Old Mar 25, 2015, 08:07 PM
sniper695 is offline
Find More Posts by sniper695
United States, MI, Saginaw
Joined Apr 2013
super cp will fly 2-3 inches high for a few seconds
this is on a new freshly charged battery, the gear and collar are all in the correct spots, it seems to spin up, then when the pitch changes to take off motor struggles and the blade slows way down, I tried a different motor I had but I'm not sure if it is any good, but they both had same issue. any ideas. also I hot glued the power wires to the main board.
sniper695 is offline Find More Posts by sniper695
Old Mar 26, 2015, 05:36 PM
Joined Apr 2013
Any ideas what could cause this?
Old Mar 26, 2015, 10:43 PM
XRAYRON is offline
Find More Posts by XRAYRON
XRAYRON's Avatar
United States, FL, Auburndale
Joined Jan 2015
Which transmitter are you using and what are your pitch/throttle settings at??
So you didn't solder or use heatless solder? Hotglued... well as soon as those wires heat up they are going to lose power.
XRAYRON is offline Find More Posts by XRAYRON
Old Mar 26, 2015, 10:58 PM
dankar04 is online now
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
I have had to resolder a Genius c/p power lead and also a Ladybird V1 power lead. Some of brand x batteries connectors get very tight. contant battery removal weakened leads. I did have a Genius c/p spin lose its pinion gear.
Drop of loctite red cured problem. Pinion slid right off. Made sure if this is problem gear lines up right. Check main gear no burrs as could be worn main gear it motor is to tight.
dankar04 is online now Find More Posts by dankar04
Old Mar 27, 2015, 01:44 PM
Joined Apr 2013
I am not home so I'm not sure what the settings are but it used to fly fine at those settings, the gear spins properly, at low pitch the blades spin at full speed, when pitch is increased the slow down
I put hot glue around the wires to reinforce them, they were working fine, Idid it for extra strength. there are a lot of suggestions to do that. to avoid needing to resolder.
Old Mar 27, 2015, 06:09 PM
Tucson, Az
Joined Feb 2007
Do as you may but flying electric helis/ quads etc soldering will need to be done at some time. Power leads are easy to do. cheap thin pencil type soldering iron/ 60/40 solder and flux get er done. Batteries run to low will charge up fine but under load will dump and lose power. This may not be problem, hope you find issue.
Old Mar 29, 2015, 09:24 PM
Ribble is online now
Find More Posts by Ribble
Crash and learn
United States, PA
Joined Dec 2011
What does it do using the old battery?
Ribble is online now Find More Posts by Ribble
Old Mar 30, 2015, 08:52 AM
Joined Apr 2013
same thing, I ordered a new motor, I will see if that helps
Discussion video for a few seconds then cuts. tomasaurus FPV Equipment 3 Jan 30, 2015 03:26 PM
Discussion Walkera super cp will not lift off n2quads 3D Electric Heli Flying 6 Jan 26, 2015 04:07 PM
Sold Just a few hours left!!! 3ea JR S185 Super High Speed Servo Mike Fortune Aircraft - General - Radio Equipment (FS/W) 0 Sep 27, 2014 09:39 PM
Sold Props: 3 pair 10 inch CF, 2 pair 10 inch carbon/nylon, 3 pair 9 inch HQ TPSreports Aircraft - Electric - Multirotor (FS/W) 1 Jun 11, 2014 04:49 PM
Discussion Will 2 of these motors on 3 cells fly the P-38 ? cyclops2 GWS (Grand Wing Servo) 8 Dec 03, 2013 04:19 PM
