Old Feb 22, 2011, 01:39 AM
jofro is online now
Find More Posts by jofro
Joined Jan 2010
Idea
102 inch foamie EDF - NEW BATTERY SET RUN-IN.
Today I got great idea, I'm sick and tired of waiting last 10 month for the 72 inch "Mig15", it is still not here so I'm going to build instead huge 102 inch foamie powered by 127mm RAMTEC/SCORPION unit running on 12S10000mA. I started with 1/4 size drawing cut out. I will try to keep the AUW below the MOP 7kg limit with 3.5kg of batteries, it should be a great fun build, Joe.
jofro is online now Find More Posts by jofro
Old Feb 22, 2011, 10:30 AM
erh7771 is online now
Find More Posts by erh7771
Joined Nov 2005
How did your 90mm 12s go fast scratchbuild do?
Curious
erh7771 is online now Find More Posts by erh7771
Old Feb 22, 2011, 11:29 AM
crypto666 is offline
Find More Posts by crypto666
USA, NV, Caliente
Joined Mar 2009
This sounds interesting. I would encourage you to quit your job and get to work on this.
crypto666 is offline Find More Posts by crypto666
Old Feb 22, 2011, 04:22 PM
jofro is online now
Joined Jan 2010
Curious
Hi 777, to your question, it must be the best flying model I have built up to date. I didn't get a chance to get video yet, been too tight up. I managed 4 flights with it last Sunday at Tingalpa EDF jet meet. I just love it so I have decided to build the larger 127mm version. It will be bit of a challenge to strengthen it with lot of carbon fibre rods which I hide inside triple layers of my 6mm Depron sheeting, Regards Joe. ( I'll do some video soon of my 12S/90mm set up )
Old Feb 22, 2011, 11:13 PM
jofro is online now
Joined Jan 2010
I'm well on my way by cutting the first layer of Depron. 6mm carbon fibre tubing and balsa leading and trial edging will give me the stiffness of the air frame, Joe.
Old Feb 24, 2011, 03:36 PM
jofro is online now
Joined Jan 2010
This is very awkward job, it is so large that I have to do most of it on the floor. My workbench facility is useless for this size of model. I hope it will fit in my car! Joe.
Old Feb 24, 2011, 03:45 PM
falcon5 is offline
Find More Posts by falcon5
Capt. Z
falcon5's Avatar
United States, NV, Las Vegas
Joined Dec 2004
Awsome build!!! I will be watching this one!!! Keep up the great work!!
falcon5 is offline Find More Posts by falcon5
Old Feb 24, 2011, 03:55 PM
ApexAero is online now
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
It will surely fit on the car when you break out your surfboard racks!
Its a Monster!
(10 donkeys equal 1 burro)
ApexAero is online now Find More Posts by ApexAero
Old Feb 25, 2011, 01:21 AM
jofro is online now
Joined Jan 2010
The hardest job is done so I can start on the fiddly bits and painting. I trimmed the whole frame with 18mm balsa leading edge making it very stiff, Joe.
Old Feb 26, 2011, 02:55 AM
jofro is online now
Joined Jan 2010
My foamie is starting to take the shape, more Depron and epoxy added, I'll expect by the time I'm finished I will use 1/2 kg of epoxy and another 1/4 kg wasted while mixing always more then needed. Today I have worked out my CG and decided on position of my power unit and the battery placement before epoxying the main formers to hold the large shroud in place, Joe.
Old Feb 26, 2011, 10:09 AM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Looking GREAT!!!! nice work
Old Feb 27, 2011, 12:42 AM
jofro is online now
Joined Jan 2010
While the massive 127mm Ramtec power unit was screwed into laminated support legs using modified rubber grommets the whole assembly was bonded into my frame with 6deg. upthrust using almost 100 grams of epoxy. Both rails are well anchored some 25mm into the foam base through the 5mm base ply former. The rear of the thrust tube will be also supported to the main body. "CC160" ESC will be placed only 30mm in front of the shroud for optimum cooling, Joe.
Old Feb 28, 2011, 04:40 PM
jofro is online now
Joined Jan 2010
The first sparkle of life. My favored colour scheme, dark purple/red and white. The main body is just about ready to fit Elevon controls and made up landing gear. Joe.
Old Mar 01, 2011, 09:02 AM
falcon5 is offline
Capt. Z
falcon5's Avatar
Joined Dec 2004
Wow !!! we look forward to the maiden flight video, that should be awsome.
Old Mar 01, 2011, 04:03 PM
jofro is online now
Joined Jan 2010
More stiffening on the belly which also serves as servo arm guard. Currently I'm making up very simple but strong main landing gear. The whole airframe weighs 2.5kg so I'm on the target< Joe.
Data Ramtec edf w/ 123mm impeller scorpion 5035-650kv by TURBO FAN ELECTRICS test w/ video TurboFanElectric Electric Ducted Fan Jet Talk 355 Nov 24, 2014 11:32 AM
Cool 1 Horse Power Foamie jofro 3D Foamies 0 Dec 11, 2010 03:39 AM
New Product Ramtec EDF with special Motor by Scorpion Ramtec Electric Ducted Fan Jet Talk 14 Aug 31, 2010 10:55 PM
Discussion Falcon 25 Nitroplanes powered by scorpion 1400kv Jaraxle Power Systems 7 Oct 16, 2009 04:20 PM
For Sale Yellow Aircraft F4 Scorpion EDF Powered!! Scale330l Aircraft - Electric - Jets (FS/W) 3 Mar 16, 2009 10:50 PM
