru the esc servo wire. Center row of the 3x6 header, marked with "+" at the bottom edge of your pic, ground to its' left on the outside edge, and the motor signal outputs are the inside row. #1 is next to the buzzer plug and marked as such.
The 10-wire rx plug, from right to left starting with black as #1:
1- RX ground
2- RX +5v
3 thru 10 - CH1 thru CH8
Old Mar 13, 2015, 12:58 PM
AMA 112747
beachflyer's Avatar
Joined Nov 2000
Thanks I will never take you for Granted!!!
Old Mar 13, 2015, 04:18 PM
ummagawd is offline
Find More Posts by ummagawd
Crash Test Dummy
Joined Apr 2013
can anyone confirm if the 10-wire plug can be configured for a serial connection to connect an OSD to it?
ummagawd is offline Find More Posts by ummagawd
Old Mar 13, 2015, 05:05 PM
Granted is offline
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
You can get two on the 10-wire plug running Cleanflight in PPM mode and enabling "softserial" in CLI.
News ST Racing Concepts Limited Edition Parts Matt Gunn Rock Crawlers 4 Dec 30, 2014 03:39 PM
Discussion The Flip32+ ... only a new NAZE32 clone ? ...and other questions. JUERGEN_ Multirotor Electronics 27 Dec 10, 2014 01:53 AM
Discussion Mytoys Race edition LIPO spruce m00se Batteries and Chargers 0 Nov 03, 2014 07:55 AM
Sold NEW RTF X-Plane Race Edition Jim Frahm Aircraft - Sailplanes (FS/W) 8 Jul 27, 2014 07:53 PM
Sold X-Plane Full carbon spread tow Race edition Dbox Aircraft - Sailplanes (FS/W) 8 Feb 28, 2014 10:21 PM
