Old Mar 29, 2014, 06:11 PM
vcazan is offline
Find More Posts by vcazan
vcazan's Avatar
Canada, ON, Markham
Joined Apr 2012
monitor mount for dx9
Just got the new DX9 and I noticed that it comes with a plastic handle and I can no longer use my lcd mount adapter with it.
I then tried to use another lcd adapter that attached from the neck strap clip but again on the DX9 they rotated the neck strap clip 90 degrees so neither options work.
Anyone have any suggestions?
vcazan is offline Find More Posts by vcazan
Old Mar 30, 2014, 05:10 AM
wazoo22 is offline
Find More Posts by wazoo22
France, Bourgogne, Nevers
Joined Feb 2012
Had a similar problem with my Graupner MX-20. I tried to get inside and loosen the nut that held on the neck strap fitting to rotate it 90 degrees- no luck. So I brute-forced it to turn with pliers to where the monitor mount would fit, then glued it in position with CA, figuring there was not going to be a need to rotate it ever again. So far so good.
wazoo22 is offline Find More Posts by wazoo22
Old Mar 30, 2014, 04:29 PM
Jesse Buck is offline
Find More Posts by Jesse Buck
Soaring Peacock Aerial Media
Jesse Buck's Avatar
United States, CA, South Lake Tahoe
Joined Dec 2012
Get a balancer that will rotate it 90 degrees. Worked for mine.
Jesse Buck is offline Find More Posts by Jesse Buck
Old Mar 31, 2014, 12:59 AM
thehelidude is offline
Find More Posts by thehelidude
United States, CA, Orange County
Joined Apr 2013
Yep, a mount adapter should work. I'm considering mounting a monitor to my dx9 also. Something like this should work, but I haven't tried it yet:
http://www.helipal.com/tarot-neck-st...ter-jr-tx.html
thehelidude is offline Find More Posts by thehelidude
Old Mar 31, 2014, 04:54 AM
davidwills is offline
Find More Posts by davidwills
Joined Dec 2013
Take a look about this TX mount http://www.wtotoy.com/hj-05-glass-fi...ous-rc-en.html
davidwills is offline Find More Posts by davidwills
Old Mar 31, 2014, 08:28 AM
Jesse Buck's Avatar
Joined Dec 2012
That looks like the one I use. That and the Tarot monitor mount.
Old Jun 27, 2015, 10:47 PM
ofpd9330 is offline
Find More Posts by ofpd9330
May it rest in pieces!
United States, PA, Old Forge
Joined Apr 2014
I know this is an old tread, I found this tread searching google for a monitor mount for my DX9. On Ebay I came across this mount. It's called a crosswise transmitter monitor mount bracket. Maybe it will help someone else searching for a mount also.
http://www.ebay.com/itm/Hot-CNC-Allo...item1a0105655e
ofpd9330 is offline Find More Posts by ofpd9330
Old Aug 26, 2015, 05:07 PM
WRXJIM is offline
Find More Posts by WRXJIM
Joined Mar 2015
Oldish thread, but I got one of these after (stupidly) trying two other types of generic mounts.
I was too cheap to just buy this, but in hindsight this thing is awesome!!
Its from Mr Droneworx - http://www.mrdesignworx.com/shop/fpv...-black-edition
Was $35 is bucks and is the best $35 Ive spent so far in this hobby. Being able to remove my monitor so easily and quickly is awesome. My space in my Pelican 1510 case is very tight with my foldable XJ470 so I could never fit my DX9 in with the monitor attached.
Honestly worth a look. He makes a standard screw mount and also a iPad/tablet mount for the same money.
MR Droneworx Spektrum DX9 Quick Mount (4 min 54 sec)
Here is a video I made of it.
WRXJIM is offline Find More Posts by WRXJIM
Help! monitor mount for Tx Radio jaredstanley FPV Equipment 1 Jan 02, 2014 05:46 AM
Discussion monitor mount for Tx Radio jaredstanley FPV Equipment 1 Jan 02, 2014 12:35 AM
Discussion Iphone 5 mount for spektrum dx9 blackbox100 FPV Equipment 0 Nov 07, 2013 12:42 PM
Sold 7" - 8" Monitor Mount For Futaba JR Wfly or DJI Phantom Controller SOLD SOLD SOLD Ziggycranston FPV Equipment (FS/W) 1 Oct 06, 2013 11:28 AM
Sold 7" - 8" Monitor Mount For Futaba JR Wfly or DJI Phantom Controller SOLD SOLD SOLD Ziggycranston Aircraft - Electric - Multirotor (FS/W) 0 Oct 06, 2013 03:51 AM
