Old Jun 05, 2016, 06:06 AM
rcgroupie is offline
Find More Posts by rcgroupie
pushing the envelope
rcgroupie's Avatar
USA, CA, Los Angeles
Joined Jun 2005
Question
Reverse Thrust for Small Airstrip?
Just wondering if anybody has tried reversing the fan rotation to achieve reverse thrust. I know the real guys use cascades or buckets, but merely reversing seems easier for electric.
rcgroupie is offline Find More Posts by rcgroupie
Old Jun 05, 2016, 07:51 AM
tkallev is offline
Find More Posts by tkallev
LSF303-AMA Fellow
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
I'm not aware of any ESCs designed for aircraft that have a reverse mode ... only surface controllers suppport reverse.
tkallev is offline Find More Posts by tkallev
Old Jun 05, 2016, 12:05 PM
minimicrorc is offline
Find More Posts by minimicrorc
Joined Apr 2012
There are a few multirotor escs that can do reverse rotation.
minimicrorc is offline Find More Posts by minimicrorc
Old Jun 05, 2016, 02:26 PM
4stripes is offline
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
There were some larger fans that had reversing but I doubt their effectiveness. I think it was HSD or TAFT models. Brakes on the wheels is very effective. You can buy electric brakes or make mechanical paddles to rub on the tire. Both work well.
4stripes is offline Find More Posts by 4stripes
Old Jun 05, 2016, 06:16 PM
jofro is offline
Find More Posts by jofro
Joined Jan 2010
Some 10 years back I created weird braking system with specially designed servo arms to rub against tires on my large IC powered "C-130, Herc" to keep it stationary at low idle of all four power units, it worked great for a while till the arm cut into the tires just as the cutting knife on the lathe! Wish I had the picture of those tires,
Now converted into electric no such issue as wanting to taxi during the idle.
I hate to see the stress of the E-motor to put it into reverse thrust, but you could always copy the system they use on full size airliners, the bloke did pretty nice job of it in 3/D printing, tho only as a desk toy not practical in real terms, Good luck!
jofro is offline Find More Posts by jofro
Old Jun 06, 2016, 05:01 AM
ronwc is offline
Find More Posts by ronwc
Ron - AMA 1025
ronwc's Avatar
USA, FL, Largo
Joined Aug 2005
Reverse thrust J10 video - https://www.youtube.com/watch?time_c...&v=bM79Jd6ckMw
ronwc is offline Find More Posts by ronwc
Old Jun 06, 2016, 05:18 AM
Quorneng is offline
Find More Posts by Quorneng
Joined Feb 2007
It could certainly be done with a 2 pole two way switch controlled by a servo to reverse two of the motor wires although a suitable high amp switch is likely to be relatively heavy.
Probably not a good idea to reverse the EDF when under power though!
Quorneng is offline Find More Posts by Quorneng
Old Jun 06, 2016, 06:58 AM
bandetlol is offline
Find More Posts by bandetlol
United States, TX, Irving
Joined Mar 2015
http://www.bananahobby.com/120a-brus...ueryId=1793522
This ESC will do reverse thrust.
It automatically does motor braking to bring the motor to a stop before reversing direction, so you just flip a switch.
Note: It doesn't give you much thrust.
bandetlol is offline Find More Posts by bandetlol
Old Jun 06, 2016, 07:53 AM
AceMigKiller is offline
Find More Posts by AceMigKiller
Team EJF >>>WHOOSH>>>
AceMigKiller's Avatar
Joined Jul 2004
If you're running any sort of lightweight thrust tube, it'll collapse on you.
As already mentioned, brakes are simple and very effective.
AceMigKiller is offline Find More Posts by AceMigKiller
Old Jun 06, 2016, 06:00 PM
jofro is offline
Joined Jan 2010
Firstly, the rotor spinning in opposite direction wouldn't be very efficient and secondly the rotor nut would get lose and undone!
Old Jun 06, 2016, 06:15 PM
bzfrank is offline
Find More Posts by bzfrank
4.2V of pure Kraut power
bzfrank's Avatar
Germany
Joined Nov 2006
Add a brake chute (Servo controlled - three settings: Retracted, Deployed - and Released, so you are able to drop the chute if wrongly deployed up in the air) . Much easier and works fine. It also adds a kind of scale touch for jet landings.
bzfrank is offline Find More Posts by bzfrank
Old Jun 07, 2016, 03:25 AM
jofro is offline
Joined Jan 2010
That sounds great, it would look fantastic with models like "Black Bird", I have never seen video of such a landing with RC model, anyone?
Old Jun 07, 2016, 04:51 AM
rcgroupie's Avatar
Joined Jun 2005
Is that because we are talking only 5A here or because EDF's are not very efficient in reverse?
Old Jun 07, 2016, 05:32 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
Maybe that's why cars have brakes! -- Can't see were throwing it in reverse would be beneficial -- or cheap!
Open you wallet, let the moths out, and buy some electric brakes ..
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old Jun 07, 2016, 05:57 AM
ronwc is offline
Ron - AMA 1025
ronwc's Avatar
USA, FL, Largo
Joined Aug 2005
I have flown and used the thrust reversing ESC in the J10 and it works well, later it was used in a Meteor. It will also let you taxi backward, watch the video of rcinformer I posted earlier - https://www.youtube.com/watch?time_c...&v=bM79Jd6ckMw
Discussion Thrust angle on a small wing LDGILLS Flying Wings 13 Apr 10, 2016 11:59 AM
Discussion looking for small, light, flat prop/motor that produces 2 ounces of thrust. webbeing Power Systems 16 Nov 17, 2015 07:17 PM
Thrust button and small brass thrust bearings sinbad Scratchbuilt Indoor and Micro Models 2 Nov 12, 2004 11:38 AM
Cool Looking for Books/reverence for basic building aeajr The Builders Workshop 5 Sep 25, 2003 05:58 AM
Wing loadings & thrust/weight for small models stumax Electric Ducted Fan Jet Talk 12 Jan 21, 2003 05:49 PM
