Old Aug 10, 2015, 09:50 AM
wrong17 is online now
Find More Posts by wrong17
wrong17
United States, CA, Sacramento
Joined Jan 2009
Originally Posted by eyber View Post
Hi again. so sorry, I have bought v4010-14 375kv and DJI 1552 folding prop (you suggested to me). But I don't know which one 6S battery. I want to fly 15 minute with A6000 camera. My hexa AUW with camera and gimbal 3,3-3.5kg. .. Maybe AUW will be almost 4,8-5kg. with battery.. Thanks again..
I am using the Multistar High Capacity 6S 10000mAh Multi-Rotor Lipo Pack. As so far they seem to do pretty well for the money. I think these batteries are the cheapest 10000mah 6s lipo that i can find. I got 15min of flight with a 4.9kg AUW (that weight included everything, battery, camera, gimbal and etc) tarot Hexa with these battery.
https://www.hobbyking.com/hobbyking/...dproduct=64439
wrong17 is online now Find More Posts by wrong17
Old Aug 10, 2015, 09:55 AM
eyber is offline
Find More Posts by eyber
Joined May 2014
Thanks for reply..
eyber is offline Find More Posts by eyber
Old Aug 11, 2015, 03:35 AM
eyber is offline
Joined May 2014
Hi, again. I bought sunnysky v4010 375kv and DJI 1552 folding prop.. But I can not DJI 1552 prop and multistar 10000mah 10c battery on ecalc.. I selected costum for prop and battery. I will buy 10000mah or 12000mah lipo battery. Which one battery. Sorry for my bad englsih.
Ecalc results:
Frame, battery holder, pro motor mount: almost 800g
Motors and props
6-sunnysky v4010 14- 375kv = 124g each
6-DJI 1552 folding prop =13g each
Power
6-40amp ESC = 40g each
1-10000mah multistar =1189g
1-Power Distribution board=5g
Electronics
almost 170g
Payload
1-Gimbal =maybe 3 axis 700g
1-a6000=344g with battery and memory card
1-Sony Nex 16-50 kitlens=116g
Old Aug 15, 2015, 11:00 AM
BravoGolf is offline
Find More Posts by BravoGolf
Spearheading an Alliance
BravoGolf's Avatar
United States, CO, Aspen
Joined Oct 2010
Just a heads up guys, Apparently today is model avaiation day, who knew.
Anyway...
Hobbyking has the 4S 10,000 mAh multistars on sale for $29.00. They normally run $58. I paid $67 when I bought my original two.
I use these in the skyhuner as well with great results so just wanted to pass this on.
BG
BravoGolf is offline Find More Posts by BravoGolf
Old Aug 18, 2015, 09:07 PM
RotoRon is online now
Find More Posts by RotoRon
RotoRon's Avatar
United States, UT, East Carbon
Joined Jan 2014
Would you guys go with an AVDome to protect the FC, or just install it directly to the frame?
I moved 4 of the standoffs for the stock top-mount battery tray to the outer holes to free up the 4 central holes to mount a vibration dampening mount for the flight controller, so that could easily be mounted under the battery tray. If I go the AV dome route, the controller will be much better protected in the event of a crash, but it adds a good bit of weight to the build.
I think the upper battery tray is pretty strong, though and could provide a decent amount of protection itself. And I want the option to use the top battery tray and add a second battery in parallel hanging from the tubes to balance a gimbal and get longer flight times.
RotoRon is online now Find More Posts by RotoRon
Old Aug 20, 2015, 01:34 AM
Vantasstic is online now
Find More Posts by Vantasstic
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
I've got a question for you experience Tarot 680 fliers. I've bashed a Talon Tricopter into a Y6. I'm using SS 3508 580kv motors with APC 14" MR props on 4S. It flies great, but I get what I think is aerodynamic vibrations from the over/under prop arrangement...which shakes my camera gimbal and I haven't been able to isolate it enough to make usable videos.
I'm looking at the Tarot 680 hex as a replacement frame, but I want to use the same same power setup I already have. I'm assuming I'll need longer arms to use 14" props. How much longer do the arms need to be...or perhaps, has anyone tried mounting the middle motors upside down and the front and back motors right side up? I'd like to keep the frame as small as possible for transportation purposes. I've also been looking at the ATG H4 folding quad of similar size, but folds up to an even smaller package. I'm just concerned dropping to a quad will effect my lift capability (not a huge deal for a GoPro anyway). The flat hex might survive a motor out condition better than a quad will though.
FWIW, I also have some APC 12" MR props, but I felt they were to weak on my Y6 unless I stepped up to 5S. I'd rather stay 4S as I can use them on other currently owned fixed wing and multirotor platforms. Also, are the Tarot retracts worth getting too?
I appreciate any inputs.
Vantasstic is online now Find More Posts by Vantasstic
Old Aug 21, 2015, 07:11 AM
Will971 is offline
Find More Posts by Will971
Joined May 2014
When build this multirotor are you advised to use loctite on the metal to metal screws? If so what type of loctite? I'm cautious as last time I used loctitie it disintegrated all my phantom's arms.
Will971 is offline Find More Posts by Will971
Old Aug 21, 2015, 09:55 AM
CyberCrash is offline
Find More Posts by CyberCrash
Germany
Joined Sep 2009
I use this one:
http://www.hobbyking.com/hobbyking/s..._Strength.html
Works perfectly. Screws are tight, but I still can loose them with a bit of force. Not ultra-hard-force, but it won't come loose in flight.
CyberCrash is offline Find More Posts by CyberCrash
Old Aug 21, 2015, 11:51 AM
Vantasstic's Avatar
Las Vegas, NV
Joined Sep 2003
Just use a dab of nail polish vs lock-tite. It'll help locks things in place, but will break away easier if/when you need to remove things...and it comes in a variety of pretty, pretty colors!!!!
Discussion Interested in getting a Mikrokopter hex or a droidworx hex. How hard is set up? LMAO Multirotor Talk 8 Dec 28, 2010 07:47 AM
Discussion Tarot 450SE V2 GF helipr0 Mini Helis 12 Oct 19, 2009 04:47 PM
Discussion Tarot 450SE V2 GF Kit? carmen5.3 Electric Heli Talk 8 Sep 18, 2009 08:54 AM
Discussion Align, Tarot, CopterX edfardos Electric Heli Talk 4 Mar 13, 2009 11:15 PM
For Sale Tarot 450 V2 KIT KS-Model Aircraft - Electric - Helis (FS/W) 5 Nov 10, 2008 10:16 AM
