This thread is privately moderated by wamsy55, who may elect to delete unwanted replies.
Old Jul 12, 2015, 12:28 PM
Gordosoar is offline
Find More Posts by Gordosoar
Sabre holic
Gordosoar's Avatar
Beverly Hills, Florida
Joined Nov 2006
New to 3D in need of a simulator.
I'm looking for a simulator that I can use my 6i transmitter to my smart TV.
Anyone know of such a setup like that?
Gordosoar is offline Find More Posts by Gordosoar
Old Jul 12, 2015, 10:43 PM
H2SO4 is online now
Find More Posts by H2SO4
christian theme park operator
H2SO4's Avatar
Australia, New South Wales, Sydney
Joined Jan 2011
Probably not the right thread for it, but virtually any sim can be displayed on a TV, because the computer itself - whether PC or Mac or Linux - can have its output piped out to any monitor/TV.
Or if you're asking whether the sim can run directly on the "smart" TV without needing a computer, no, I very much doubt that. Sims are code, and code is compiled to run on a particular hardware platform. With the current crop of serious sims (Phoenix, Real Flight, AccuRC...), you still need a PC or Mac or Linux box to run the actual sim application. If your TV is built atop some version of Android, there may be a few arcade-like sims that would run directly on the TV, but so far none of those are hobby-grade training tools.
H2SO4 is online now Find More Posts by H2SO4
Old Jan 02, 2016, 11:03 PM
ryguy76 is offline
Find More Posts by ryguy76
Joined Apr 2014
Question on rolling harriers...
I specifically use elevator to control the turns in a rolling harrier and hold the appropriate elevator longer, on each revolution, if/when a turn is needed. Just beginning to learn rolling loops now and thought I'd ask in case doing it this way is something that is going to end up being challenging for learning new moves.
Thoughts?
ryguy76 is offline Find More Posts by ryguy76
Old Jan 03, 2016, 03:34 PM
JCFLYR is offline
Find More Posts by JCFLYR
Love the sticks
JCFLYR's Avatar
Mason, Michigan
Joined Nov 2009
Thoughts?
In the case of rolling left and turning right, I just delay the inputs a bit so I am just a hair behind what it takes for straight and level, this starts the airplane turning left. If you get behind just a bit too much just add more control input. Be careful though because getting behind tooooo much will cause you to get in trouble low to the ground.. I'm not sure if this is the industry standard but it works for me.
JCFLYR is offline Find More Posts by JCFLYR
Old Jan 03, 2016, 04:24 PM
ryguy76 is offline
Joined Apr 2014
Are delaying all inputs of just one specific one per revolution. I jump on the up elevator early to roll right and turn left, and delay the up elevator to roll right and turn right. Just wondering if this method is wise for getting better and doing more advanced flying.
Old Jan 03, 2016, 06:48 PM
theKM is offline
Find More Posts by theKM
↓↘→ + (punch)
theKM's Avatar
central PA.
Joined Sep 2004
yup, this is just changing of timing needing to perform turns during rollers. here's the diagram that explains the same...
theKM is offline Find More Posts by theKM
Latest blog entry: Updated Hatcam - Apr2016
Old Jan 03, 2016, 07:09 PM
JCFLYR is offline
Love the sticks
JCFLYR's Avatar
Mason, Michigan
Joined Nov 2009
KMs diagram is perfect. The stick movements are the same, the timing of them is what is adjusted.
Old Jan 03, 2016, 08:11 PM
ryguy76 is offline
Joined Apr 2014
Makes sense. Thanks guys. The only difference is the diagram seems to be using each quarter point in the turn where I'm limiting it to just early or late elevator inputs. Maybe I'm doing it subconsciously to the rudder too, but am not aware that I am.
Old Mar 16, 2016, 05:12 PM
yesbee1 is online now
Find More Posts by yesbee1
United States, CA, Redding
Joined Oct 2003
Knife edge turns and circles
Hi Guys
I have been practicing knife edge turns/circles in RF 7.5. Even when my KE is perfectly 90 egress and flying even straight(not climbing or sinking), when I push or pull elevator to do a turn the plane loses altitude. What sort of corrections should one be applying to maintain constant altitude in KE cicrles?
Thanks.
yesbee1 is online now Find More Posts by yesbee1
Old Mar 16, 2016, 05:17 PM
tominator06 is offline
Find More Posts by tominator06
Team Hillbilly
tominator06's Avatar
United States, MD, Dundalk
Joined Feb 2009
Basically the added "drag" from the elevator which is acting like a rudder in KE is slowing you down.
tominator06 is offline Find More Posts by tominator06
Old Mar 16, 2016, 05:18 PM
Team Hillbilly
Joined Feb 2009
Add a little throttle as you give the input. You will get used to how much with some practice.
Old Mar 16, 2016, 05:44 PM
Joined Oct 2003
Old Mar 16, 2016, 07:24 PM
wedoitall is offline
Find More Posts by wedoitall
wedoitall's Avatar
United States, WV, Clay
Joined Sep 2012
To follow up on what Tom said as you give the elevator Input you may have to let of the rudder some. Sometimes if you don't let off rudder some while giving more elevator, it could cause your plane to do a snap roll( depending on plane ) or put you in an unanticipated position.
wedoitall is offline Find More Posts by wedoitall
Old Mar 16, 2016, 10:26 PM
dalecheek1 is offline
Find More Posts by dalecheek1
United States, NC, Garner
Joined Nov 2012
Originally Posted by yesbee1 View Post
Hi Guys
Thanks.
Good KE about 2min in.....Listen to motor ...hope this helps......Throttle control all through turn,..
06 2215 Yak 39"55 Easy Flying (4 min 3 sec)
dalecheek1 is offline Find More Posts by dalecheek1
Old Mar 17, 2016, 02:56 PM
Depronicus is online now
Find More Posts by Depronicus
Altitude is my friend...
Depronicus's Avatar
Southern California
Joined May 2009
...when I push or pull elevator to do a turn the plane loses altitude. What sort of corrections should one be applying to maintain constant altitude in KE circles?
Apply the rudder.
If you're rolled right, with the right wingtip down, apply left rudder to increase your angle of attack. You may or may not have to increase throttle a little.
This is where anti-rudder coupling mixes are nice. Most planes have rudder coupling issues. They often pitch down and/or roll into the turn when you apply rudder only. Mixing in the proper amount of up elevator and adverse aileron with rudder movement eliminates that, and the plane only yaws when you apply rudder. It doesn't try to roll or dive.
Depronicus is online now Find More Posts by Depronicus
Mini-HowTo Nitroplane's 3D-Hawk PNP (They say ARF) Tutorial Dellagd 3D Foamies 41 Sep 09, 2011 08:00 PM
GWS Spitfire Build thread (with glassing tutorial) David Winter GWS (Grand Wing Servo) 156 Sep 14, 2009 05:42 AM
Question Brushless Tutorial/Help Thread? thatchf137 Power Systems 0 Jul 31, 2004 01:24 PM
