Old Jan 25, 2016, 05:56 AM
ABOVE_AND_BEYOND is online now
Find More Posts by ABOVE_AND_BEYOND
ABOVE_AND_BEYOND's Avatar
Australia, NSW, Central Coast
Joined Jun 2014
I'm running stock digital servos in the durafly EFX and with the GR-12 set at 20ms everything seems great.
I wonder if it would be a good thing to have a servo pop up box when you are doing a new model set up ?
This did catch me out and if it wasn't for you I'd be heading back to the dealer for a replacement lol.. to have that setting in fail safe icon was a bit strange too but hey I'm just a newbie
I'm now fiddling with butterfly and I have will have some questions :
Firstly the orientation of the flap servos can they be mirror imaged when you install them or do they have to be positioned the same way ?
Can I control butterfly from the throttle stick which is channel one and have the second flap on channel 6 ? I don't want to run a Y lead.
Cheers Daz
ABOVE_AND_BEYOND is online now Find More Posts by ABOVE_AND_BEYOND
Last edited by ABOVE_AND_BEYOND; Jan 27, 2016 at 07:50 AM. Reason: silly predictive text on Iphone
Old Jan 30, 2016, 06:12 AM
rockowwc is online now
Find More Posts by rockowwc
Australia, QLD, Redbank Plains
Joined Jan 2016
Well I ordered my Teensy development board today.. Going to be working on a few projects ..
1. Conversion HUB.. allows using frsky s-port sensors with hott.
2. Try and make a capacative glow fuel tank level sensor.
Rob
rockowwc is online now Find More Posts by rockowwc
Old Jan 30, 2016, 04:51 PM
VHO is online now
VHO
Find More Posts by VHO
VHO
glider misguider
Armidale NSW Australia
Joined Feb 2007
Cheers Daz
Hi Darryl,
I presume you are trying to set up a glider (no motor) with 2 flaps and 2 ailerons on a 6 ch Rx. What Tx?
Mirror the flap and aileron servos is the way to go.
You might be 1 Ch short of a full house to do the job properly. Usually you use Ch1 to drive butterfly C2, Ch5 (ailerons), Ch6 and 7 (flaps) and elevator comp Ch3.
Without a better description of the set up you are trying to do, its a bit hard guessing how to help.
Tell us / me more.
Hutton
VHO is online now Find More Posts by VHO
Old Feb 01, 2016, 12:23 PM
bhughes is online now
Find More Posts by bhughes
Team pro-rc
bhughes's Avatar
Canada, AB, Camrose
Joined Aug 2013
Graupner frustration
I have a Graupner mz-18 radio and am struggling with trying to program flaps. I can't seem to figure out how to assign a channel to the function. The operating manual has very little text, used terminology that is unfamiliar and the pictures don't match the program in my transmitter. It also wants me to assign a "rate A" and "rate B" value but I want a proportional flap response. Anyone got experience with this?
question my buddie has. I haven't owned a plane with flaps since switching to graupner so I'm asking for help with his question lol
bhughes is online now Find More Posts by bhughes
Old Feb 02, 2016, 10:05 PM
Joined Jun 2014
Originally Posted by VHO View Post
Hi Darryl,
Tell us / me more.
Hutton
Hi Hutton,
Thank you for the info,
I swapped out left flap from ch1 to ch7 and that has made the flaps work nicely !
I'm running an MZ-18 with the 12 channel receiver and I would like to control the following :
Q-link 1( Normal )
*Full span Ailerons using the flaps as ailerons as well. found out where I can do this in "FLAP MIX" page
*Elevator
*Rudder
*Flap control on throttle stick with elevator compensation .
Q-link2 (Rename Butterfly)
*Outboard Ailerons
*Butterfly mix on throttle stick, assigned to S3 with elevator compensation.
*Elevator
*Rudder
Model is a 2 metre slope soarer.. pics to follow
Cheers Daz
For Sale AirField 2.4GHz DSSS N4 Radio System MTDV Aircraft - General - Radio Equipment (FS/W) 1 Nov 20, 2014 02:47 AM
Discussion E-FLY 6BII 2.4GHz R/C System flashing light fuggire Radios 1 Oct 25, 2010 03:24 PM
Wanted Tactic 2.4ghz radio and receiver system trade for micro microflitedude Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 2 Oct 10, 2010 10:12 PM
Sold Tactic 2.4ghz Radio and Receiver System Trade for Micro EVEN LOWER!! microflitedude Aircraft - General - Radio Equipment (FS/W) 0 Oct 09, 2010 05:38 PM
For Sale NEW - 2.4GHZ 2 channel Pistol R/C system SRM Cars - Cars and Parts (FS/W) 0 Oct 22, 2008 10:39 AM
