Old May 19, 2015, 09:14 PM
OrangeBird is offline
Find More Posts by OrangeBird
Wow, the sky is clear
OrangeBird's Avatar
Canada, QC, Chicoutimi
Joined Aug 2012
Hi FyreSG
Try to add a plastic spacer under each main blade.....
See photo # 41 of my Blog, resize photo for see the spacer and read the text writed by vincent 713 upper the photo # 41...
Also photo # 12 - # 13 of this Section # 1
Bye Gilles
OrangeBird is offline Find More Posts by OrangeBird
Old May 20, 2015, 06:31 AM
hifinsword is online now
Find More Posts by hifinsword
Blue Skies
hifinsword's Avatar
United States, VA, Williamsburg
Joined May 2012
Originally Posted by FyreSG View Post
Hi OrangeBird,
Yes, with the blade tracking is bad a.k.a. blade does not track well, then there will be vibrations.
But tracking is not adjustable on V912; the linkages (rotor blades to flybar) are fixed. How would tracking be off, and how to fix that?
Adjusting blade tracking is adjustable on the V912. Try the procedure here in my blog on the V913.
http://www.rcgroups.com/forums/showp...0&postcount=10
Don
hifinsword is online now Find More Posts by hifinsword
Old May 20, 2015, 10:36 AM
OrangeBird's Avatar
Joined Aug 2012
Hi FyreSG
Also
Using Lasers for RC Helicopter Blade Tracking Measurement/Adjustments
Old May 20, 2015, 11:10 AM
FyreSG is online now
Find More Posts by FyreSG
新加坡的飞儿
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
Thanks guys but I'm stopped flying FP helis such as V912, and I can fix the tracking of my CP helis. It is pretty straightforward for larger CP helis. I asked the question earlier because typically (based on my CP heli experience) tracking is fixed by adjusting the linkage rods, which is not possible for V912. Now I see the other way to do it, which is possible for FP helis like V912 - bend higher prop lower, or the lower prop higher.
FyreSG is online now Find More Posts by FyreSG
Old May 22, 2015, 09:19 AM
OrangeBird's Avatar
Joined Aug 2012
Hi Guys
New offers on V912 and V915
Also save 35 %
Cheerson CX20 CX-20 Open-source Version Auto-Pathfinder Quadcopter RT
Old May 24, 2015, 08:10 PM
OrangeBird's Avatar
Joined Aug 2012
Hi Guys
Warning ..Warning ..Warning ..Warning
With this charger 3S, if you make the mistake of reversing the polarity of the battery in this charger you go burn one or two I/C AP5056 as I do. So be careful when connecting the battery to the charger.....
I just repair it ........
I added color dots for help me.....
Mini-Review WLtoys V922 6-Channel CP Flybarless Helicopter Mini-Review FyreSG Micro Helis 8307 May 17, 2015 07:07 PM
Discussion WLToys V912/NEX helicopter jameschen072 Micro Helis 41 Jan 27, 2015 10:17 AM
Mini-Review The Walkera SUPER FP review (4 Channel Flybarless fixed pitch helicopter) jameschen072 Micro Helis 471 Mar 14, 2014 10:28 AM
Sold Two (2) Nine Eagles Solo Pro V 4-Channel Fixed Pitch 45 Flybar Coaxial RTF Helis ShaneXman Aircraft - Electric - Helis (FS/W) 4 Mar 09, 2012 10:23 AM
