Old Jul 19, 2015, 08:44 PM
finguz is offline
Find More Posts by finguz
finguz's Avatar
United States, CA, San Diego
Joined Mar 2012
LED/resistor - final voltage issue
I'm just trying to power a single 2.2v orange (blinking) LED using the calculator here:
http://ledcalculator.net/
Power supply: 5.23v (just what my battery is charged to at the moment, just a reference for now)
LED forward voltage: 2-2.2v
Current rating: 20ma
The online calculator mentioned above says to use about a 220ohm resistor for this application (if I want about a 15ma current draw).
But here's my problem: when I connect it all together, with even a 300ohm resistor inline, I still get a +3v reading at my 2.2v LED. Which means too much voltage is being supplied still, even though I used an even higher resistor than suggested. It doesn't sound like my 2.2v leds would last very long at +3v.
Something is wrong here. Am I looking at this right? Does the answer have something to do with the wattage staying the same even though the voltage reads higher (like as if the voltage were higher and current appropriately lower to equal the same wattage in the end). Otherwise I'm lost at this point.
finguz is offline Find More Posts by finguz
Old Jul 19, 2015, 10:43 PM
finguz is offline
finguz's Avatar
Joined Mar 2012
Maybe my meter is broken. It has been acting up lately but I just thought it had a broken solder joint on the connectors.
Old Jul 21, 2015, 09:06 PM
Barn-E-Stormer is offline
Find More Posts by Barn-E-Stormer
Dark Yet??
Barn-E-Stormer's Avatar
United States, VA, Narrows
Joined Dec 2009
So you have 5.2V on one end of the resistor and 3V on the other end, for a total of 2.2V across 300 ohms? That would only be 7ma, no danger to the LED. The voltage across the LED is a specification at a specific current. I suspect you are not putting enough current thru the LED to drive the forward voltage down that low. The LED is a active device. It's forward voltage changes with current. The resistor tells no lies.
Barn-E-Stormer is offline Find More Posts by Barn-E-Stormer
Discussion Combining resistor values for SMD LEDs Markran Night Flying 1 Jul 27, 2014 03:14 PM
Sold Make your own LED lights wire and resistors muck76 Aircraft - General - Miscellaneous (FS/W) 0 Dec 26, 2013 09:36 AM
Resistor values for LED's please tipperary Electric Plane Talk 3 Oct 20, 2005 03:24 PM
resistors for LED's??? raythomas DIY Electronics 5 Mar 24, 2005 04:53 AM
Now OnLine: LED resistor calculator just for R/C'ers Mr.RC-CAM Modeling Science 32 Oct 29, 2002 09:54 PM
