Old Jul 16, 2015, 02:23 PM
jk6672 is online now
Find More Posts by jk6672
John
jk6672's Avatar
United States, CA, Heber
Joined Sep 2012
Hey if you guys like this stick you will love the giant big stick. I'm running a 12s set up on 8000mah packs and it's amazing with an easy 10 min flight. Vertical is good, but it's not crazy like the 4s set up I have on the electrostik
http://www.rcgroups.com/forums/showp...6&postcount=40
jk6672 is online now Find More Posts by jk6672
Old Jul 19, 2015, 01:44 PM
rkleinhenz is offline
Find More Posts by rkleinhenz
United States, NY, Wappingers Falls
Joined Jul 2014
elevator throw
The manual calls for 6 mm elevator throw in high rates, 3.2 mm on low. Does anyone use those settings? Seems REALLY low!
Rich
rkleinhenz is offline Find More Posts by rkleinhenz
Old Jul 19, 2015, 02:22 PM
ipscwolle is offline
Find More Posts by ipscwolle
ipscwolle's Avatar
Germany, BW, Eislingen
Joined Jun 2014
new member in your Electro Stik family
Hello together,
when I started rc-flying 35 years ago, my most famost plane was the German Version of the Electro Stik, a plane called Jonny from WIK with a 15 ccm engine.
After a long break of 30 years, I again started to fly rc-planes one year ago as I will need to have a hobby when I retire
Meanwhile my focus is on 3D planes, preferable from Precision Aerobatics.
But I couldn't stop to remember the Jonny, so now I found it's replica in form of the Electro Stik
I searched the Internet an found this thread, scanned everything here and ordered the Electro Stik from Great Planes. Hope it'll arrive soon.
Available in my hobbyroom are the following components:
Motor: RimFire .32 Brushless (800 Umin/V), Great Planes # GPMG4700
BEC: Brushless D-Power COMET 60 A, 2-6 LiPo, 5A S-BEC
Servos: HS-5085 MG, DIGITAL, HiTEC # 113085
Batteries: Hacker Lipo 4S 3000 mAh
One queston left: which Propeller would you suggest acc. to your experience?
I have the following propellers in my hobbyrom: 11x7, 11x8.5, 12x8, 13x8 and VOX/XOAR wooden props 12x6, 13x5, 13x6, 14x7 and T40
Thanks a lot in advance for further tips & tricks what to improve when building up the plane,
Wolfgang
ipscwolle is offline Find More Posts by ipscwolle
Old Jul 19, 2015, 02:37 PM
John
jk6672's Avatar
Joined Sep 2012
I use the VOX 13x8 on the 32 and it rips through the air!
I use a Castle ICE 75 and external BEC, same servos as you.
I'm balanced with a 4s 4000mah pack though
Old Jul 19, 2015, 03:02 PM
3rd Try is online now
Find More Posts by 3rd Try
United States, NY, Champlain
Joined Jul 2012
I'm flying a FirePower .46 720 Kv, SkyPower 60 Amp esc, Turnigy 4s 4000 Mah lipo and an APC 12x8e prop. Good speed and unlimited vertical. Had to move servos back to make room for the battery to get proper cg.
Regards
Dennis
PS: All electronics came from Heads Up Hobby in Florida, (headsuphobby,com)
3rd Try is online now Find More Posts by 3rd Try
Old Jul 19, 2015, 03:04 PM
Joined Jul 2012
Rich
Rich, Start with the recommended throws and then after the maiden adjust to your liking.
Regards
Dennis
