Old May 13, 2013, 06:56 AM
Joined May 2013
Super CP tracks badly, but only in certain headspeed
I have a walkera Super Cp that generally is flying great, and tracks perfect at most of the throttlerange. Except for at about 30-40% throttle when the blades all of a sudden goes way out of line and the whole heli vibrates badly.(Seems like the blades are about 5mm apart if i look from the side) If I increase a little more it stops as fast as it came and i can fly again. Usually it happen before liftoff, but it seems to be worsening and over a broader and broader rpm range.
Does anyone have a good idea what the problem might be? Everything seems to be tight and good from what I can see/feel.
Thank you for any advise!
(I blame bad spelling on my phone and non-english motherlanguage)
evolve is offline Find More Posts by evolve
Old May 13, 2013, 10:52 AM
Hong Kong
Joined Jan 2010
I would check that the feathering shaft is not bent first.
zadaw is online now Find More Posts by zadaw
Old May 13, 2013, 10:54 AM
9958 gave me the toilet bowl
Proud Infidel's Avatar
United States, IL, Addison
Joined Jan 2012
Check this thread. If you still have the problem, a video would be nice.
Proud Infidel is offline Find More Posts by Proud Infidel
Old May 17, 2013, 03:25 AM
Joined May 2013
Spot on, it was the collar that has moved up a bit on the main shaft. Flies like a charm again, thank you
Old May 17, 2013, 01:37 PM
Joined Jan 2012
I've owned Syma, Great Wall, WL Toys, Nine Eagles, etc. Walkera is the only manufacturer that does not secure the main gear to the main shaft. How silly is that?
I put JB Weld epoxy inside the hub of the main gear, and a tiny bit on the main shaft, to secure the main gear to the main shaft. To the best of my knowledge, JB Weld is not permanent. I've never had to remove my main gear yet. You'll want a main gear & a main shaft in your parts inventory, just in case.
Discussion Blade wobble on Super CP ljump12 Micro Helis 5 May 07, 2013 09:06 AM
Discussion Brushless Setup - Super CP opinions on my cart Measuredpath Micro Helis 0 Apr 27, 2013 10:27 PM
Poll Servo Saver on Walkera Super CP Poll stringrazor Micro Helis 20 Apr 15, 2013 11:59 AM
Discussion Belt CP - blade tracking OK but paddles not in same plane as blades, slight angle turnbui Micro Helis 2 Jun 30, 2009 12:57 PM
Discussion Blade track well pos pitch but badly out of track neg pitch? shschon Electric Heli Talk 1 Jun 10, 2006 10:44 PM
