Old Yesterday, 12:36 AM
Monaco
Joined Dec 2006
Originally Posted by Razerworkz View Post
I swapped out my main gear with the all metal FMS 1700mm gear. The go up nice and slow and fit with little changes. I haven't found a good replacement for the base nose gear.
My grass field destroys the circuit board in the nose gear every 9 flights. It's only 12 bucks but need to figure something out.
Do you mean the gear and door sequencer module, or some other board mounted in the nose gear servo ?
What happens to the board, vibration damage ?
Photo would be great
Many thanks in advance :-)
EuroDriver is offline Find More Posts by EuroDriver
Old Yesterday, 02:50 PM
Monaco
Joined Dec 2006
Originally Posted by Knife Liddle View Post
https://www.hobbyking.com/hobbyking/...n_.htmlSTRIKE]
I use this on mine at almost 13lbs.
Many Thanks, I ordered one today !
I have also ordered a Zippy 8S 35C 4,500 mah battery that weighs less, and should help bring the CG closer to 185. Lower internal resistance should also give the fan a bit more oomph on take off I hope
Discussion HK coming soon new fiberglass sport jet 90mm Tim Wan Electric Ducted Fan Jet Talk 91 Sep 14, 2014 10:01 PM
Build Log 90mm Sport Jet (Inspired by the JMP Firebird) JLink125 Scratchbuilt EDFs 136 Feb 11, 2014 10:03 PM
Question Where`s that new Fiberglass 90mm Sport Jet? Knife Liddle HobbyKing 1 Dec 09, 2013 01:30 AM
Sold New Jet Teng JTM 90mm Viper Jet w/TJ90 & Tamjet Retracts Alkaline Aircraft - Electric - Jets (FS/W) 4 Oct 23, 2013 01:44 PM
Sold HK F9F-8 Cougar Composite 90mm EDF Jet 1100mm (ARF) lmpbpd Aircraft - Electric - Jets (FS/W) 0 Oct 16, 2013 09:18 PM
