Old Jan 21, 2016, 03:13 PM
iadamz is offline
Find More Posts by iadamz
Joined Jan 2009
I agree. Completely overpriced. If TechOne ever went away I think I would loose it.
I try to recommend TechOne whenever possible.
iadamz is offline Find More Posts by iadamz
Old Jan 21, 2016, 03:21 PM
fauconnier is offline
Find More Posts by fauconnier
Flying a Falcon or a 3D plane.
fauconnier's Avatar
Canada, QC, Rimouski
Joined Jul 2012
+1
It's ridiculous to pay big bucks for printed cut sheets of packing foam.
fauconnier is offline Find More Posts by fauconnier
Old Jan 22, 2016, 08:20 AM
Rickflaguy is online now
Find More Posts by Rickflaguy
United States, FL, West Melbourne
Joined May 2011
Today ended flight testing on my rebuilt Yak 54. 15 mph gusting. The stabilizer handled the majority of it. Perfection. Ready to rumble.
Rickflaguy is online now Find More Posts by Rickflaguy
Old Jan 27, 2016, 02:00 PM
FieldofDreamsFlyer is online now
Find More Posts by FieldofDreamsFlyer
Field of Dreams Flyer
FieldofDreamsFlyer's Avatar
United States, CA, LA
Joined Sep 2004
Originally Posted by The Snake View Post
Has anyone built one of these yet?
Got two issues.
I need to get the pool pool router an elevator tighter, the photo is kind of vague.
My second issue is my ESC keeps cutting out, typically the default settings are usually ok. Any thoughts?
http://www.motionrc.com/techone-meti...-wingspan-pnp/
Pull Pull not Pool Pool , and whats a router .
FieldofDreamsFlyer is online now Find More Posts by FieldofDreamsFlyer
Old Jan 27, 2016, 02:12 PM
The Snake is offline
Find More Posts by The Snake
Registered RC NUT!
The Snake's Avatar
United States, CA, Lomita
Joined Jun 2002
YO Mikey,
I used my google voice option to speak it and i guess i didn't double check it son! You know, you saw my plane! Pull pull rudder...
The Snake is offline Find More Posts by The Snake
Old Feb 06, 2016, 01:53 PM
Enrique K. is offline
Find More Posts by Enrique K.
Enrique K.'s Avatar
Montevideo, Uruguay
Joined Apr 2006
Soft EPP?
A friend of mine recently bought a HobbyKing Yak 55, ostensibly made by TechOne. The EPP foam is much less rigid than the one in my Yaks ( of which I have two that are 2 and 3 years old). For example, checking the ailerons before take-off facing the wind, the whole plane oscillated substantially; mine barely budged .
Has anyone been experiencing this too or is my friend's example a one-off case?
Thanks!
Enrique K. is offline Find More Posts by Enrique K.
Old Feb 20, 2016, 06:32 AM
japan3d is offline
Find More Posts by japan3d
Rolling Takeoff
japan3d's Avatar
Japan
Joined Jun 2005
SU-31 Battery strap
Just finished a SU-31 II, is there a need for velcro on the battery? The battery strap doesn't seem to hold the battery very secure. Or maybe I'm not using the strap the right way.
japan3d is offline Find More Posts by japan3d
Old Feb 20, 2016, 08:02 AM
fauconnier's Avatar
Joined Jul 2012
Does it help you ?
Old Feb 26, 2016, 02:36 PM
krisvanjr is offline
Find More Posts by krisvanjr
Cloud Dancer Jr
krisvanjr's Avatar
United States, TX, Fort Worth
Joined Jun 2014
Got two issues.
I need to get the pull pull rudder an elevator tighter, the photo is kind of vague.
Did you get the pull pull fixed? If you use one string tied to one side of the rudder then thru the servo arm and around thru the other side of the servo arm to the other side of rudder. And put a screw in one of the servo arm holes. Wrap the string and tighten up too your likeing.
krisvanjr is offline Find More Posts by krisvanjr
Old Feb 26, 2016, 03:46 PM
Registered RC NUT!
The Snake's Avatar
Joined Jun 2002
I was able to get it more tight, also I used to slightly different method. I just got the two strings tight then put a drop of CA to keep it from coming loose
. But the elevator is a little loose, I will have to order some more strain to try your method on my elevator. Otherwise the Pull-Pull works great.
But my second issue is still unresolved, my ESC is still cutting out when I engage the ailerons fully. I had to cut my rates way down to fly it... I am wanting to wake up the 3D beast in this plane but can't. I may need to go with a bigger speed controller or what. It came with a 6amp ESC. It seams the BEC Is not strong enough to run four 5.5 Digital servos.
Old Feb 26, 2016, 03:53 PM
Cloud Dancer Jr
krisvanjr's Avatar
Joined Jun 2014
If you have very thin spider wire fishing line that works great. Or power line pro. Any of the breaded fishing lines work good.
Old Feb 27, 2016, 06:36 PM
iadamz is offline
Joined Jan 2009
First flights of the season on my Tempo today, got to near 60 in Twin Cities. Freaking love TechOne!!! Their planes fly so good and are just great fun. I also flew my $500 balsa plane and got not nearly the enjoyment. Fly Low!
Old Mar 23, 2016, 11:01 AM
LTOB is online now
Find More Posts by LTOB
LTOB's Avatar
United States, IL, East Moline
Joined Mar 2008
Morning guys, just ran across this thread for the Tech One planes. I am still wet behind the ears flyer with a little over a year under my belt. I picked up a Venus used at a swap meet a month ago. Well if I would have known these planes were so easy to fly I would have saved a bunch of money with trainers. I was thoroughly impressed the first time in the air. I started with 50% throws and 40% expo and have since swapped to 100% throws. I have suggested to all my flying buddies that want a 3D trainer to pick one up. Will be buying a new Venus shortly and passing this old one to my dad to learn with. did just finish up a GriffWerks plane so really anxious to see how it compares. Brian LTOB
LTOB is online now Find More Posts by LTOB
Old Mar 23, 2016, 02:10 PM
dalecheek1 is offline
Find More Posts by dalecheek1
United States, NC, Garner
Joined Nov 2012
07 12 15 Flying Swift Low and Slow in Small area (4 min 31 sec)
dalecheek1 is offline Find More Posts by dalecheek1
Old Mar 23, 2016, 08:40 PM
ahicks is online now
Find More Posts by ahicks
United States, MI, Waterford Charter Township
Joined Aug 2008
Dale, and others flying a Swift for a while,
Just built my 3rd Swift (in as many years) and tried an idea with more lively tumbling action in mind. Been flying it long enough now, and it's worked out well enough, where I thought I might share. I cut 2.5" off the back of the fuse prior to gluing the tail on. Had to add 6 small sheet metal screws to the back of the skid to get it into balance, but no overall weight increase. Even though I have several others, this is now my favorite foamie. Still very stable in all attitudes, but with a 2.5" shorter tail moment, obviously more capably when it comes to some of the higher energy stuff.
Mod is pretty simple if starting with a new plane. Really doesn't involve anything fancy.
Another move made just recently, is the swap to a higher kv motor. With no other changes (even using the same prop), I now have completely stupid power on tap with the ability to rocket up out of a hover. Only downside is reduced flight times when pushing it hard - maybe 5 minutes on a 1500mah. This extra power, with no weight increase, well worth what it cost to try. All components staying nice and cool.
I had been running a D3536/8 1000kv -
http://www.hobbyking.com/hobbykingst...arehouse_.html
And switched to the identical weight and size D3536/6 1250kv -
http://www.hobbyking.com/hobbyking/s...arehouse_.html
ahicks is online now Find More Posts by ahicks
Cool Twisted Hobbys Owners Thread! hercdriver7777 3D Foamies 12688 Yesterday 09:42 PM
Discussion Dynam Warbird Owners Thread Merlin Power Electric Warbirds 1529 May 23, 2016 06:38 PM
Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* Z06 Tony Multirotor Talk 1792 May 22, 2016 03:04 PM
Discussion Classic Parkzone Radian Owners thread wingymaster Electric Sailplanes 9 Jun 16, 2015 02:52 PM
New Product GAUI 500x/ GU-INS GPS Owners Thread - Tips, Problems And Experiences sap_2000 Multirotor Talk 231 Aug 05, 2014 04:32 AM
