Old Oct 17, 2014, 03:39 AM
United Kingdom, Sheffield
Joined Sep 2013
please help delta wing 1st built
just built my 1st delta wing im a complete newbie to planes
its all been put togther now
prob is with the elivons
i cant seem to get them to go in right directions
when i press up and down my dx6i the elivons right and left go up and down
when i press left are right the elivons go up are down
can please someone tell me what should happen with the elivons when i press
up and down ??
left and right ??
im using a dx6i ive tried changing the plugs in the reciver to diffrent places
at min right elivon is in eliv and left elivon is in aile i think
leespuggy is offline Find More Posts by leespuggy
Joined Sep 2013
thers loads of good videos on net on scratch building delta wings but cant find one that goes into detail about how to set up the elivons
Old Oct 17, 2014, 03:50 AM
Joined Sep 2013
basicly scrap everthing ive said looking for someone to run me throw setup as if ive just about to bind my dx6i to the delta wing
also im using a spectrum ar 6100e reciver
Old Oct 17, 2014, 04:12 AM
serial scratchbuilder
Granted's Avatar
Canada, BC, Mission
Joined Sep 2012
http://www.rcgroups.com/forums/showthread.php?t=1553248
Granted is offline Find More Posts by Granted
Old Oct 17, 2014, 04:53 AM
Joined Sep 2013
thanks very much will give that a try mate again thanks alot will report back later today with a bit of luck hehe
Old Oct 17, 2014, 08:20 AM
buyer of the farm
United States, FL, DeLand
Joined Mar 2009
Mmmmmmmmmmmmkay.........
Rockin Robbins is offline Find More Posts by Rockin Robbins
Old Oct 17, 2014, 10:20 AM
Ft Lauderdale
Number_6's Avatar
Joined Sep 2012
Hey...
I didn't read that thread complete...but
Stand behind the plane, looking forward:
If you move the aileron stick to right, the right
aileron should give you 'a High Five' ( move up).
Move to left, left goes up.
Pull stick back, to climb, both go up.
Push forward, both go down,
Remember to do this from standing behind the plane!
Number_6 is offline Find More Posts by Number_6
Old Oct 18, 2014, 02:28 AM
Joined Sep 2013
Cheers granted. Followed the inscructions in the link all working as it should now
I no I'm a pain but could you reccomend me the dual rate and expo settings for a medium size delta wing thanks
Old Oct 19, 2014, 06:08 PM
United Kingdom, England, Dorset
Joined Mar 2011
without seeing what travel your getting on full rates, its hard to say with rates. expo i would start about 30%
on my tek sumo, i went with 90 rates, 30 expo for high rates
60 rates, 30 expo low rates
collective itch is offline Find More Posts by collective itch
Old Oct 22, 2014, 10:36 AM
Joined Sep 2013
cheers for info matey was thinking about getting a teksumo are bonsia wing myself
are they hard to fly?
Old Oct 22, 2014, 10:40 AM
Joined Mar 2011
I've had a few planks, and a few edfa, so didn't find it hard to fly. they can be twitchy on the elevator axis as they are wings. go for it, they are so well priced if you really smash it up you can buy another one!
Old Oct 23, 2014, 04:06 PM
DustBen's Avatar
United States, NE, Kearney
Joined Dec 2011
The dual rate settings are trivial compared to the amount of throw of the elevon.
Because of geometric variables, you can have widely different throws while using the same transmitter inputs.
Using a long servo arm connected to the elevon control horn hole close to the hinge line will give a much greater throw than a short servo arm attached to the control horn hole far from the hinge line.
DustBen is online now Find More Posts by DustBen
Discussion pros and cons of a delta wing or fixed wing for FPV jeff262 FPV Aircraft 5 Oct 23, 2014 02:14 AM
Discussion Delta Ray - 1st Vid - What Went Wrong? (Also Plane Eating Tree) Thirty30 Beginner Training Area (Aircraft-Electric) 6 Sep 30, 2014 04:35 PM
Discussion Delta wing is built . Need help mensite Electric Plane Talk 4 Jun 11, 2014 12:52 PM
Wanted Topmodel "Bullit" - built up Delta wing joe_crash Aircraft - Electric - Airplanes (FS/W) 7 Mar 22, 2014 02:13 PM
Help! Scratchbuilt Delta wing help ggradtech Flying Wings 0 Sep 25, 2013 09:17 PM
