Old Jun 22, 2011, 10:29 AM
danford1 is offline
Find More Posts by danford1
Innovator
danford1's Avatar
United States, MI, White Lake
Joined May 2011
58" Aeromaster from Value Hobby. CG location problem
I'm thinking of buying a 58" Aeromaster aerobatic plane, not the bi-plane, from Value Hobby. http://www.valuehobby.com/product_de...=0&item_id=379
The instruction sheet can be downloaded here.
http://www.valuehobby.com/manual/Aeromaster.pdf
The main problem I see is the CG location. The picture shows it 85 mm back from LE and the wording says 110 mm back from LE at the fuselage.
Could the 85 mm picture be at the wing tip ???
Does anyone here have any experience with this particular mode from Value Hobby?
Danford1
danford1 is offline Find More Posts by danford1
Old Jun 22, 2011, 02:53 PM
fmw is offline
fmw
Find More Posts by fmw
fmw
fmw's Avatar
Joined Jul 2009
No experience here but in your shoes I would choose the CG point that is closer to the leading edge (85mm) and then work my way back if that proves to be too nose heavy. Going the other way can be disastrous.
fmw is offline Find More Posts by fmw
Old Jun 24, 2011, 10:27 AM
Vulgar Vulture is offline
Find More Posts by Vulgar Vulture
AMA 34191
Vulgar Vulture's Avatar
Fayetteville, PA
Joined Dec 2002
What complicates this is that 4 15/16" converts to 125.5 mm!
I would follow fmw's advice if I were you. Start nose heavy (85mm) then work your way back on subsequent flights. Good luck!
Vulgar Vulture is offline Find More Posts by Vulgar Vulture
Old Jun 24, 2011, 01:22 PM
TexasClouds is offline
Find More Posts by TexasClouds
TexasClouds's Avatar
Joined Feb 2010
how many mm back is the spar?
TexasClouds is offline Find More Posts by TexasClouds
Old Jun 24, 2011, 10:59 PM
danford1 is offline
Innovator
danford1's Avatar
Joined May 2011
I don't know where the spar is located.
I haven't bought it yet. I want to find out all I can before I buy it.
Anyone here have one?
Danford1
Old Jun 25, 2011, 08:54 AM
road_rascal is offline
Find More Posts by road_rascal
Crashasaurus Dumbthumus
road_rascal's Avatar
USA, MN, Apple Valley
Joined Dec 2008
I don't have that one but I have 2 other Value Hobby planes- the Sabre 35 and the 49" Yak. The Sabre didn't need many mods but the Yak really needed some help. The firewall was way too flimsy and the LG area needed quite a bit of beefing up. Flies nice though. I've considered the Aeromaster as a lazy flyer. I have way too many planes at this point...
road_rascal is offline Find More Posts by road_rascal
Old Aug 16, 2015, 08:51 PM
squigintx is offline
Find More Posts by squigintx
United States, TX, Allen
Joined Jun 2015
Has anyone bought an Aeromaster?
http://www.valuehobby.com/airplanes/...er-46-arf.html
What is the verdict?
How is the quality? What is the covering? How is the canopy attached? What motor/battery do you recommend?
The plane looks like a good value but is it too good to be true?
squigintx is offline Find More Posts by squigintx
Build Log first Build Value Hobby E450 CCPM 3D Helicopter Kit Metal Version RogueTitan Mini Helis 55 Aug 31, 2011 09:50 PM
Cool Hobby King VRx RSSI Location (900mhz) Enthlapy FPV Talk 4 Jul 08, 2011 06:18 AM
Discussion 40" Yak 54 Profile from Value Hobby sgomes 3D Flying 1 May 11, 2011 08:12 PM
Discussion Topstar 480 from Value Hobby tlh101 Power Systems 0 Apr 10, 2011 01:41 PM
B-58, F-106 Cg location stegre Fuel Jet Talk 2 Jun 28, 2004 09:46 PM
