Old Nov 18, 2014, 11:30 AM
TAFTS
Chandler, AZ
Joined Apr 2008
Have you tried it outside? It only takes a few seconds for the air in the garage (closed in area) to become turbulent.
Scott Todd is offline Find More Posts by Scott Todd
Old Nov 18, 2014, 11:38 AM
3D plane, heli, quad, FPV noob
United States, TN, Smyrna
Joined Feb 2014
Same result outside. Just recorded inside because it was cold and dark outside.
moteasa is online now Find More Posts by moteasa
Old Nov 18, 2014, 11:46 AM
Joined Feb 2014
Clear frame with LEDs
Just posting what the clear frame looks like set up without FPV gear. The HK website doesn't show it lit up with the motors on. Works pretty well. The LED plates under the motors help lock in the landing gear as well. I'm curious if a hard landing or crash will break the gear or the LED board first. I'll take it easier on this frame and hopefully not find out. Ordering the one piece "maltese" frame for acrobatic bashing.
If you do decide to get the LED frame, order one of these if you use the KK2 mini or Naze32. The distribution board that comes with it is the larger size which makes mounting the small FCs more challenging. These adapters would have made easy work of it.
http://www.hobbyking.com/hobbyking/s...5mm_36mm_.html
Old Nov 18, 2014, 12:14 PM
MassiveOverkill's Avatar
United States, FL, Melbourne
Joined Feb 2011
Moteasa can you comment on whether the material seems stronger/weaker/the same as the black frame? Thanks.
MassiveOverkill is online now Find More Posts by MassiveOverkill
Site Sponsor
Old Nov 18, 2014, 01:33 PM
Joined Feb 2014
It seems to have a little more flex to it, but the mold of the frame is slightly different from the black version I had . The clear frame is 10g lighter than the black one when I put them on the scale.
This one has holes/standoffs for the smaller flight controller and the holes where the FPV cage are have been made smaller so you can use screws without the aluminum washers to fill the hex holes. I'm not sure if that's how the standard frames are shipping now or not.
Matt
Old Nov 18, 2014, 04:04 PM
Joined Feb 2011
Thanks Matt
Site Sponsor
Old Nov 18, 2014, 06:07 PM
United States, IN
Joined Apr 2014
Matt
Standard frame is this way now too. I ended up buying a full kit when I broke my FPV frame and noticed the difference.
Martian21 is online now Find More Posts by Martian21
Old Yesterday, 07:56 AM
Cajun Flyer
United States, LA, Lafayette
Joined Dec 2013
I'm running a KK2 FC, is there a OSD I can use the might have built in gps?
Quadflyer1 is offline Find More Posts by Quadflyer1
Old Yesterday, 10:50 AM
Quad fun for everyone!
RC2211's Avatar
United States, WI
Joined Oct 2013
As far as I know, there is no GPS or OSD that works with the KK2. You will need a separate system.
RC2211 is offline Find More Posts by RC2211
Old Yesterday, 10:16 PM
Cajun Flyer
Joined Dec 2013
I was looking at this
http://www.hobbyking.com/hobbyking/s...PS_Module.html
Old Today, 05:58 AM
asdiasx's Avatar
Brazil, PR, Curitiba
Joined May 2014
Maybe EzOSD is agood alternative...
asdiasx is offline Find More Posts by asdiasx
Discussion The HobbyKing ST360 360mm Quad Owners Thread (Read posts 1-4 before questions) richard9999 Multirotor Talk 36 Yesterday 08:03 AM
Discussion HobbyKing/Art-Tech F/A-18 Hornet mod thread. Oblivion Foamy EDFs 423 Nov 20, 2014 08:33 PM
Idea The Let's Boycott HobbyKing Until They Fix Their Customer Service Thread foxactual HobbyKing 7 Nov 24, 2013 09:56 AM
Discussion Hobbyking Mini-Pitts Thread ozzi supercub Parkflyers 249 May 12, 2012 08:46 PM
Discussion HobbyKing CS - Question. Not a complaint/rant/bash/etc. thread zultone Foamies (Scratchbuilt) 9 Oct 08, 2009 12:53 AM
