Old Dec 21, 2015, 08:47 AM
Quorneng is online now
Find More Posts by Quorneng
Joined Feb 2007
A push/pull twin with really big flaps!
Included as a "scratch built foamy" as it is nearly all 3mm sheet Depron but the wing is built in more or less the conventional spar/ribs/skin way.
Description:
Being a twin allows the use of counter rotating props to eliminate torque an important consideration on a very slow flying plane and the push pull configuration keeps the battery, ESC and motors close together.
The flaps extend over 60% of its 40" (1016 mm) span and occupy no less than 45% of the wing chord. In addition the flaps have two sections and travel to a maximum of 85 degrees.
Description:
Both flap sections are bottom hinged and driven from a single 5g servo on each side.
Two section flap test (0 min 8 sec)
Flown bank and yank the ailerons and elevator use 3,7g servos.
The motors are 2840kV Emax 2805 driving 3 blade 5x3 props. An novel feature is its very small hub allows a "spinner behind the prop" configuration which is also made of Depron.
Description:
The battery is a 2200mAh 2s LiPo.
It weighs 12.5 oz (355 g) ready to fly - which it does quite well.
Plenty of power and with full flaps deployed it lands in a very short distance!
PushPull STOL flight and landing (1 min 54 sec)
Really just an experiment it has nevertheless survived for 3 years and is still going.
Quorneng is online now Find More Posts by Quorneng
Old Dec 21, 2015, 10:17 AM
basicguy is offline
Find More Posts by basicguy
Dream it...Build it...Fly it!
basicguy's Avatar
United States, MO, Macon County
Joined Dec 2014
Very Clever, unique and a nice flier.
I have always liked the Cessna 336-337. Have one plane with twin tandem motors, a micro bat, the front motor had a mishap and the replacement motor turned the opposite way, so both motors turn the same direction, it does torque roll now.
basicguy is offline Find More Posts by basicguy
Discussion Rudder: Pull-pull v.s. push-pull (push rod) DYORD 3D Flying 6 Jul 14, 2015 10:35 PM
Discussion Push-pull twin engined canard macboffin Aerial Photography 0 Jul 28, 2007 10:23 AM
Question Do You Have To Compensate For Torque On A Push/Pull Twin? FoamingInMI Foamies (Kits) 9 May 31, 2005 03:31 PM
Pull/Pull vs. Push/Pull Will-MO Parkflyers 3 May 22, 2003 09:02 PM
Pull-pull vs push-pull on a DLG tom_yellowblue Hand Launch 6 Aug 17, 2002 07:25 AM
