Old Apr 04, 2015, 04:12 PM
James Lee is offline
Find More Posts by James Lee
Australia, NSW, Tabulam
Joined Nov 2014
Question
Park 480 good match for SR22 Cirrus 50.5 inch?
Hi all,fairly new to electric prop stuff,I recently bought a new in box great planes SR22 50.5 WS and wondeing if anyone has tried or could recomend the E flight Park 480?It says in the manual to use a e flight 10 power but a 480 just came up cheap so hoping it may suit.Cheers,James.
James Lee is offline Find More Posts by James Lee
Old Apr 04, 2015, 06:42 PM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
Sorry but the 480 just won't cut the mustard here. Eflite tend to use minimum sized motors in their arf's, I'd suspect the 10 to be the minimum, a 15 likely better on a 50" plane. If the plane is over 3-4 lbs, I'd be tempted to use a 25 size system. jm2cw fwiw Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Apr 04, 2015, 06:43 PM
Mike Dubovsky is offline
Find More Posts by Mike Dubovsky
Condescending Pedant
Joined Aug 2013
If you go by the 3 watts/gram rule of thumb, the E-flite Park 480 should be able to draw more power than the Rimfire. If you go by the published spec's. for each the Rimfire is about 20% more powerful. I think the Rimfire spec's are a bit overstated.
There are two E-Flite Park 480's. One is 1020 Kv and the other is 910 Kv. Which one are you looking at. The 1020Kv unit can pull a little more amps than the 910 Kv.
I think the Park 480 will Fly your plane just fine. It may not have the performance that you would get if you loaded the Rimfire up with a big prop and went to the max figures as published, but it will fly very well.
Mike Dubovsky is offline Find More Posts by Mike Dubovsky
Old Apr 05, 2015, 05:44 PM
Joined Nov 2014
Thankyou for the replies,the motor Im looking at is the 1020kv.I would like it to be slightly over powered than under,is there an ebay combo that would fit/work that I could use?
Old Apr 05, 2015, 06:17 PM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
Start with what the model needs and how you want to fly it, and then choose an appropriate power system, not just a motor.
Assuming 3lbs as per Tower's claims (maybe a bit optimistic on the light side for a 50" ARF) and looking for good sport aerobatics, you'd want a 300-350W power system. That suggests straight away motors in the 100g class, not the 71g Rimfire .10. It also suggests the 87g Park 480 is on the small side.
To deliver up to 350W, 3S at up to 35A makes good sense, and capacity of at least 2500 mAh will give over 6 minutes per flight while being easy on the batteries.
Tower suggests a 10x7 prop, but is that because it is a good choice for the model, the biggest diameter that will fit, or just the biggest that will work with a Rimfire .10? Will a bigger prop fit?
If you're limited to 10" props, then you will need Kv around 1100-1200 rpm/V in motors around 100g - the lower end of the Kv range in heavier motors that are more efficient at 300W+. The Park 480-1020 will only use about 250W if you're limited to a 10" prop. If you can use an 11 or 12" prop, you'll find a few more motor options in the 100g range, and the overall power system will be more efficient.
The other factor to consider is motor weight. Does it tend to being tail heavy? If so, then motors around 130-150g have plenty of options in the Kv you need and wil run more efficiently and cooler than ~80g motors.
I'd be having a good look at how the model balances and what props fit before choosing a motor - and if the Park 480 is a really good deal - grab it for the next model as it's likely not a great choice for this one.
scirocco is online now Find More Posts by scirocco
Old Apr 05, 2015, 06:50 PM
Joined Aug 2013
It's a sport scale model. If we were looking at an aerobatic plane, maybe 300-350 watts would be right, but I think for scale type performance the 480 would deliver what is needed. I guess it depends on what you want to do with the plane.
Old Apr 05, 2015, 07:13 PM
scirocco's Avatar
Joined Feb 2001
Good points, especially the last sentence. I'd add "and what it actually weighs and how it balances".
Old Apr 05, 2015, 07:21 PM
Joined Aug 2013
Yes, if it needs nose weight, better to use motor or battery to get it rather than lead.
Sold Cirrus SR22 rwalbroehl Aircraft - Electric - Airplanes (FS/W) 0 Mar 11, 2015 04:13 PM
For Sale Hangar 9 cirrus sr22 30 cc lorhd2005 Aircraft - Electric - Airplanes (FS/W) 0 Dec 15, 2014 11:00 AM
Sold Great Planes Cirrus SR22 Turbo EP ARF 50.5" lmpbpd Aircraft - Electric - Airplanes (FS/W) 0 Sep 16, 2014 10:37 PM
Sold New - Great Planes Cirrus SR22 Turbo 50.5" - LPU - $200 Skywarrior01 Aircraft - Electric - Airplanes (FS/W) 0 Aug 24, 2014 06:59 AM
For Sale New - Great Planes Cirrus SR22 Turbo 50.5" - LPU - $200 Skywarrior01 Aircraft - Electric - Airplanes (FS/W) 0 Oct 26, 2013 10:00 PM
