A J3 is a very stable plane so the width of your fingers doesn't really matter.... if it's level when you center your fingers on the exact spot then it's good enough; in reality even if it's slightly tail down or nose down at this spot, you may find that there's no point to added weight since it is still perfectly flyable (slightly nose down is better than tail down). Some people take 1/4" dowels and put pencil erasers on the ends and put the dowels into something solid like a block of wood as a rudimentary balancing machine. There are also commercially available balancers... But, for most planes the finger method is just fine.
Joined Aug 2011
Your over analyzing a bit. Use your fingernails to fine tune the point if you like, or some other smaller point that won't poke into the wing. Also some makers manuals don't list the correct CG, it should be from 25% to as far back as 33% of the wing cord, farther forward is more stable and best for a maiden flight, adjust to suit afterwards.
Joined Jan 2013
Balance model on your finger tips at the point shown on the instructions with battery in place. It is usually necessary to fine tune the CG after the maiden flight moving battery pack forward or backward. The cg point shown on the plans/instructions is only a good starting point.Best to do the maiden with model balancing somewhat nose down.
| Thread Tools | |
| Discussion Best way to setup the rudder throws on a 450 Heli (or any Heli with a Gyro) | SoarWest | Beginner Training Area (Heli-Electric) | 8 | Jan 15, 2013 03:52 AM |
| Question What is the best way to find CG on the SS | Stimpy56 | Beginner Training Area (Aircraft-Electric) | 9 | Mar 28, 2008 07:57 AM |
| Discussion J3 Cub on the way. | boomerace | Parkflyers | 13 | Dec 31, 2007 03:19 PM |
| Discussion A-10 GWS Best way to check CG | jet_d | Foamy EDFs | 4 | May 14, 2007 10:55 PM |
| Best way to check CG | joeker | Parkflyers | 12 | Feb 19, 2004 05:41 PM |
