Old Oct 20, 2014, 07:01 PM
Yep! I'm addicted.....
mash76's Avatar
United States, AZ, Mesa
Joined Mar 2012
Originally Posted by mrfirkin View Post
Hey Mash,
That 4 blade & spinner are a ripper!
Can you let me know what they are & where I could order them please?
Cheers!
The spinner and prop are from Zinger, give them a call to place a order.
http://www.zingerpropeller.com
they were really nice to deal with. The only complaint I have is the spinner is a little small for the cowl but it still looks cool! I havent painted the props yet but they will be black with yellow tips when I get done.
mash76 is offline Find More Posts by mash76
Old Oct 20, 2014, 08:26 PM
Oh, Ho, Ho, It's Magic!
mrfirkin's Avatar
Australia
Joined Apr 2004
Originally Posted by mash76 View Post
yes they come on sheet to protect the adhesive side with a clear sheet on top of them. So you peel the backing off, then place them where you like then peel the top protective layer off. Easy to put on and look way better then the stock stickers.
I was convinced the original H9 stickers were the same & I spent about 15 minutes trying to peel off a 'top protective layer'
Thanks for the info re the prop & spinner.
That will look fantastic painted up.
mrfirkin is online now Find More Posts by mrfirkin
Old Oct 20, 2014, 08:32 PM
mrfirkin's Avatar
Australia
Joined Apr 2004
Originally Posted by GavDorro View Post
Flying off a salt lake, I do have a little trouble with taxiing. More than a slight breeze and I cant turn downwind as the tail wheel bounces over the rough ground and looses contact with the surface. You'll probably find 12 degrees is enough. I'm not really using a lot of rudder in the air anyway.
Have a look at your servo horns. Are you at the recommended distance from centre?
Hey Mash. Like your vinyls. They ARE still on an adhesive sheet, yes?
Did you do anything to beef up the tailwheel Gav ?
I fitted a Dubro .60 tailwheel bracket. Not sure if that would help. ?
Once the gear doors are glued on, it's pretty much a done deal
I'll check the distance on my servo horns. I just put the pushrod on a hole that best lined up.
Old Yesterday, 02:12 AM
mrfirkin's Avatar
Australia
Joined Apr 2004
I just checked the distance from the servo centre to the hole in the servo arm.
15mm as per the manual.
I got lucky !
Old Yesterday, 05:59 AM
Don't Panic!
GavDorro's Avatar
Australia, WA, Baldivis
Joined Jul 2011
You reckon thats dumb?
I cut one my first stickers out and put it in a dish of water, thinking they were water slide!
GavDorro is offline Find More Posts by GavDorro
Old Yesterday, 06:01 AM
Don't Panic!
GavDorro's Avatar
Joined Jul 2011
Sometimes you just gotta fluke stuff!
Tail wheel is standard at the moment. But I have had to adjust it and retighten it several times as it tends to twist out of alignment when I do something stupid like push the plane backwards.
Oh, and I deliberately left off the wheel hatches because I was also concerned about access....
Do you have a pic of the tail bracket handy?
Old Yesterday, 06:06 PM
mrfirkin's Avatar
Australia
Joined Apr 2004
I'll take a pic when I get home tonight. It certainly adds strength to the wobbly wire wheel.
I have glued my wheel hatches. I may attempt to drill a couple of holes straight up through the port side one so I can get a socket driver in there if ever I need to.
Yes, my stickers almost went in a dish of water too !
Old Yesterday, 08:22 PM
mrfirkin's Avatar
Australia
Joined Apr 2004
My next job is the elevator pushrods.
That will be fun bending them to line up with the 2 push rod tubes.
I have a wire bending jig around here somewhere !
Old Today, 03:37 AM
mrfirkin's Avatar
Australia
Joined Apr 2004
Hi Mash,
What size 4 blade are you using please ?
Old Today, 03:58 AM
mrfirkin's Avatar
Australia
Joined Apr 2004
Hey Gav,
Should give you an idea. It's a Du-Bro .60 Tailwheel Bracket.
I picked one up on Ebay for a couple of dollars.
Sorry for the lousy pic.
Old Today, 08:06 AM
mash76's Avatar
Joined Mar 2012
Hi Mash,
These are 15x7
Old Today, 06:41 PM
mrfirkin's Avatar
Australia
Joined Apr 2004
These are 15x7
Thanks!
Discussion NEW Top Flite P-51 Mustang 60 ARF MUTID Fuel Warbirds 10 May 11, 2009 10:29 PM
Discussion Hangar-9 P-51 Mustang PTS ARF dfruehwald Electric Warbirds 8 Mar 21, 2009 09:55 PM
Discussion Hangar 9 P-51 Mustang PTS ARF - Recommendations sandydr Fuel Warbirds 27 May 27, 2008 09:43 AM
Sold Hangar 9 P-51 Mustang PTS FUSELAGE ARF rcfunhouse Aircraft - Fuel - Airplanes (FS/W) 0 Mar 30, 2008 12:57 AM
For Sale F/S Hangar 9 P-51 Mustang 60 size electrified (Airframe Only) LOCAL PICKUP Aobid Aircraft - Electric - Airplanes (FS/W) 12 Jun 24, 2006 08:07 PM
