Old Feb 09, 2016, 08:23 PM
DaOldGuy is online now
Find More Posts by DaOldGuy
Flying Half Pound and Down
DaOldGuy's Avatar
United States, PA, Bellefonte
Joined Dec 2007
Originally Posted by scmitchell11 View Post
The tabs on the bottom of the fuse broke off when I test fit it to the wing This didn't sit well with me so I cut the bottom edge of the fuse smooth and made 2 struts with tabs from ply. These are glued into the slots on the wing and should provide for glue surface area for the fuse to wing joint. This thing really is turning into a Frankenstein!
Oh... you never seen my PZ Typhoon 2 that I named FrankenPhoon... That was a creation.
DaOldGuy is online now Find More Posts by DaOldGuy
Old Feb 10, 2016, 07:47 PM
scmitchell11 is offline
Find More Posts by scmitchell11
United States, GA, Augusta
Joined Aug 2011
Wing mounted
Well Bottom Wing is mounted...Clamped up for glue to dry tonight. Supposed to be COLD (For Ga.) here this weekend so it might be a good weekend to turn on the heater in the garage and build!
scmitchell11 is offline Find More Posts by scmitchell11
Old Feb 12, 2016, 06:56 PM
Joined Aug 2011
glued up
Glued up. Tomorrow the top wing!
Old Feb 12, 2016, 09:43 PM
DaOldGuy's Avatar
Joined Dec 2007
Nice.. that is coming right along..
Old Feb 13, 2016, 06:33 PM
Joined Aug 2011
Got the top wing on this morning Glue is dry. Now the center cabane struts are drying in the fuse top In the morning will glue these to the top wing too. Had to help a friend hang some cattle gates today but tomorrow.... Maybe get the control surfaces mounted and start hanging some electronics!
Old Feb 14, 2016, 04:58 PM
DaOldGuy's Avatar
Joined Dec 2007
Came across a video of the Cutting Edge Bipe when the fella I got it from had it out for maiden. Its an old clip and not the best camera.
The Maiden Flight of Woody's Cutting Edge Bipe (1 min 54 sec)
Old Feb 14, 2016, 09:50 PM
Joined Aug 2011
Thank you for sharing! I LOVE that plane! Had a bit of a head ache today. Tried to work on the bipe but couldn't focus and wasn't enjoying it so....went to the hobby shop and purchased the last few bits to finish it Tomorrow is a holiday and rain on the way so.... Looks like a good day for building. With my luck I will get it finished just in time to go back to work!
Old Feb 14, 2016, 10:00 PM
Joined Aug 2011
Ok SO time to ask...Where is the CG on the bipe? I am assuming at the LE of the bottom wing?
Old Feb 16, 2016, 12:21 PM
DaDesign is offline
Find More Posts by DaDesign
ɹǝsn pǝɹǝʇsıƃǝɹ - inverted!
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
That would be really close. This will get you through the maiden flight.
If it is a little tail heavy move it back a little.
If I remember correctly I put mine center between the two wing tips (top and bottom tips) and I didn't have to adjust it any.
It's looking GREAT! More pictures.
Video it in flight for us also.
DaDesign is offline Find More Posts by DaDesign
Old Feb 16, 2016, 06:40 PM
Joined Aug 2011
All that's left is to link the ailerons. With a 2 cell pack it is balancing near the center of the top wing. This seems a little too far back (Tail heavy) I feared this with the paper and paint. My 3 sell packs should be here tomorrow. I hope this balance it a little better. Can you all suggest throws for elevator and ailerons?
Old Feb 16, 2016, 06:50 PM
DaOldGuy's Avatar
Joined Dec 2007
If I am flying its at least 45 degrees on all surfaces.... I have some scary tendencies...
You may opt for 10 degrees low rate and 25 on high if you are a fan of dual rates.
Old Feb 16, 2016, 07:56 PM
Joined Aug 2011
I use rates and EXPO as well.
Old Feb 16, 2016, 08:04 PM
DaOldGuy's Avatar
Joined Dec 2007
You got this then,
My next transmitter needs triple rate. Calm, hold on, and oh crap!
Joined Aug 2011
I will throw a pic up soon Just looks kinda funky right now with top ailerons drooping.
Old Feb 17, 2016, 01:01 PM
DaDesign is offline
DaDesign's Avatar
USA, SC, Greer
Joined Jul 2008
LOL
Sounds good!
Mini-HowTo Low cost XBee/GPS plane locator plans rich smith UAV - Unmanned Aerial Vehicles 5 Feb 04, 2009 02:57 PM
Easy way to make a quick, good looking jet Tumbler Electric Ducted Fan Jet Talk 54 Feb 08, 2005 05:26 PM
How to build a good looking pager motor plane! gbarc Scratchbuilt Indoor and Micro Models 9 Jul 04, 2004 06:09 PM
