Old Jul 18, 2015, 10:39 PM
Chris3D is offline
Find More Posts by Chris3D
Chris3D's Avatar
Joined Apr 2001
V120d02s problem - motor, ESC or RX?
Hi everyone. So a few months ago, I had a pretty spectacular crash with my V120D02s V2. Slammed into the ground pretty hard, but surprisingly enough, all I did was bust the landing skids and split the canopy. Replaced the parts and it flew fine afterwards for several flights.
Just tried to fly it, and something is very wrong. The motor is incredibly jerky, the rotor speeds up, slows down, surges and stutters. I removed the motor to make sure nothing was binding mechanically, and everything is smooth. I ran the motor out of the heli, and noticed it has very little torque. I can grab it with my fingers while it's running at a moderate speed, and it just stops and then starts stuttering.
Any ideas what it could be? I don't have that much experience with brushless motors, so I'm not sure if that's a typical symptom of a damaged motor. Since it flew perfectly find probably 6-8 times after the big crash, I'm just not sure what it could be.
Thanks in advance.
Chris3D is offline Find More Posts by Chris3D
Old Jul 19, 2015, 04:13 AM
Fast AF is online now
Find More Posts by Fast AF
Fast AF's Avatar
Joined Jun 2015
Had a very similar problem on a brushless mcpx. After a crash the motor lost torque and it was very easy to stop it from full rpm. Replaced the esc and made no difference. Resistance was the same on all windings.
Replaced the motor and all was fine.
Fast AF is online now Find More Posts by Fast AF
Old Jul 19, 2015, 08:28 AM
dankar04 is online now
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
When you crashed did you hit TH to kill power to motor ? If you ran it stalled most likely could have fried motor. New motor is about $21.00-25.00 depending on vendor. Or you could upgrade motor to one cell HP08s.
dankar04 is online now Find More Posts by dankar04
Old Jul 21, 2015, 12:33 AM
jamichx is online now
Find More Posts by jamichx
jamichx's Avatar
Slovakia
Joined Sep 2013
Or you could try to rewire it
jamichx is online now Find More Posts by jamichx
Old Jul 21, 2015, 02:01 AM
Tucson, Az
Joined Feb 2007
Several month back made mistake of tighting blades on my #1 -V120. motor wouild not start. I bought another good used motor and esc. same problem. Then IHW said to lossen blades and bird was then fine. Point now I have extra motor/ esc that work prefect extra. If any interest let tem go for $25.00 for pair and few $$ for postage. , The guy who i got them from went to two cell operation GY280 RX/ HP08s two cell motor.
Old Jul 21, 2015, 10:22 AM
Chris3D is offline
Chris3D's Avatar
Joined Apr 2001
Thanks guys, yea, this confirms my suspicion that it's the motor. Like I said, I'm fairly new to brushless, so wasn't sure if this was a typical symptom of a failed motor. I thought I chopped the throttle before the crash, but hard to really say.
Jamichx, that's a great idea, I'm always up for trying to fix something, and I can't possibly make it any worse!
Dankar, thanks for the offer, I'll contact you depending on how my rewiring attempt goes.
Thanks guys.
Old Jul 23, 2015, 01:18 AM
jamichx's Avatar
Slovakia
Joined Sep 2013
Thanks guys.
If you decide to rewire your motor check my blog it may give you some hints
http://www.rcgroups.com/forums/showt...4#post32228864
Discussion Motor, battery or esc problem? Kooshball 3D Foamies 3 Jul 13, 2015 02:40 PM
Discussion Help! ESC or Motor Problem!? MemphysX Electric Power Cars 11 May 25, 2015 05:29 AM
Question 250-size quad - ESC or Motor or Naze32 or operator problem? mihavalencic Mini Multirotors 8 Nov 29, 2014 02:27 PM
Discussion Motor jerking continuously - rx or esc problem nguyen.tran Power Systems 13 Oct 23, 2010 08:01 AM
Help! esc, motor or rx problem? giancan Electric Plane Talk 19 Jun 24, 2010 09:26 AM
