Old Yesterday, 09:47 AM
United States, CA, Carlsbad
Joined Apr 2014
Using 7.4 volt. Max torque for the HV servos.
PamW is offline Find More Posts by PamW
Old Yesterday, 10:47 AM
RiBell's Avatar
Canada, BC, Abbotsford
Joined Jan 2003
Originally Posted by Cherokee Flyer View Post
If I remember correctly the larger the wire, the lower the resistance, thus lower loss.
L.
This is correct.
Originally Posted by Snakebite666 View Post
My electronic wizard days are behind me, but be careful about increasing the thickness of wires as you could increase the resistance and create lag or power drops...
Snake:
You are correct about being careful with wire size. Although I don't have any mega projects. But if you look at Dag's huge B-36. with 20+ servos in that thing running several receivers for redundancy and safety. Add in the motor wiring. He's got to have 20 lbs. of wire running through that thing. Going up a gauge of wire would be a significant weight, The ultra micro guys watch the wire weight as well.
However for the rest of us with 40 size and up sport and scale models. I don't think it's an issue.
Rick
RiBell is offline Find More Posts by RiBell
Old Yesterday, 12:55 PM
Cherokee Flyer's Avatar
United States, KS, Rose Hill
Joined Sep 2007
Bruce,
Might want to look at Electrodynamics one click multi-connex. They work great and are resonable, the concurn I have with your D9 connectors is they are designed to be connected with screws and you could have issues with just plugging them in. Don't want to see all that super work get hurt by a connection.
L.
Cherokee Flyer is offline Find More Posts by Cherokee Flyer
Old Yesterday, 01:15 PM
Martin5465's Avatar
United States, TX, Haltom City
Joined Mar 2013
Cherokee, Bruce said he was going to cut the plastic casings off.
That probably means the screw fasteners too.
Some guys use dental floss or small wire ties to tie the connections together.
That's probably what Bruce will do.........................
Martin5465 is offline Find More Posts by Martin5465
Old Yesterday, 01:28 PM
Jack of all master of none
splinterz25's Avatar
Baltimore MD USA
Joined Jan 2011
HERE'S WHAT I'M DOING I COLOR CODE THE PLUG ENDS.
THE WING BOLT WILL PULL THE CONNECTORS TOGETHER.
THAT PART IS EASY: REMEMBERING WHAT THE
I DID A YEAR AGO IS THE PROBLEM. LOL
Bruce
splinterz25 is offline Find More Posts by splinterz25
Old Yesterday, 01:35 PM
Martin5465's Avatar
Joined Mar 2013
So each half of the plug will be firmly attached to the wing tip and the wing root,
and plug in automatically when you slide the wing tip on, if I read that right. Is that so?
Old Yesterday, 02:24 PM
Baltimore MD USA
Joined Jan 2011
THAT IS CORRECT
THE lights will have to be plugged in by hand there's not enough wires; and they will go through the half round hole above the 9 pin plug.
Old Yesterday, 02:43 PM
United Kingdom, England, Dewsbury
Joined Jul 2014
Originally Posted by splinterz25 View Post
THAT IS CORRECT
You know if you go down to an electronics shop, you can pick up these connectors up to 21pin and wire them yourself?
Snakebite666 is offline Find More Posts by Snakebite666
Old Yesterday, 02:54 PM
Baltimore MD USA
Joined Jan 2011
THERE A REAL TO SOLDER ....I'VE TRIED THIS WORKS FOR ME.
Bruce
Old Yesterday, 03:50 PM
Joined Jul 2014
Bit too fine work huh? lol.
Yeah, they can be a bit of a git, the key is to fill each core with solder first, then clamp them to add the tinned wire...
Old Yesterday, 05:31 PM
Baltimore MD USA
Joined Jan 2011
Yes wiring this is going to be a pain in my FOR SURE
This is when I need a tecno geek to come over and run this stuff
no takers though
Bruce
Old Yesterday, 06:09 PM
Joined Sep 2007
I'd be glad to, but it is a bit of a trip!
L.
Old Yesterday, 11:11 PM
Martin5465's Avatar
Joined Mar 2013
Be a bit of a trip for me, too, but it would be an easy job for me.
In the early 90's I worked for a company that built hard drive motors
where I soldered tiny wires under a magnifying glass.
But at least there wasn't any sanding to do......
Old Today, 03:12 AM
Joined Jul 2014
Hey, post the connectors and cables over with detailed instructions for pin numbers and wire colours and I'll get it back to you in the new year lol.
Other than that, just keep doing what you're doing lol.
Wanted 80" PBY Cat...Looking for Gear or plans... mudman1959 Aircraft - General - Miscellaneous (FS/W) 8 Sep 11, 2014 04:58 AM
Sold Vintage RC Plans 108" PBY 5-A with plastic parts AVGDAY Aircraft - Electric - Airplanes (FS/W) 0 Jan 29, 2013 11:08 AM
Sold Vintage RC Plans 108" PBY 5-A plans and plastic AVGDAY Aircraft - Fuel - Airplanes (FS/W) 0 Jan 29, 2013 10:59 AM
For Sale 1/4 Scale Robert Star Bumble Bee Plans & Foam Wing Cores M.Putnam Aircraft - Fuel - Airplanes (FS/W) 0 Jan 02, 2013 10:16 AM
Discussion Vintage PBY Plan Gullwing Waterplanes 7 Jan 02, 2007 06:49 AM
