Old Feb 25, 2016, 09:23 AM
locoworks is offline
Find More Posts by locoworks
isle of man
Joined Aug 2003
FRSKY X4RSB with SBUS to PWM converter????
is it possible ( anybody tried and succeeded? ) to use an X4R with an SBUS to PWM converter plugged onto the SBUS output to get a 7 channel PWM receiver? I know CH's 1-3 on the X4R outputs still work alongside the SBUS channels if you use SBUS to connect to a CC3D flight controller. As I have a few X4R's doing nothing and want to equip a 6 channel plane it would be cheaper to buy the SBUS to PWM converter instead of an X6R or X8R for the job. will it work and are the outputs configurable on the SBUS to PWM converter? I'd set them to 4 -7 or 5 -8 if they have to be done in blocks and program up the taranis accordingly. thoughts???
locoworks is offline Find More Posts by locoworks
Old Mar 05, 2016, 01:04 PM
isle of man
Joined Aug 2003
it works, but analogue servo's buzz, i read elsewhere digital don't but don't have any to try it with yet.
Old May 08, 2016, 06:26 PM
skylarkfpv is offline
Find More Posts by skylarkfpv
Joined Apr 2011
CC3D can work well with SBUS, it need no a converter
skylarkfpv is offline Find More Posts by skylarkfpv
Old May 08, 2016, 08:54 PM
mpjf01 is offline
Find More Posts by mpjf01
mpjf01's Avatar
Australia, SA, Adelaide
Joined Aug 2012
He wants to get 6 PWM channels to control a plane from a hybrid receiver (SBUS plus PWM) , nothing to do with any CC3D.
mpjf01 is offline Find More Posts by mpjf01
For Sale RmileC high accuracy 18 channel PPM/PWM/SBus signal converter RC2211 Aircraft - General - Radio Equipment (FS/W) 2 Sep 27, 2015 08:38 PM
Discussion X4R, SBUS to PWM converter, frame rate and analogue servos sabre2 Radios 6 Sep 25, 2015 07:54 AM
Help! Any Diy Arduino based PWM to Frsky CPPM converter out there? rank DIY Electronics 1 Jun 19, 2015 03:55 AM
Discussion FrSky X8R Sbus and PWM hjstaples Radios 2 Mar 08, 2015 05:10 PM
For Sale OrangeRX dsmx sbus RX and frsky sbus-ppm converter InFocus Aircraft - General - Radio Equipment (FS/W) 0 Aug 30, 2014 12:00 AM
