Old Jul 06, 2016, 12:36 PM
hallo is offline
Find More Posts by hallo
Amateur Forever
hallo's Avatar
Norway
Joined Feb 2014
How much time do you spend on maintenance
How much time do you spend on maintenance of your CNC machine?
It takes me about two to tree days to properly clean up my machine and add fresh grease and oil.
I have a recommended schedule from the manufacturer of course but how about you, what's your routine?
hallo is offline Find More Posts by hallo
Old Jul 06, 2016, 01:52 PM
acclivity is offline
Find More Posts by acclivity
United States, CO, Olathe
Joined Apr 2016
Not much. Sometimes change out a bearing or two. A little cleaning here and there.
acclivity is offline Find More Posts by acclivity
Old Jul 06, 2016, 11:36 PM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
My mill gets taken apart about once a year. I spend about a week doing that as it takes some time to check, clean, and adjust everything. After a messy project it gets cleaned and lubed, maybe several hours for that. For normal projects I usually give it a quick look over, then clean and lube afterward, maybe 10 minutes.
Roto Rob is offline Find More Posts by Roto Rob
Old Jul 09, 2016, 08:57 AM
hallo is offline
Amateur Forever
hallo's Avatar
Norway
Joined Feb 2014
Ok, thanks.
I guess I'll get the hang of it after a couple of years.
Old Jul 09, 2016, 09:16 AM
kc8qpu is offline
Find More Posts by kc8qpu
kc8qpu's Avatar
United States, SC, Moore
Joined May 2007
I know you guys are probably referring to hobby grade machines here . However I just went through all this at my work. We make stuff that is extremely precise. With tolerances of +-.005mm. Its small. The machines are very nice but have not had periodic maintenance done in a long time. Well now it has turned into a huge project and has really raised the cost of repairs by 4 times. And more than tripled the time down.
I would suggest that you do all you can to protect your investments. A few hours/ days spent in the long run can potentially be a huge cost savings.
kc8qpu is offline Find More Posts by kc8qpu
Old Jul 09, 2016, 11:12 AM
hallo is offline
Amateur Forever
hallo's Avatar
Norway
Joined Feb 2014
Thanks for that, I will keep to the schedule in my manual (which is pretty frequent) and then some.
Discussion How much time do you spend on Simulator? Killionaire Beginner Training Area (Heli-Electric) 9 May 15, 2014 08:20 PM
Discussion How much time do you guys spend on flight trimming your planes? Roguedog Classic Pattern Flying 5 Jan 04, 2012 11:24 PM
Poll How much time do you spend on RCGroups a week? Doctor Who Electric Plane Talk 29 Dec 13, 2007 02:25 PM
How Much time do you spend on E-Zone at work? fly4fun Electric Plane Talk 49 Mar 24, 2005 05:57 PM
How Much time a week do you spend ... kepople Electric Plane Talk 13 Aug 24, 2002 01:14 PM
