Old Yesterday, 07:56 AM
Canada, ON, London
Joined May 2011
Originally Posted by drac View Post
Yep, I have the 635 and I was about to say I think that may be why mine was already activated.
DOH! LOL... I should have asked - HUGE difference from the 636 to 635. The 635 is NOT programmable via cable / app interfaces. It is a Tx stick only programmable unit.
Problem solved. </facepalm>
uberjay is offline Find More Posts by uberjay
Old Yesterday, 03:19 PM
Flying Fiz's Avatar
Sydney Australia
Joined Dec 2009
Hi
I still haven't figured out how to use the Matchbox (see previous post). Do I need to plug in one servo at a time and set them all separately? At the moment its doing nothing. I also tried powering the matchbox via the 636 rx with a 6s battery via the speedy, still nothing but a red light on whilst in the 0 position.
Very frustrated!!
Cheers,
Flying Fiz is offline Find More Posts by Flying Fiz
Old Yesterday, 04:03 PM
Australia, TAS, Burnie
Joined Jul 2008
Yeah, the different numbers didn't click with me straight away.
What is the differences between the 2, apart from the 636 being computer programmable?
drac is online now Find More Posts by drac
Old Yesterday, 05:10 PM
Canada, ON, London
Joined May 2011
I'm not sure other than I would not want a 635 if someone gave it to me as I'm too lazy to figure out what sticks to hold where for how long ;-). I had a 636 in a plane that's sold now and I loved that I could just plug my phone in at the field, adjust / tweak a value, and go fly.
J
Old Yesterday, 05:55 PM
Joined Jul 2008
J
Hmm, that's interesting. I can't recall having to hold the Tx sticks in positions to set up. I plugged the Matchbox in and set the travels there and that was that. Unless I just don't remember doing it??
One thing for sure is it wasn't complicated to set up.
Old Yesterday, 06:07 PM
Canada, ON, London
Joined May 2011
Sorry I meant on a plane without the matchbox. And for making adjustments to the PIDS/rates.
On my Beast I'm not using any stabilization. Just running an AR8000 and high voltage servos.
J
Old Yesterday, 07:48 PM
I can't fly
camoy's Avatar
United States, CO, Parker
Joined Dec 2006
The big differences between the AR636 and AR635 is you can run separate aileron servos no need for a y cable, better for aileron setup. The latching can be adjusted which means you know have control over hoe hard the Gyro starts to kick in not just how much it kicks in. Meaning the higher latching value will cause the Gyro to come on with more gain (not to exceed the max gain setting) once the sticks are let go. Stick priority is also adjustable which means having control of when the Gyro shuts off when you are giving inputs. A higher stick priority means the gyro shuts off faster as you move the sticks from center. Lastly the AR636 is capable of 3 gain settings which one can be a hold if desired. The AR635 only can do two gain settings of which hold cannot be one.
The AR636 is the upgrade from the AR635, it is closer to the other gyros on the market currently in terms of features and adjustability.
camoy is offline Find More Posts by camoy
Old Yesterday, 07:49 PM
I can't fly
camoy's Avatar
Joined Dec 2006
Originally Posted by Flying Fiz View Post
Hi
Very frustrated!!
Cheers,
I am not sure as i am at work right now but the matchbox may not be able to handle the HV.
Old Yesterday, 08:15 PM
Flying Fiz's Avatar
Sydney Australia
Joined Dec 2009
I've got a dud !
Thanks for the response Camoy. Yes it can handle the HV as its the new HV Matchbox and tolerates up to 8.4 volts.
But speaking to the Australian distributor I must have a faulty unit and they want me to return it.
I'll report in due course with the result of all this but a magor pain and the Beast won't be flying over the holiday period as planned.
Cheers.
Old Yesterday, 08:49 PM
Joined Jul 2008
Both Rx's are 6 channel, so you would still need to use the Matchbox on the 636 to set up 4 aileron servos??
Old Yesterday, 09:11 PM
I can't fly
camoy's Avatar
Joined Dec 2006
Well one could setup a Beast with the AR636 without a matchbox.
Here is one way. If using a programmable digital servo you would hook up the top and bottom right ailerons servos and use a y cable to plug into the AR636. Then using the servo programmer set your centers and balance the end points for equal throws in both directions and both top and bottom servos. Repeat for the otherside and plug the y cable into aux1.
So yes if you have say Hitec HS5245MGs in the wings one can accomplish this without the need of a matchbox. Just one needs to have the servo programmer and some patience as it takes a little longer getting things balanced out and centered.
Old Yesterday, 09:35 PM
Joined Jul 2008
Yes, you would need one or the other. Programmable servos do basically the same thing as a Matchbox.
Old Today, 01:15 AM
can't buy vaporware
7oneWo1f's Avatar
Joined Nov 2011
Ask in radio section you might get better help.
7oneWo1f is offline Find More Posts by 7oneWo1f
Cool New E-flite Cessna 150 Aerobat ARF dee-grose Scale ARF/RTF 607 Nov 30, 2014 08:09 AM
Sold E-flite hawker hurricane rc airplane plane kit no electronics new $80 3drcparts Aircraft - Electric - Airplanes (FS/W) 8 Feb 21, 2013 01:35 PM
For Sale Misc Arf parts, Hangar 9, E-flite, 3dhs, Great Planes dakotanovass Non R/C Items (FS/W) 0 Jan 12, 2013 08:56 AM
Sold E-flite L4 Grasshopper ARF and Cessna 150 Aerobat ARF ton2di Aircraft - Electric - Airplanes (FS/W) 0 Nov 23, 2012 06:50 PM
Discussion e-flite cessna 150 aerobat 250 arf? rcguy1234 Electric Plane Talk 3 Aug 20, 2011 02:38 PM
