Old Jul 08, 2014, 07:27 PM
Joined Dec 2006
Researching options
I'm not new to R/C, and have flown helis for years but I'm new to multi rotor. I'm reading as much as I can, and starting to get excited, but was hoping to throw out just a few questions to speed the process slightly.
I'm lost on sizing. Are there size categories like with regular helis? For instance - .30, .60, .90, or 450, 550, 600 etc? I have no clue whats considered small, medium, or large, and how to tell which is which.
Have any frame designs been found to be better than others?
Quad vs Hex - which, and why?
Better to build or buy RTF? Looking for a larger unit with lot's of bang for the buck. Don't mind a kit, or bare frame build. Ive seen some $3000 to $10,000 RTF craft that look great but that isn't going to happen for me!
Wmacky is offline Find More Posts by Wmacky
Old Jul 08, 2014, 07:40 PM
United States, PA, Doylestown
Joined Jan 2014
Keep reading and be sure to watch the videos.
Sizes seem to be, micro = less than 150mm, mini = 200 to 280, then 330, 450 and larger.
Its always better to build since it is much richer learning experience and you'll then be easier able to make repairs and modifications to suite your needs. If you have built Helis then building a quad will be easy. You just need to learn about setting up and tuning the flight controller.
I recommend starting with either a 220-250 size X frame or H frame. These can be flown lots of places and really are fun. This size is a good basis for proximity FPV or Arco.
Or if you would rather have a stable camera platform then start with a 450 size.
Either way keep the first one simple and light weight and a quad. You will crash.
waltr is offline Find More Posts by waltr
Old Jul 08, 2014, 09:26 PM
Joined Dec 2006
Ok, what is 450mm? rotor to rotor distance?
Old Jul 09, 2014, 08:12 AM
Joined Jan 2014
Multi-rotor size is measured from motor center to motor center on two opposite motors.
Discussion Is PM Research out of business? Deserteagle Steam Boats 2 Oct 21, 2013 05:07 AM
Question Days spent researching, just need a bit more help for my first RC Mandydeth Off-road Cars 1 Oct 13, 2013 10:09 AM
Discussion new to FPV and want your opinion on my setup (already research options) jaas75 FPV Talk 16 Aug 09, 2012 01:42 PM
Discussion Researching options to charge packs at the field. BrownEyedFool Batteries and Chargers 10 Jul 23, 2012 08:29 PM
research power options.. interesting rogwabbit Scratchbuilt Indoor and Micro Models 2 Jul 12, 2004 06:33 AM
