Old Today, 04:30 AM
pardshaw is offline
Find More Posts by pardshaw
Flying one day at a time....
pardshaw's Avatar
United Kingdom, Pardshaw
Joined Oct 2012
Analysis of failure.
The structure failed in compression on the top cap strip.
The lower cap strip bent continuously under tension with no difficulty at all and did not fail.
The details of the upper cap strip compression failure are simple. The glue bond to the plywood remained intact. The glue bond to the foam failed in shear, releasing the plywood and allowing it to snap, creating two new ends. These ends slid one over the other as the beam failed. Its all over in a fraction of a second - classic catastrophic failure.
The initiation of the first fracture is the stress increase at the sharp brick edge.
pardshaw is offline Find More Posts by pardshaw
Old Today, 04:33 AM
pardshaw is offline
pardshaw's Avatar
Joined Oct 2012
What does this mean?
Spars are not needed. Thin, wide spar caps top and bottom provide ample strength for foam wings.
Remember .... the test was a CONCENTRATED load, wings take much less severe DISTRIBUTED loads which are far more easily handled.
Old Today, 06:15 AM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Very interesting and thorough test Dave. I wonder what the result would be if you used the iron on formica edging instead of the plywood?
Just thinking that instead of priming an EPP wing and then applying xtreme type crossweave tape you could just use iron on edging in a similar pattern. A lot less hassle and probably lighter. Wouldn't degrade like cross weave does if exposed to sunlight either. Just need a little crossweave on the le for ding protection.
I say this as I'm just about ready to cover my EPP-Modelle Pluto wing
Andy
headlessagain is online now Find More Posts by headlessagain
Old Today, 06:51 AM
kompmen is online now
Find More Posts by kompmen
kompmen's Avatar
Russia, Sverdlovskaya oblast', Kamyshlov
Joined Sep 2011
Weasel profil Tsagi 8%
Weasel 11022016 (2 min 18 sec)
+Bonus Sturtfnzer profil PW 98
Bonus (3 min 52 sec)
kompmen is online now Find More Posts by kompmen
Discussion Just bought a used swift. Need you input renerc Electric Heli Talk 31 Mar 21, 2008 11:28 AM
Sold Bandit--New with just about all you need. Reduced utcadman Aircraft - Sailplanes (FS/W) 13 Oct 26, 2007 10:36 PM
Discussion Just approve the program AG, you don't need to know the details. thunder1 Life, The Universe, and Politics 13 Aug 19, 2007 03:25 AM
